Electrics Earthing kit problem - Civinfo
post #1 of 15 (permalink) Old 5th February 2011, 19:51 Thread Starter
parsco's Avatar
Car: 2007 CTR, NHB
I bought a earthing kit from LeeH (great item) because I was having trouble with dimming lights when I'm using electrics in the car (windows, AC, rear de-mister etc...).
I fitted the kit as per LeeH's instructions (also followed Loxy's How2) and I've given it a test and it's exactly the same . Have I missed a trick here? Did you do anything different Loxy?
It's driving me mad at the moment
parsco is offline
post #2 of 15 (permalink) Old 5th February 2011, 19:54
The Guru
k20_ed's Avatar
Car: 57 DPB CTR GT
I'd advise taking it to a dealer to have a proper look. I don't think the earthing kit us designed to sort issues like that, it's more engine blunt then anything
k20_ed is offline
post #3 of 15 (permalink) Old 5th February 2011, 20:05 Thread Starter
parsco's Avatar
Car: 2007 CTR, NHB
Quote taken from Loxy's thread:
"Earthing kits work by better grounding the negative electrical components on the car to reduce voltage fluctuations and avoid damage. An example can be seen when you turn the rear window/mirror heaters on or wind the windows down etc and you can see the lights dim ever so slightly."
This is the exact same problem I am getting and want to know if Loxy has cured it by fitting the earthing kit?
parsco is offline
post #4 of 15 (permalink) Old 5th February 2011, 20:45
higham's Avatar
Car: 57 CTR GT, NHB
gonna say you got more of a problem than just wires all you can do is make sure they tight at the joints, i cant see you improving it anymore, i suggest taking it to a dealers.
higham is offline
post #5 of 15 (permalink) Old 6th February 2011, 11:20
Nick7's Avatar
Poor accu is main issue.
I also have issue with dimming lights with i-Shift when it changes gears, etc...
I also did pull extra 3 thick wires for better ground, but it still happens.
However, when turning on engine, voltage drop is less for 0.5V, so yes.. it helps, but slightly only.
Nick7 is offline
post #6 of 15 (permalink) Old 10th February 2011, 11:41
kaisersoze's Avatar
Same problem for my i-shift with xenon.
I've earthing kit; still dimming.
What about changing battery with an optima yellow 2.7?
kaisersoze is offline
post #7 of 15 (permalink) Old 10th February 2011, 15:36
Nick7's Avatar
Well, my battery is still working, so don't fancy changing it yet... but when it starts dying, I'll get more powerful one.
From what I've read, getting battery mount for diesel is good, as you can fit a little larger battery which should also help a bit.
*but*, as for Xenon's dimming (yes, I have it too) - it's also down to crappy poor **** ballasts used.
I did Xenon retrofit on my old Civic and used Hella ballasts.
Let's put it this way: I can turn lights on, crank engine, and while it's cranking light output is exactly the same, no dimming, no nothing... on the other side, on my 'new' Civic with i-Shift, you can notice light flicker for anything that uses a bit more electrical power -> i-Shift changing gear, ABS/VSA working, etc, etc..
It's quite annoying
Nick7 is offline
post #8 of 15 (permalink) Old 10th February 2011, 18:30
nunoctr's Avatar
I have a pivot raizin voltage stabilizer (they are cheap on ebay) on my fn2 and this problem was resolved with it.
nunoctr is offline
post #9 of 15 (permalink) Old 11th February 2011, 10:31
Nick7's Avatar
Hmm.. had to check that.
TBH, me no likey what I saw.
It's basically few capacitors, and by their size, not too big capacity.
It's better to just get some 0.5F or similar, which are generally for audio freaks, and that will have way much more effect.
Nick7 is offline
post #10 of 15 (permalink) Old 16th February 2011, 09:29
kaisersoze's Avatar
I'm going to buy (end of february or march) an Optima Yellow Top YT U 4.2 55A battery.
I'll tell you the (i hope positive) results.
post #11 of 15 (permalink) Old 18th February 2011, 17:04
Nick7's Avatar
Be sure to let us know, even if it still stays the same issue.
Nick7 is offline
post #12 of 15 (permalink) Old 28th February 2011, 10:49
kaisersoze's Avatar
I've mounted an Optima YellowTop YT U 4.2.
I've tried for 2 days...
The problem with the xenon seems to be solved!
post #13 of 15 (permalink) Old 28th February 2011, 11:30
cheekyweeboy's Avatar
Car: 2007 type r gt, NHB
where can i get this kit?
cheekyweeboy is offline
post #14 of 15 (permalink) Old 28th February 2011, 15:13
Nick7's Avatar
Goodie.. so good/bigger battery IS the fix
Nick7 is offline
post #15 of 15 (permalink) Old 10th March 2011, 13:44
kaisersoze's Avatar
After 2 weeks of use I confirm that is the solution.
I don't know if the solution is the high "Cold Cranking Amps: (EN) CCA" or the "Capacity: (EN) Ah"; what i can say is that with an Optima YellowTop YT U 4.2 i SOLVED the problem.
Electrics Earthing Kit ivtecdoyou Electronics (8G) 14 17th December 2013 16:26
Earthing kits reb Type-R 20 8th October 2009 12:03
