Other hft part of satnv? - Civinfo
post #1 of 12 (permalink) Old 7th July 2011, 10:24 Thread Starter
hft part of satnv?
Hi
Would anybody know whether the hft is part of the satnav or if they are seperate units?
satnav works fine, hft has packed up and warranty covers hands free systems but not satnav and im guessing if there part of the same unit in the civic the warranty company will say no.
cheers
marlyg is offline
post #2 of 12 (permalink) Old 7th July 2011, 10:53
Car: 2006 1.8 ES 5 Door Cosmic Gr
Send a message via Skype™ to coltam
Yes it is
Sent from my GT-P1000 using Tapatalk
coltam is offline
post #3 of 12 (permalink) Old 7th July 2011, 12:33
Bog
Bog's Avatar
Car: 2016 CR-V 1.6 160 4WD
Actually the Hft is a separate unit even though it's intregated with the nav... The main hft module is on the inside of tbe trim panel under the drivers side dash, so in theory if its this part that has failed, it's just a case of un screwing it and plugging in a new one.
Bog is offline
post #4 of 12 (permalink) Old 7th July 2011, 17:41 Thread Starter
excellent news if its seperate and it would make sense as honda have quoted over nearly 700 to fix by replacing the unit and i would have thought if it was intergrated into the satnav it would be a lot more.
anyway thanks for the reply's
marlyg is offline
post #5 of 12 (permalink) Old 7th July 2011, 20:29
Bog
Bog's Avatar
Could you not try getting the unit from a breakers? It is really simple to fit... 15 min job.
Whats wrong with the hft btw?
Bog is offline
post #6 of 12 (permalink) Old 7th July 2011, 22:14 Thread Starter
it sounds like you speak from experience, if so i take 15mins its not dash off to get to?
any further info appreciated as its taken 3 months to get to this stage going back and forth netween honda and warranty i may just try that
all of the hft works right up to the point it try's to pair up,when I brought the car it paired first time on my iphone and wifes galaxy s then 2 weeks later phone not found and when trying to repair if just fails to pair,timing out with no phone found.
I have done multiple complete resets etc and over 10 diff phones
honda had it for an hour and could only conclude it requires a complete new module
marlyg is offline
post #7 of 12 (permalink) Old 7th July 2011, 22:53
Bog
Bog's Avatar
Basicly, you unclip the trianglular trim panel at the end of the dash (Drivers side), then you will see one screw that holds the lower dash panel (the one below the steering wheel in front of your knees). then pull that panel forward releasing it from it's clips. You will then see the hft module fixed to that panel - you need to un-plug it and the its just 2 screws holding it on
I assume the dealer actually checked for a loose connection?
From what you say, it's seems to be that it works, but the bluetooth bit is not... Strange. Have you tried putting the phones to search at the same time as the car, as this is how I have get mine to 'find' my iphone?
Bog is offline
post #8 of 12 (permalink) Old 8th July 2011, 10:53 Thread Starter
thanks for the info much appreciated, believe me when i say ive tried every which way.
id be very surprised if they checked as the car went off into the workshop for what must have been 10mins max inc driving it round and back and when it was brought back out the guy i was dealing with asked me to go through the pairing precedure with my phone, then a few times with his as well for good measure.
yes quite correct its only the bluetooth bit that fails, ill check connections at the weekend.
cheers
Glen
marlyg is offline
post #9 of 12 (permalink) Old 8th July 2011, 20:24 Thread Starter
no loose wires and white block was pushed firmly in so no joy,
that unit, what is it exactly? surely thats not the total sum of 700
if you happen to know what it was ill try some breakers while waiting for warranty and honda to sort there S*** out
cheers
Glen
marlyg is offline
post #10 of 12 (permalink) Old 8th July 2011, 21:25
tomo2001's Avatar
Car: 2011 Ford Focus Titanium X
tomo2001 is offline
post #11 of 12 (permalink) Old 8th July 2011, 23:06 Thread Starter
yup that would be it then
thanks for link though chap
marlyg is offline
post #12 of 12 (permalink) Old 8th July 2011, 23:59
jameslro's Avatar
Car: 07 22ictdi Type s gt Sat/Nav
hi, from what you are saying i tell you that the hft is good. i bought a type s gt with sat nav and has hft integrated like ex models. i tried to pair a phone with no result and followed the manual to the letter. then i took it to the Honda main dealer in Malta and with no result they didn't even know about it cause here they do not come with sat/nav pack. and sent me to a very professional car audio technician that usually send people with problems that they aren't able to solve and he told me that he never worked on civic but the same problem had with the accord and he solved it. but unfortunately mine wasnt so lucky and at that point i resigned from make it work. then one fine day i was playing with the hft and i do not know exactly what i had done but it reseted everyhing like it was new the first time due it had other settings from previous owner and then the hft paired with my phone immediately i took around 2 hrs playing with it and like i mentioned before i am not able to say exactly what to do but it worked. there is just setting problem for me. now it is 3 months that i use it daily and touch wood works fine. probably the best hft i ever had.
jameslro is offline
part ex norken47 General Discussion (8G) 11 10th August 2011 13:13
