Battery bosh - Civinfo
post #1 of 7 (permalink) Old 15th September 2010, 18:38 Thread Starter
bosh
hi can any one help my car keeps getting a flat battery if its left for a day or two. i have read the forum about the problem but honda said that my car dosent have a problem its the wrong type thats in the car. i am usung a bosh 640amp and i should have a 680amp battery. would this cause the battery to drain over night any help would be greatfull.
phoenix honda linwood
pcsandchips is offline
post #2 of 7 (permalink) Old 15th September 2010, 19:00
Foglight Covers FORSALE
gray52's Avatar
I'm using a lower amp battery in mine and it's 6 years old, as it was my original from my last car, long story but vie had this in since January and has been perfect, no problems. However I will be switching back to my original civic battery mid winter. As I only do short trips it hammers the battery with the bits on in the winter. I would just give it a good charge but not a fast charge. To get my green ball so I could see it took 9 days on my optimate charger. If that don't work then £100 for a new battery should do the trick, but you still need the check the drain or the new battery will be shot in a few weeks.
gray52 is offline
post #3 of 7 (permalink) Old 16th September 2010, 14:26 Thread Starter
thanks
i have taken my car to another honda garadge who also adviced on changing the battery for a honda one. so i bought one and have put it in so i will wait and see if i have the same fault again thanks for your reply mate..
post #4 of 7 (permalink) Old 16th September 2010, 15:26
there has been a recall of certain civic's for the flat battery my car was included it' not the battery it is a relay of some sort MICU i think that it's name itswitch's all the circuits on whilst the car is parked and locked
Milano.J is offline
post #5 of 7 (permalink) Old 16th September 2010, 19:44
gray52's Avatar
I hope you kept the original battery? You and then charge this up and have a spare forth winter should you need it.
gray52 is offline
post #6 of 7 (permalink) Old 17th September 2010, 09:01 Thread Starter
Battery
hi thanks i did say to them about the recals but they said that the fault was that the battery i had was only 640amps and not the recomended 680.amp i have since spoke to an auto electrician who said that the battery would not drain due to a difrence in amp's. and that some thing is draning it. honda at phoenix linwood wont take anything to do with the car until i have the correct battery fited. so i bought one from henry honda. and fitted this. so i will wait and see if it happens again which i am sure it will. henry honda were great yesterday and said that they dont belive it to be the amps but it should have a honda battery. that way they can do a test on the car should it fail again. for a small sum off money£60.00.
post #7 of 7 (permalink) Old 17th September 2010, 10:38
ashkeenon's Avatar
I had 3 flat batteries in one day & if you left the radio on for more than 5 mins it went flat got the micu sorted as MJ said and it now lasts for a good time now never had a flat battery since.
ashkeenon is offline
