Electrics Ecu - Civinfo
 1Likes
  • 1 Post By Jon_G
post #1 of 3 (permalink) Old 22nd October 2016, 10:14 Thread Starter
Ecu
Hello, can somedy help me to read ecu codes? https://youtu.be/1HjdIq4tiHo
Uplif is offline
post #2 of 3 (permalink) Old 22nd October 2016, 11:29
jaxckhan's Avatar
hi there f your scanner is just giving you codes, you can just google the codes, and they will come up
jaxckhan is offline
post #3 of 3 (permalink) Old 22nd October 2016, 11:57
Bye bye Honda...
Jon_G's Avatar
Car: Volvo V60 VEA D4 (181)
If you mean the engine ECU, then an OBD2 scanner connected to the vehicle OBD2 diagnostic port (somewhere near the drivers legs) will read the powertrain codes, some of which will be generic (so most scanners will provide an explanation) but some of which will be Honda-specific (so you'll need to search this forum for an explanation). For VSA/ABS issues then a dedicated diagnostic reader is required (HDS or Snap-On types), but this trick will read body codes... http://www.civinfo.com/forum/how/704...ial-tools.html
Have you actually got a problem?
Farqui likes this.
Jon_G is offline
Faults Ecu help staffyjim Engines and Transmission (8G) 1 27th January 2014 12:12
Tech ECU - What does it do exactly Cush Engines and Transmission (8G) 1 7th September 2009 18:25
Ecu jag943 Type-R 1 19th August 2008 17:28
