Electrics 2.2cdti rear electric window issue - Civinfo
post #1 of 10 (permalink) Old 21st March 2015, 23:09 Thread Starter
I've discovered the passenger side rear electric window isn't working on my 2.2cdti with either the switch on the drivers armrest or the passenger rear switch
Any ideas what it could be or where to start
Jerry2.2cdti is offline
post #2 of 10 (permalink) Old 21st March 2015, 23:28
Civinfo Wind Up Merchant
Scotty182's Avatar
Car: V'9 STI
Send a message via MSN to Scotty182
Start with the window reset:
Electric window reset procedure - Civinfo Wiki
If that still doesn't work i'd hazard a guess the motors kicked it, If all other windows work and neither control will move the window.
You can also remove the door trim and then the switch module (both drivers and the non-working one) and check the switches are both powered; with a multimeter probe. (the switch module box comes apart to the pcb.)
Scotty182 is offline
post #3 of 10 (permalink) Old 22nd March 2015, 12:05 Thread Starter
Is there any way to switch the switches around just to power the window that won't go down just to allow me to fit wind deflectors ?
post #4 of 10 (permalink) Old 22nd March 2015, 12:25
Scotty182's Avatar
Car: V'9 STI
Depends if the motors knackered or it's a switch issue.
You could remove both rear door switches and see if the the connectors fit, i've not compared the two connectors to be honest; so im not so sure.
post #5 of 10 (permalink) Old 22nd March 2015, 12:27 Thread Starter
Do you mean from the drivers armrest switches ?
post #6 of 10 (permalink) Old 22nd March 2015, 12:40
Scotty182's Avatar
Car: V'9 STI
Sorry no; i mean remove both rear door trims and remove the switch housings and see if the connector from the other side fits the wiring on your "broken" side.
I couldn't tell you if the connectors fit or not but it may be worth a shot.
post #7 of 10 (permalink) Old 22nd March 2015, 12:50 Thread Starter
Cheers mate that makes sense but as it works from neither front drivers switch or rear passenger switch I'm assuming your right with the motor being goosed
post #8 of 10 (permalink) Old 22nd March 2015, 13:08
Scotty182's Avatar
Car: V'9 STI
I would have thought so from what you've said mate.
If it's the TeamHeko deflectors you can get those in without the window being down if you're careful im sure, wont be ideal and a bit tight, but should go.
post #9 of 10 (permalink) Old 22nd March 2015, 13:35 Thread Starter
Yep that's the ones I've got might give it a go
post #10 of 10 (permalink) Old 22nd March 2015, 13:47 Thread Starter
Worked a treat mate cheers for your help
2000 civic electric window issue. mikesmith181 Previous Civics 1 3rd April 2014 07:09
Electrics Electric Wing Mirror Issue... akingcool Electronics (8G) 2 5th March 2013 14:18
Electric Window Problems Penners Honda CR-V 4 27th December 2011 23:18
Electrics Electric wing mirror issue azztech30 Electronics (8G) 11 1st September 2011 17:56
