Battery new battery - upgrade?? - Civinfo
post #1 of 17 (permalink) Old 1st November 2011, 22:52 Thread Starter
corasdad's Avatar
my battery has gone flat twice in a week so I think i need a new one what is the best upgrade for 2.2diesel
corasdad is offline
post #2 of 17 (permalink) Old 2nd November 2011, 10:55
coste1l's Avatar
are you sure its the battery? search for micu recall and eliminate that first, what colour ball is in the window on top of it?
coste1l is offline
post #3 of 17 (permalink) Old 2nd November 2011, 11:12 Thread Starter
corasdad's Avatar
cant see any ball maybe it needs topping up??
corasdad is offline
post #4 of 17 (permalink) Old 2nd November 2011, 11:18
coste1l's Avatar
im fairly certain they are maitainance free?
coste1l is offline
post #5 of 17 (permalink) Old 2nd November 2011, 11:28 Thread Starter
corasdad's Avatar
this battery has the bits you open and top up the car is 2006 and I only got it in april so I have no idea how old the battery is
corasdad is offline
post #6 of 17 (permalink) Old 2nd November 2011, 12:38
coste1l's Avatar
check with a dealer about micu first buddy
coste1l is offline
post #7 of 17 (permalink) Old 2nd November 2011, 13:14 Thread Starter
corasdad's Avatar
done on online nothing is outstanding for my car so must just be battery??
corasdad is offline
post #8 of 17 (permalink) Old 2nd November 2011, 13:17
coste1l's Avatar
i suppose if its original its 5yrs old so maybe! could also be the alternator
coste1l is offline
post #9 of 17 (permalink) Old 2nd November 2011, 13:33
COTM Feb 2012
Guitaralmond's Avatar
Car: Aston V12 Vantage S
I see you have a "cheapo rear camera" possibly a discharging issue? It might not be fully compatible and running your battery while your car is off.
Get the recall checked first, also I had a problem with the roof switch discharging the battery, it could be something like that if you have a glass roof.
Guitaralmond is offline
post #10 of 17 (permalink) Old 2nd November 2011, 15:02 Thread Starter
corasdad's Avatar
camero only works in reverse
corasdad is offline
post #11 of 17 (permalink) Old 2nd November 2011, 15:04 Thread Starter
corasdad's Avatar
tut no
corasdad is offline
post #12 of 17 (permalink) Old 2nd November 2011, 15:54
Car: 2010 1.4 type S, Silver
Location: Hampshire, where ponies rule the roads ENGLAND
Your battery may have a visual indicator which will help to determine its condition. If it has there should be a label which explains the possible indications.
If you have access to a voltmeter you can quickly carry out a simple test that gives a guide to your batteries condition. Failing that you could go to a battery centre where they can test the battery more thoroughly to determine its conditon.
To test it yourself connect the voltmeter to the battery and with everything switched off check the battery voltage. For a reasonable battery the voltmeter should indicate 12.2-12.5 volts.
Switch on the side lights and check the voltmeter. It should indicate no more than 0.2 volts less than the previous test.
Switch off side lights and start engine with the engine idling the voltmeter should read at least 13 volts. Rev engine at about 2000 rpm and the voltmeter should read 13.5-14 volts. This test will show whether the alternator is working correctly.
You do not say how old your battery is, but if it is 4-5 years old it could simply be life expired and not have a very good capacity.
If you have any doubts get a battery centre to test the battery for you.
dodger is offline
post #13 of 17 (permalink) Old 2nd November 2011, 16:12
J. Derek Riddell's Avatar
If the Battery is simply dead, I'd recommend getting the Bosch S6 replacement ...
J. Derek Riddell is offline
post #14 of 17 (permalink) Old 2nd November 2011, 16:27 Thread Starter
corasdad's Avatar
cool thanks will get it tested and take it from there
corasdad is offline
post #15 of 17 (permalink) Old 21st November 2011, 11:51 Thread Starter
corasdad's Avatar
correct boo ,booked in tuesday for a new one
corasdad is offline
post #16 of 17 (permalink) Old 21st November 2011, 12:10
coste1l's Avatar
sorry mate! no chance of a recon one?
coste1l is offline
post #17 of 17 (permalink) Old 21st November 2011, 12:33 Thread Starter
corasdad's Avatar
na
corasdad is offline
Battery Battery for FN2 Pabby Electronics (8G) 7 17th October 2011 10:58
battery's AndyG72 Type-R 3 23rd February 2010 18:50
Battery Tie CTR_Timmy Type-R 4 25th November 2009 15:14
Questions Need battery J-FN2 Buying, Dealers and Servicing 13 24th January 2009 00:50
