Hi guys, I've installed a rear view mirror LCD dash camera with reverse camera. We're really struggling on how to feed the wire from the rear of the car, through the boot to the reverse light. We are trying to feed the cable through the rubber wiring loom boot cover.
Is there an easier way of doing this?
It should go through with a bit of washing up liquid as a lubricant. Or tape it to a bit of stiffish wire and poke that through. I've done it that way on three of my cars and two of SWMBO. Simples.
I ran the cable along the top of the doors (5 door) along the edge of the headlining. Getting through the tailgate is the most tricky part for me, but some wd40 in the rubber boot meant I could get the cable through without cutting off the rca plug from the lead. Running across the top of the windscreen (under the headlining) to the mirror should be fairly easy.
That doesn't even pass the 'so what' test. And WUL is likely to be considerably kinder to the rubber than the solvents and other stuff in WD40.
From the can
Personally, I wouldn't put that anywhere near rubber or similar stuff. It's designed for use on metal. (Apart from that, it is not very slippery):grin2:
Related Threads
2006+ Honda Civic Forum
2.5M posts
103.9K members
Since 2006
