Electrics No warning lights coming on in dash - Civinfo
 6Likes
  • 1 Post By scaramanga
  • 4 Post By spkejones
post #1 of 14 (permalink) Old 13th February 2017, 22:14 Thread Starter
Car: 2009 2.2 5-door, Silver
Hi All,
Well this evening I decided to change reversing bulbs for LED type. Left ignition on and car in reverse so I could make sure polarity of the LED bulbs was correct.
Pulled bulb out, pushed LED one in which flashed and went out so I tried 2nd one which didnt light so I put original bulb in which also did not light then noticed that the other side reversing light had gone out and assumed the fuse had blown.
Gave up and got into drive home, put key in, welcome lights came on, turned key and no warning lights came on - zilch! Pressed start, turned over lovely but not firing. Got nothing working that is normally associated with the "run" position of the key.
Called AA, 2 hours later a 3rd party garage turned up, 10 miutes checking fuses using his phone torch to see what he was doing and declared it's a "broken relay" wrote me up and buggered off. Luckily was still at work so could take a van home.
I'm conviced it's a blown fuse but haven't had time to check. I'm open to suggestions on which one, 36 internal comes to mind.
Any ideas gratefully received.
Cheers
spkejones is offline
post #2 of 14 (permalink) Old 13th February 2017, 22:22
Jamesoxborrow's Avatar
Open your driver door and remove the triangular panel which forms the side of your dash. Underneath this panel is a black round switch. Push it in very hard then try starting your engine again.
In the Honda manual it's called something like a fuel pump cut off switch or inertia switch.
Try this and let us know.
Sent from my SM-G935F using Tapatalk
Jamesoxborrow is offline
post #3 of 14 (permalink) Old 13th February 2017, 22:25
scaramanga's Avatar
Car: 2015 white orchid 1.6 dtec
is this the same as the other threads where leds fitted and car wont start ??
think theres a fuse that pops
scaramanga is offline
post #4 of 14 (permalink) Old 13th February 2017, 22:26 Thread Starter
Thanks,
Will try in the morning.
Cheers
post #5 of 14 (permalink) Old 13th February 2017, 22:28
I imagine the AA must have checked the fuses as it's the first thing that came to mind. But the fuel cut off switch is jumpy when people have put on footwell lights, hence I wonder if it's the same if u have a short in other places.
I had te exact same problem last weekend after putting in the footwell lights. Luckily my AA chap worked for Honda and after checking the fuses, battery, starter etc, went strait for the fuel cut off and it started strait up.
post #6 of 14 (permalink) Old 13th February 2017, 22:31
scaramanga's Avatar
try this
http://www.civinfo.com/forum/general...ed-solved.html
fuse 10 in interior fuse box
as for aa rac and such like theres not many that are very good most of them just want to hook up and tow to garage/home
the fuel cut off is usually triggered by a bang or accident
spkejones likes this.
post #7 of 14 (permalink) Old 13th February 2017, 22:41
Originally Posted by scaramanga View Post
try this
I agree your absolutely right. But after I put my foot well lights in, my car would turn over beautifully but not start. There was no bangs or accidents, it had been parked on my driveway way where I had left it working perfectly before I started the install. Yet the fuel cut off still activated after I had tinkered with the electrics a little. Strange one.
post #8 of 14 (permalink) Old 13th February 2017, 22:46 Thread Starter
Thanks, Will check the fuse properly in the morning.
The lisiting in the Owners Manual leaves a lot to be desired!
The "technician" that rocked up was tapping a relay in the fusebox in the engine bay and his oppo was watching the dash who say lights were flashing hence their "its a broken relay" diagnoses... Didn't occur to them that they were actually making the relay cotacts to make a connection onstead of finding the route of the problem
post #9 of 14 (permalink) Old 13th February 2017, 23:14
jaxckhan's Avatar
that fuel cut off switch is over sensitive in my opinion, same thing happend to me when installing foot well lights, and coming home module
jaxckhan is offline
post #10 of 14 (permalink) Old 13th February 2017, 23:17
The AA chap who showed me how to fix mine and luckily used to work for Honda, said that it's also supposed to cut out in flooding/waterlogged conditions. So maybe it's very susceptible to shorts aswell.
post #11 of 14 (permalink) Old 14th February 2017, 12:14
Any luck?
post #12 of 14 (permalink) Old 14th February 2017, 15:09 Thread Starter
Hi Guys,
Went and checked fuse No. 10 (7.5A) on the inside fusebox as suggested. Found it blown, replaced it, turned key and Bobs your uncle, dash indicators came on and engine fired up.
Have got DWL on but not surprised, just needs to be reset.
Thinking about it now, the fuse is marked "Meter" probably means instruments which sort of makes sense.
Thanks all for your input
Kev
PS was going to have a bit of a moan at the AA about the garage they sent out but decided not to as they are one of my customers lol
post #13 of 14 (permalink) Old 14th February 2017, 18:11
scaramanga's Avatar
the important thing is with the help of this great forum you are back on the road with a 10p fuse
post #14 of 14 (permalink) Old 14th February 2017, 22:01 Thread Starter
Not quite 10p, I charge a little more for them but not much lol
Indications "Check System" Warning lights on dash Beck Engines and Transmission (8G) 8 16th August 2015 14:28
Tyre Pressure Tyre warning coming on a lot lately Vyse Wheels, Tyres, Suspension and Brakes (8G) 9 24th June 2015 06:00
Road Noise Rattle coming from inside the dash fearLess Bugs, faults and irritations (8G) 3 27th April 2013 07:28
Brakes Warning Lights on Dash ? borse2010 Wheels, Tyres, Suspension and Brakes (8G) 2 17th May 2012 13:23
Warnings Dash Board Warning Lights cagster Electronics (8G) 3 20th April 2012 16:12
