Mounts Not So Sticky Situation...Help! - Civinfo
post #1 of 14 (permalink) Old 22nd July 2010, 17:12 Thread Starter
My other woman is my CTR
antmaz's Avatar
Car: '59 CTR GT satnav/hft
Hey all
Some of you may know that I have the Mugen Assist meters fitted in my car. They are great except for the fact that the control box keeps falling off! I have tried many adhesive pads but all have failed, usually due to the heat in the cabin, but also in colder weather!
Tried and failed:
- "Velcro" extra strong pads
- "no more nails" outdoor adhesive pads (claims to work from -20C to +50C)
- B&Q adhesive foam strips
- double-sided tape with foam strips.
Something with a foam back is required as the surface if not perfectly flat and so needs padding out.
Does anyone have any suggestions?? I want something that will not leave any trace or damage in case I sell the car and sell the meters seperately.
Please see photos below for the box location.
Cheers
Ant
antmaz is offline
post #2 of 14 (permalink) Old 22nd July 2010, 18:01
pricey0819's Avatar
Send a message via MSN to pricey0819
worktop contact adhesive
pricey0819 is offline
post #3 of 14 (permalink) Old 22nd July 2010, 18:05 Thread Starter
antmaz's Avatar
Cheers, Will that be easily removed if I uninstall the device?
antmaz is offline
post #4 of 14 (permalink) Old 22nd July 2010, 18:08
3m double sided tape. Ganteed to hold it.
G-10 is offline
post #5 of 14 (permalink) Old 22nd July 2010, 18:42
Car: Type S 2.2
I cant see how you can get something thats strong enough to hold it there so it NEVER falls off but you can just pull it off easily when you want it to come off! And with out it leaving a trace?
Has it got be placed there? cant you put it underneath so yo can use something stronger then it doesn't matter it it leaves a mark.
But if it must be there you can always try siliconing it on, that will dry over night if you tape it up there, cos you can get lots of "silicon eaters" thats remove the silicone residue.
But i have no idea what these would do to your dash?
BillyMAC is offline
post #6 of 14 (permalink) Old 23rd July 2010, 16:23 Thread Starter
antmaz's Avatar
The Red Mugen prototype car has its box held on with white adhesive strips and it's never fallen off - I found this out at Goodwood, so it is possible. I know a good adhesive pad will leave a mark but it can be cleaned off, If I were to use a superglue/epoxy resin type thing then it would do permanent damage to the box and car. Also the box is a control unit so needs to be in a location that is easily accessible when driving... especially when I'm recording the data on track
cheers
antmaz is offline
post #7 of 14 (permalink) Old 23rd July 2010, 16:24 Thread Starter
antmaz's Avatar
Just got some... cheers for that, I think you're right it's sticking like flies to S***
antmaz is offline
post #8 of 14 (permalink) Old 24th July 2010, 22:36
Newt1's Avatar
Car: 2006 2.2 ES i-CTDI
I've used some of these for my carkit and phone holder. They're good and come off with a bit of picking. Other than that I can recommend 3M adhesive foam tape.
As always clean the area thoroughly with alcohol prior to sticking it really does make a big difference.
...the link
http://cgi.ebay.co.uk/EXTERIOR-STICK...9#ht_500wt_928
Newt1 is offline
post #9 of 14 (permalink) Old 24th July 2010, 23:28
elisonex's Avatar
Car: vivid blue 2.2 2006 ES
Mate use reg plate sticky pads the 6mm or 3mm ones you get them in halfords for under a fiver and they are really sticky, they hold my DTUK chip onto the car wing and its never fallen off. Worth a shot and they are a nice spongey foam as you require.
elisonex is offline
post #10 of 14 (permalink) Old 29th July 2010, 20:18
Resident Civinfo Nutter
NeoFlare's Avatar
Car: 2010 1.5 PWP CRZ-GT navi
Send a message via MSN to NeoFlare
Can I suggest something to mount it onto first?
As we all know how irritating the sticky stuff is to get rid off when removing anything
NeoFlare is offline
post #11 of 14 (permalink) Old 29th July 2010, 20:29 Thread Starter
antmaz's Avatar
Neo... such as? surely whatever I mount it to will need attaching to the plastic of the car?
antmaz is offline
post #12 of 14 (permalink) Old 29th July 2010, 20:32
NeoFlare's Avatar
Inivisible plastic...I'll get my coat
NeoFlare is offline
post #13 of 14 (permalink) Old 29th July 2010, 20:56 Thread Starter
antmaz's Avatar
haha... THanks for coming!
antmaz is offline
post #14 of 14 (permalink) Old 31st July 2010, 17:44
Mister B's Avatar
Car: 2010 Type S GT,Crystal black
Send a message via Skype™ to Mister B
This make all the difference between sticking and not !!
Mister B is offline
Brakes Sticky Shim Unknownsoldier Wheels, Tyres, Suspension and Brakes (8G) 5 15th May 2010 19:00
Tyre Other sticky pads gmp Wheels, Tyres, Suspension and Brakes (8G) 6 18th February 2010 13:41
in a nightmare situation and need advice on previous "scrapped" car Whitehart General Discussion (8G) 22 15th June 2009 23:36
Chuckle situation No 17 Kremmen Any non Civic chat here please! 3 8th October 2008 18:00
Unusual situation The Great Soprendo General Discussion (8G) 20 2nd February 2007 13:26
