Electrics Code reader - Civinfo
 1Likes
  • 1 Post By Adamsnake
post #1 of 10 (permalink) Old 14th December 2016, 02:46 Thread Starter
Fkkirk's Avatar
Code reader
Fk2 2007 does anybody know where I can get a code reader from on eBay is it eobd2 !! I need one cheers
Sent from my Robin using Tapatalk
Fkkirk is offline
post #2 of 10 (permalink) Old 14th December 2016, 13:36
Car: Audi A3 2.0 TDI 2015
Adamsnake is offline
Thanks to Adamsnake from:
post #3 of 10 (permalink) Old 14th December 2016, 13:43 Thread Starter
Fkkirk's Avatar
Cheers adamsnake just bought that now 😀😀
Fkkirk is offline
post #4 of 10 (permalink) Old 14th December 2016, 13:45
Car: 2007 2.2 i-ctdi Black
I got one on ebay(pretty much the same as above) for a fiver works a treat with the torque pro app, which codes do you intend to read as most don't read ABS/VSA/SRS. (which is what i need now, but they're significantly more expensive than a fiver.
RIP Accord hello civic!! is offline
post #5 of 10 (permalink) Old 14th December 2016, 13:53 Thread Starter
Fkkirk's Avatar
Mainly engine . But my abs,vsa keeps popping up doing my nut in been like this a wk now . Keep feeling juddering through my peddle . Think it's the abs sensor is gone but if it was the sensor I wouldn't be able to feel the juddering would I???!
Fkkirk is offline
post #6 of 10 (permalink) Old 14th December 2016, 13:58
Vaikis's Avatar
I doubt that abs sensor will give you any juddering through peddle. Maybe it's abs pump ?
Vaikis is offline
post #7 of 10 (permalink) Old 14th December 2016, 13:59 Thread Starter
Fkkirk's Avatar
Better hope not there 's
Fkkirk is offline
post #8 of 10 (permalink) Old 14th December 2016, 14:37
mine is similar its not intermittent tho, the lights came on and stayed on since, theres a high pitched squeak when things heat up so thinking it could be the bearing gone bad and has caused the abs light to come on. when i break hard the peddle judders when the abs should be activating but the wheels still lock but not sure if its just the fronts locking or all 4.
Really wish i had my old 1999 1.8i vtec accord back, built proof car that. Ran it for hundreds of miles on roughly 2 pints of oil and it didnt bother it at all.
post #9 of 10 (permalink) Old 15th December 2016, 21:37 Thread Starter
Fkkirk's Avatar
These came up on the dash this evening asked my local garage to scan it it costs 46 to scan it and it may only be a abs ring or sensor nothing else...!
Fkkirk is offline
post #10 of 10 (permalink) Old 16th December 2016, 10:31 Thread Starter
Fkkirk's Avatar
The hand brake symbol went out this morning well I topped up the brake fluid was 5mm from the max point don't know if that'd make a difference.? But the VSA and ABS light is still on its wracking my brain. So going to have a over view on it on Sunday see what's what. 😐
Fkkirk is offline
Electrics Which Code Reader?????? hondacivicnut Electronics (8G) 16 26th November 2017 15:00
code reader bigrobbo General Discussion (8G) 4 27th June 2013 08:45
Warnings Which code reader mylesjohn Electronics (8G) 4 30th December 2012 17:23
Servicing What Code Reader DO You Use? jonathan.dixon Buying, Dealers and Servicing 1 10th February 2011 01:38
Tech Code Reader Paul542 Engines and Transmission (8G) 2 17th July 2009 23:49
