776 quote for A/C clutch?! - Civinfo
 6Likes
  • 3 Post By cheekee
  • 1 Post By cavalrystu
  • 1 Post By hondacivicnut
  • 1 Post By M8TJT
post #1 of 11 (permalink) Old 25th March 2019, 22:28 Thread Starter
Car: '07 1.8 I-VTEC I-Shift SE 5D
Hi all,
Firstly, moderators forgive me if I've not posted correctly, happy to adjust.
Just come back from my 2nd diagnostic on my Air con on my 8th gen Fn2 1.8 SE ishift Civic. I thought this was a test to blacklight check any leaks from dye left from previous regas. My aircon died 2 days after that regas, 5 months ago. The exact wording from the Honda dealer is: "ac clutch looks to be overheated, advise replacing clutch, electro magnet and thermal cut. Had old style relay, advise replacing also, quote 776.“
Woah.
So, the relay I've seen on part websites, 20, clutch 40, I cannot find anything about a electro magnet or thermal cut...?
Am I being conned? Why was there no mention of a leak. I understand the ac was trying to run on empty and overheated. I still don't know the source of the leak. Meh.
Please could someone advise. No idea. Probably worth taking to a small independent mechanic for a 2nd opinion? I understand the compressor would be an expensive replacement but not the parts mentioned...
Thanks in advance... 😁
JoeChamberlain is online now
post #2 of 11 (permalink) Old 25th March 2019, 23:48
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Definitely get a second opinion as from what you have said, their quote is too much.
I could understand if the price involved a new compressor.
Farqui is offline
post #3 of 11 (permalink) Old 26th March 2019, 04:02
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
Vauxhall dealers were quoting around 400 for A/C Clutch on Vectra C's so yes sounds possible from Honda for similar.
Das is offline
post #4 of 11 (permalink) Old 26th March 2019, 08:17
cheekee's Avatar
Car: 2011 Type S GT-T
I got a whole new oem quality compressor for 170 from autodoc and got it fitted for about 100 including regass.
RA108, Farqui and Das like this.
cheekee is offline
post #5 of 11 (permalink) Old 26th March 2019, 11:09 Thread Starter
Awesome, just found the part online. From what I've read it seems easier and recommended to just replace the compressor. Especially if I find there's damage to the current one if I just got the clutch changed. Unless anyone else has further suggestions I'll check with some local mechanics if they'll do it and I'll source the compressor.
Thanks.
post #6 of 11 (permalink) Old 28th March 2019, 11:06
So, you've swapped the Relay?
It's 5 on ebay... worth a try first, to be SURE it's the compressor.
Howard Jump likes this.
cavalrystu is offline
post #7 of 11 (permalink) Old 2nd July 2019, 08:49
Bought?
sophiaedward64 is offline
post #8 of 11 (permalink) Old 2nd July 2019, 20:11
Clutch pedal guru
hondacivicnut's Avatar
Take your car to an AC specialist NOT HONDA.
RA108 likes this.
hondacivicnut is offline
post #9 of 11 (permalink) Old 12th July 2019, 20:33
May I ask which one did you get? Need to buy one but struggling to decide.
morbid86 is offline
post #10 of 11 (permalink) Old 13th July 2019, 05:06
Car: 2008 1.8 GT Type S
An aircon specialist will charge a lot less. One near me charges 70 to fix a slow leak including a full system regas. He charges 250 to fix any serious leak / issue. 776 is just rape!
RA108 is offline
post #11 of 11 (permalink) Old 13th July 2019, 08:25
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
Are you 100% certain that you need a new compressor and it's not just the clutch that's slipping and needs shimming.
jpbroad1970 likes this.
M8TJT is offline
Brake and clutch flush. Different feeling to pedals? Yandex General Discussion (8G) 6 10th August 2019 15:53
Clutch 2.2 CDTI clutch options/questions EnragedBeard Engines and Transmission (8G) 21 24th November 2015 19:58
Performance Performance drop since clutch replacement Jediknight Engines and Transmission (8G) 10 2nd November 2011 16:58
