Speedo Shows ~6km/h too little? - Civinfo
 5Likes
  • 1 Post By Farqui
  • 1 Post By Kremmen
  • 1 Post By M8TJT
  • 1 Post By nturnb
  • 1 Post By nturnb
post #1 of 18 (permalink) Old 5th February 2019, 08:32 Thread Starter
Chris-Mario Portale's Avatar
Car: 2006 FK3 Hatch, Galaxy Grey
Hi!
2006 Civic FK3 2.2CDTI Hatchback showing too little on the speedo; We have to drive in ~56km/h in the 50-zone to go 50km/h.
Is there a way to adjust this anywhere? I haven't seen anything in the menu about this, only the +/- 6C on the outside temperature adjustment :b
Kind regards
// Chris-Mario
Chris-Mario Portale is offline
post #2 of 18 (permalink) Old 5th February 2019, 08:58
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
All vehicle speedo's should over read, not under read vs the actual speed of the vehicle.
Are you running stock wheels and tyres?
Das likes this.
Farqui is offline
post #3 of 18 (permalink) Old 5th February 2019, 12:22
Haltamer's Avatar
Sounds like it is regular overreading; The easiest way to get an idea of true speed is with a GPS.
If you drive at a steady speed, see what the GPS gives you and you can work out a slight offset.
An over read is normal, as it's not permitted for the speedo to under read at all, manufacturers tend to err on the safe side and under read. with option wheels etc. this can be amplified.
Unfortunately, there isn't really an option for getting the speedometer calibrated - I did have a look in the UK to see if I could get the speedometer calibrated similarly to Police speedometers, but there isn't a service accessible to the general public that I've found.
Haltamer is offline
post #4 of 18 (permalink) Old 5th February 2019, 12:31
Car: MY13 1.8 EX Auto
The pre-facelift 8G Civics did over read by quite a margin. The post-facelift were better.
Das likes this.
Kremmen is offline
post #5 of 18 (permalink) Old 5th February 2019, 14:19
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
Put smaller wheels on it?
M8TJT is offline
post #6 of 18 (permalink) Old 5th February 2019, 18:14
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
How bad were the pre faces? My facelift reads 3MPH over against a GPS reading.
Das is offline
post #7 of 18 (permalink) Old 5th February 2019, 18:36
I think it was 10%
One answer is to fit and configure a 'speedo healer'
Pottsy did post about that ages ago - if you search.
Kremmen is offline
post #8 of 18 (permalink) Old 5th February 2019, 22:58
M8TJT's Avatar
I think it was 10%
That's about the error on OP's car. Normal?
M8TJT is offline
post #9 of 18 (permalink) Old 6th February 2019, 05:24
That was how the 2006 - 2008 Civics were configured.
Kremmen is offline
post #10 of 18 (permalink) Old 12th February 2019, 21:15 Thread Starter
Thank you all for your answers
I've checked vs. GPS, and in 50km/h (car speedo) I drive 56km/h steady (on the GPS)
The wheels on now are standard winter-rims/tyres; 205/50-16 (I think..? Or maybe around 205/55-16)
- but that's besides the point; Yes, they are the standard rated winter-size atleast. I drove it home on summer-rims/tyres when I got it and it showed the same on the 17" standards/OEMs
So it's kinda odd :b
But, I see the point of manufacturers "safeing" themselves against tons of lawsuits because "well my car said I only did x-amount of speed not my fault"
If it's normal and not to worry about, then alright
Thanks for the replies. Y'all amazing on here <3
post #11 of 18 (permalink) Old 12th February 2019, 23:14
M8TJT's Avatar
If the car speedo reads less than the GPS speed, that's deffo wrong.
The car speedo, should read a bit higher than your GPS speed so that your actual speed (GPS) is slower than what your speedo says.
Kremmen likes this.
M8TJT is offline
post #12 of 18 (permalink) Old 13th February 2019, 09:25
Fergiem123's Avatar
My Type R also appears to read approx 3mph over.
Not sure if a 59 plate is facelift or not?
Fergiem123 is offline
post #13 of 18 (permalink) Old 13th February 2019, 09:43
3mph for the MY09 facelift was normal. Honda did improve it.
Facelift has the sockets in the centre console, USB, etc.
Kremmen is offline
Thanks to Kremmen from:
post #14 of 18 (permalink) Old 13th February 2019, 10:20
Fergiem123's Avatar
Mine must’ve been an early 09 build then registered in October.
The reason I installed the double din was because it had no USB sockets like my old FN1
post #15 of 18 (permalink) Old 13th February 2019, 11:18
Ex-Pat Geordie!
nturnb's Avatar
Car: 2015 Civic S Navi I-dtec
My old 2.2 pre-facelift at 61mph on the dash was 56mph on the GPS. I know all cars over read but does this mean that they also add too many miles as well? Maybe there's a boffin out there who can answer. I remember watching a documentary on the Manchester Constabulary traffic workshop and the first thing the do when preparing a police car is to calibrate the speedo to that it reads the actual, so plod's correct
Fergiem123 likes this.
nturnb is offline
post #16 of 18 (permalink) Old 13th February 2019, 11:21
We had a Honda tech on, years ago, who assured us that whilst the speedo was a tad inaccurate, due to legislation, the mileometer was absolutely correct.
Kremmen is offline
post #17 of 18 (permalink) Old 13th February 2019, 15:16
M8TJT's Avatar
No they don't. It seems that the OP's speedo under reads.
M8TJT is offline
post #18 of 18 (permalink) Old 13th February 2019, 15:31
Ex-Pat Geordie!
nturnb's Avatar
Ok, I stand corrected
M8TJT likes this.
nturnb is offline
Other Dashboard screen only shows speed alert majkomaj Electronics (8G) 5 29th December 2017 09:47
Car Shows? eroll_fn2 Any non Civic chat here please! 4 26th January 2017 12:12
Engine light shows after changing oil engine nd gear saholan General Discussion (8G) 9 16th October 2016 05:56
Computer Speedo and trip shows 0, AVG not calculated maigadi Electronics (8G) 5 21st September 2015 19:14
what car shows to goto this year? DervBurner Any non Civic chat here please! 2 9th January 2013 18:02
