Cruise Erratic Cruise Control - Civinfo
post #1 of 12 (permalink) Old 20th January 2010, 14:53 Thread Starter
I tried to engage my CC last night, cruising along around 40MPH, pressed the switch on the steering wheel, light comes on the dash to say it's active. Then pressed the set button and the CC simply will not set at any speed.
Thoughts/ideas what to check?
Chilled is offline
post #2 of 12 (permalink) Old 20th January 2010, 14:57
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
Take your foot completely off the clutch pedal
I had the very same problem http://www.civinfo.com/forum/electro...e-control.html
NoNumpty is offline
post #3 of 12 (permalink) Old 20th January 2010, 15:00 Thread Starter
Hmmm...will double check/try that on my way home this evening...cheers
Chilled is offline
post #4 of 12 (permalink) Old 20th January 2010, 15:01
doofus4000's Avatar
Chiiled, my cruise control is the same, stopped working after I changed the intake on my car for some reason (but I wont be telling the garage that lol), car is due in for a service now anyday so will get it looked at then. I think it may be just the case of turning off an error code type thing logged in the cars computer somewhere to get it working again.
doofus4000 is offline
post #5 of 12 (permalink) Old 20th January 2010, 15:20
CS1.6 Pro
cache's Avatar
Car: 2009 Champ White R GT
i find setting the speed with decellerate more effective than pressing the accelerate to set it, try that
cache is offline
post #6 of 12 (permalink) Old 20th January 2010, 15:40
NoNumpty's Avatar
de-accelerate sets it to current speed if not already set
accelerate reset it to a previous speed if CC has been previously cancelled
NoNumpty is offline
post #7 of 12 (permalink) Old 20th January 2010, 16:15
J. Derek Riddell's Avatar
Sure it was at 40 mph ? - at low speeds, you can't set CC at all ...
J. Derek Riddell is offline
post #8 of 12 (permalink) Old 20th January 2010, 17:08
jameseh's Avatar
Car: Orchid White GG6 Si
You can set CC at 30mph or over. Does the Cruise light come on along with Cruise Main after you try to set it?
jameseh is offline
post #9 of 12 (permalink) Old 20th January 2010, 17:10
Heavy Footed!
HenryTheHonda's Avatar
Car: 2012 Astra GTC SRi
I believe its around 29MPH and higher it can be set.... Just under the threshold for the speed cameras!!!
HenryTheHonda is offline
post #10 of 12 (permalink) Old 20th January 2010, 22:47 Thread Starter
You can't set the CC anything below 28MPH...and, as NoNumpty suggested above, it really does help to completely remove your foot from the clutch pedal :/ Transpires even "looking" at my clutch pedal is enough to cancel the CC.
Drove to Cardiff this evening to collect a laser and some other bobs and bits, sure enough, left foot on the rest, turn CC on, set speed, off she went like a dream!
Cheers
Chilled is offline
post #11 of 12 (permalink) Old 21st January 2010, 09:18
NoNumpty's Avatar
Cool
NoNumpty is offline
post #12 of 12 (permalink) Old 21st January 2010, 13:19
Smeepers's Avatar
Car: 2013 Black 2.2 ES Dynamic
I have an issue too but but found out what it was. My clutch pedal doesnt always come right up and after lifting the clutch with my foot by an inch, I could then set the CC. Im due a service so will mention it then.
Smeepers is offline
Cruise Cruise Control Spaceman Electronics (8G) 4 7th April 2009 20:00
MPG Do you get better MPG when using cruise control? RickHondaR Engines and Transmission (8G) 14 26th February 2009 18:11
Cruise Cruise Control shieldy2k7 Electronics (8G) 6 1st July 2008 09:58
Electrics No Cruise control Diesel Virgin Bugs, faults and irritations (8G) 22 23rd December 2007 23:08
Engine Cruise control angie4m Bugs, faults and irritations (8G) 36 1st November 2007 16:17
