Computer Econometre conversion from litres/100km to mpg - Civinfo
post #1 of 15 (permalink) Old 5th August 2008, 22:00 Thread Starter
dextergregor's Avatar
Does anyone know how to switch from lt/100km to mpg? I've got a LHD civic. Checked the menu and cant seem to find where to do this. Any help would be much appreciated.
dextergregor is offline
post #2 of 15 (permalink) Old 5th August 2008, 22:03
Car: MX-5, C6 Vette & MB S212
You can´t.
The UK cars can change from MPH to KM/H.
Not sure if the fuel computer changes also though.
You can use this, however:
http://online.unitconverterpro.com/u...uel-efficiency
FWH is offline
post #3 of 15 (permalink) Old 5th August 2008, 22:05
gm1980's Avatar
google l/100 kmh to mpg and you will find a variety of convereters if you cant do it with the car
gm1980 is offline
post #4 of 15 (permalink) Old 6th August 2008, 09:41
UnreaL's Avatar
You can simply use the google calculator and enter the query directly into google. E.g. like this.
UnreaL is offline
post #5 of 15 (permalink) Old 6th August 2008, 09:44
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
How about a MPL to MPG converter??
NoNumpty is offline
post #6 of 15 (permalink) Old 6th August 2008, 09:51
UnreaL's Avatar
Try entering "6.9 l/100 km in miles per liter" into google. It doesn't recognize "mpl", but "miles per liter" works.
UnreaL is offline
post #7 of 15 (permalink) Old 6th August 2008, 10:51
pjr
pjr's Avatar
Car: Mk VII Golf GTI
The trip computer also changes on the UK cars, to show l/100km instead of mpg.
pjr is offline
post #8 of 15 (permalink) Old 6th August 2008, 12:40
NoNumpty's Avatar
Hi UnreaL - thanks for that but ... this gives me a KM per liter to MPG I need to know a Miles per liter to Miles per Gallon.
My trip in my car says I've done 595 miles and I fill up with 47.85 liters - what is the MPG?
I know how to work it out long hand and the answer is 55.33 MPG, what I want to know is there a tool for this?
NoNumpty is offline
post #9 of 15 (permalink) Old 6th August 2008, 13:10
UnreaL's Avatar
You can always google for this: "47.85 liters / 595 miles in miles per uk gallon" and you'll get approximately what you said (it comes out as 56.5 MPG though).
Note though that apparently the US MPG and UK MPG aren't the same (I'm from a metric country so this is news to me) so that's why you need to add "uk" to the query.
As far as online tools go, you can try this one: Unit Conversions
UnreaL is offline
Thanks to UnreaL from:
post #10 of 15 (permalink) Old 6th August 2008, 13:16
Do you have the two buttons on your steering wheel? one I think is the letter "i" and the other is sel/res? Somthing like that? If you do you can hold the i, when stationary, then you can select all settings for your display!
marc_wareing is offline
post #11 of 15 (permalink) Old 6th August 2008, 13:17
NoNumpty's Avatar
me bad - got the conversion wrong 4.45 instead of 4.54
cool thanks UnreaL - did as you suggested and here is the result
(47.85 litres) / (595 miles) = 56.5292512 miles per Imperial gallon
NoNumpty is offline
post #12 of 15 (permalink) Old 6th August 2008, 13:24
UnreaL's Avatar
Heh, no problem, it also solved my problem of trying to figure out how come all you guys had such high MPG values. I kept converting my l/100km into US MPG and I'd get significantly lower numbers that in UK MPG. I just improved my fuel economy from 34 MPG to 40 MPG
UnreaL is offline
post #13 of 15 (permalink) Old 6th August 2008, 13:31
NoNumpty's Avatar
wayhay!!
NoNumpty is offline
post #14 of 15 (permalink) Old 6th August 2008, 21:37
You were better off the other way, because US fuel is half the price.
FWH is offline
post #15 of 15 (permalink) Old 7th August 2008, 00:41
Strange Engineer
Steeph's Avatar
Divide 282.4809363 by the l/100km value you see in the display.
So for example 6l/100km gives: 47.08015606 mpg
That'll give you some arithmetics to do during a boring drive
Steeph is offline
LPG conversion britsbest General Discussion (8G) 28 29th February 2012 12:55
UK conversion SPQRCivic General Discussion (8G) 5 19th March 2008 23:14
Help with EG6 K20 conversion gazrawly Previous Civics 1 6th May 2007 13:58
How many litres Velocity General Discussion (8G) 11 5th December 2006 16:10
LPG Conversion? Bardley General Discussion (8G) 14 3rd December 2006 18:13
