Warnings warning light on display..? - Civinfo
post #1 of 12 (permalink) Old 28th August 2008, 22:33 Thread Starter
Al Stirling's Avatar
Hi folks.. advice needed please..
Does anyone know what the bright yellow (!) means on the digital display infront of me on start up of my 2.2 sport..? It only comes on and pings after start up now and again and goes out and returns to normal display after about a second or two.
It's in the same place the large refuel warning light comes on.
My Civic is running like a dream..
Any ideas..?
Civic's got 28k on the clock now..
Al Stirling is offline
post #2 of 12 (permalink) Old 28th August 2008, 23:23
Coldwarkid's Avatar
Put your seat belt on.
Coldwarkid is offline
post #3 of 12 (permalink) Old 28th August 2008, 23:41
Is the VSA switched off?
Wheelchair is offline
post #4 of 12 (permalink) Old 28th August 2008, 23:45
HappyMan's Avatar
Car: 2016 Ford Kuga Titanium
The (!) is the warning signal indicator. So if you haven't put on your seatbelt it will stay there until you put it on. If the boot isn't closed properly it's stays on to draw you attention to the problem. Generally the centre of the speedo shows the problem by scrolling through the menu's
HappyMan is offline
post #5 of 12 (permalink) Old 29th August 2008, 00:40
Rousey's Avatar
if you read the user manual there is a list of all the warning signals im sure you will find your problem
Rousey is offline
post #6 of 12 (permalink) Old 29th August 2008, 08:33
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
When you see the '!' symbol press the ! button on the steering wheel and it will inform you what is wrong in the center of the rev counter
NoNumpty is offline
post #7 of 12 (permalink) Old 29th August 2008, 08:37
mrh339's Avatar
Beat me to it!!
mrh339 is offline
post #8 of 12 (permalink) Old 29th August 2008, 09:18
Civic gone, not forgotten
alanwalne's Avatar
Car: Pug 4007, 308CC, Clio dci
Any ideas..?
To me it sounds like the oil is getting close to the lower limit. Perhaps the oil is not low enough to activate the warning permanently. I would check it ASAP.
As the warning goes off, it does not sound like the seat belt or open door warning as that warning would stay active until the 'problem' changes.
alanwalne is offline
post #9 of 12 (permalink) Old 29th August 2008, 15:37
Bog
Bog's Avatar
Car: 2016 CR-V 1.6 160 4WD
The light comes on and goes off at start as a self test!
Bog is offline
post #10 of 12 (permalink) Old 29th August 2008, 17:32
GerryJ's Avatar
Any ideas..?
I get this alot, but I always get a 'Check System' warning on at the same time. Had dealer check the fault log, but nothing there. Another unexplained problem?
GerryJ is offline
post #11 of 12 (permalink) Old 29th August 2008, 21:46 Thread Starter
Hi Folks ***** for all the replies...
Yea I've checked the owners manual after posting the thread.. DOP..!!
It's needing the handbrake replaced anyway just not had time to get it into the stealers yet. It might have something to do with that going by the manual.
Cheers..!!
post #12 of 12 (permalink) Old 30th August 2008, 23:45
The fat controller
fatboy-pete's Avatar
Car: 2018 Civic 1.5 prestige
Cheers..!!
Yes it sounds like the handbrake warning. If you drive away with the handbrake on you get a big ! in the middle.
But most lights do come on at start up as a self test and also to warn of a bulb blown in the particular area.
fatboy-pete is offline
Oil Oil Warning Light angie4m Engines and Transmission (8G) 61 29th July 2009 08:02
Oil Oil warning light thespacecowboy Engines and Transmission (8G) 4 1st September 2008 19:45
Oil Oil warning light Speedy471 Engines and Transmission (8G) 15 7th April 2008 21:53
Warnings warning light!!!! rev100100100 Electronics (8G) 3 9th February 2008 21:06
Oil Oil Warning Light NathanB Engines and Transmission (8G) 1 1st January 2008 18:34
