AC/Heater AC fan interval - Civinfo
post #1 of 8 (permalink) Old 8th July 2010, 01:54 Thread Starter
Car: 2006 1.4 5D, NHB
AC fan interval
I have tried to search it, but didnt find-does it sound right for AC fan: 40 sec ON, 5 sec OFF, 40 sec ON, 5 sec OFF aso...it has always bothered me that it turns on and off so often and i have never had a car with AC before soo...yeh....
Kutsikas15 is offline
post #2 of 8 (permalink) Old 8th July 2010, 14:50 Thread Starter
anyone?!?
post #3 of 8 (permalink) Old 8th July 2010, 16:08
Car: Jag XF 3.0
IIRC it varies according to the amount of work it has to do. Try testing it at night to see if the cycle changes.
Pottsy is offline
post #4 of 8 (permalink) Old 8th July 2010, 16:48 Thread Starter
that cycle was at night-outside temp was 20 C and climate control was set to 23 C. And i did one other test: i set climate control to MAX temp and turned AC OFF-nice hot air came out. Now i turned AC to AUTO with same temp setting and air became a lot cooler... why it even starts AC with max temp?
post #5 of 8 (permalink) Old 8th July 2010, 21:30
Car: Jag XF 3.0
The AC will run nearly all the time to dry the air. So it is cooled and dried by the AC and then warmed up again by the heater matrix. It makes it more comfortable inside, and stops the car from misting up.
So long as it is cycling, and the air can be cooled, then it sounds like it is working fine. Just set it to Auto and something like 20C, and all should be fine.
Pottsy is offline
Thanks to Pottsy from:
post #6 of 8 (permalink) Old 9th July 2010, 14:37
Nick7's Avatar
AC compressor works in this manner: in the cabin behind the cooling elemnt is thermostat.
When temperature it reads is above some 6C it turns on compressor.
When temperature drops below some 2C it turns off compressor.
And so.. on.. off..etc..
PS: Compressor on = vent on, compressor off = vent off
Stated temperatures are just an example, as proper ones might vary a bit, but this is how it works.
Nick7 is offline
Thanks to Nick7 from:
post #7 of 8 (permalink) Old 11th July 2010, 19:29
john87's Avatar
Car: Golf GTI
The fans run at high speed for a much longer interval if the air recirc feature is 'off' on my car, and about 10 secs on, 20 secs off when the recirc feature is 'on'
john87 is offline
post #8 of 8 (permalink) Old 12th July 2010, 10:16
Nick7's Avatar
And again, this is normal, because generally outside air temperature during summer is higher than one inside car.
So, to cool outside air more cooling is needed and fan/compressor will need to work more.
Nick7 is offline
Oil Change it more often, rather than at the service interval Jeroen1000 Engines and Transmission (8G) 20 28th May 2015 14:45
cam belt interval kentrojan1 Previous Civics 1 24th December 2008 08:52
