AC/Heater 2007 Civic AC Problem MICU Replacement - Civinfo
post #1 of 2 (permalink) Old 16th August 2016, 18:40 Thread Starter
The compressor has been replaced as has the pressure switch and under hood fuse box. All fuses and relays are good but the Civic diagnostics manual points to a bad MICU. Problem is this is something that requires an HDS to re-flash the MICU to the ignition keys. I can replace the MICU but from what I understand the car won't start until the re-flash is done. Is my understanding correct or is there a way I can replace the MICU and then get the re-flash done later or is there another alternative. My guess is Honda will charge max for the part plus labor and I am guessing this will cost $500+.
jmerritt is offline
post #2 of 2 (permalink) Old 16th August 2016, 22:10
ante00's Avatar
Car: 2007 1.8 Sport MT (Vivid)
Send a message via MSN to ante00
Only reflashing micu thru HDS is possible. Try tacho swap for someone to test because if tacho isn't ok compressor won't kick is. Hadnit on mine
Sent from my GT-I9300 using Tapatalk
ante00 is offline
Flat battery replacing fuse box inside box (micu problem ) ap1927 Bugs, faults and irritations (8G) 2 10th February 2013 13:31
Flat battery honda civic 07 possible fuse box micu recall ap1927 Bugs, faults and irritations (8G) 3 4th February 2013 13:14
Electrics changing my 2002 Civic MICU casperove Electronics (8G) 1 21st June 2011 12:33
Electrics Civic 2002 MICU location image casperove Electronics (8G) 3 15th June 2011 16:41
Electrics 07 Type-R -- Can't disable alarm! MICU Problem? charsiu Bugs, faults and irritations (8G) 4 18th April 2011 12:14
