Oil Major Oops Moment - Lost the Engine Oil Cap - Civinfo
 4Likes
  • 2 Post By Wilmo
  • 1 Post By 4thHonda
  • 1 Post By Adamsnake
post #1 of 12 (permalink) Old 29th December 2007, 18:52 Thread Starter
nelster's Avatar
Question Major Oops Moment - Lost the Engine Oil Cap
Seems to be the case that I only post the stupidest things on this forum, but here goes again.
This afternoon I was chittering away in Glasgow trying to top myself up a bit as the oil was a wee bit low, after much heaving the cap comes off, great.
10 minutes later having spilt my new 2L Castrol GTX I'm ready to put the cap back on.
The hands are freezing I try to turn it to tighten and POP! off it goes into the darkness down inside the bonnet.
It's not been found yet... So 2 questions.
1. Is a replacement easy to come by at a dealership ??
2. Once I have a replacement and can drive again - is the missing cap a potential hazard ?? could it rattle something it shouldn't or is it all pretty secure down there ??
nelster is offline
post #2 of 12 (permalink) Old 29th December 2007, 18:59
Jack The Lad.'s Avatar
If the Dealer doesn't have one in stock, he will nick one off another Civic for you and then place one on order for himself.
As for your one under the bonnet, best get down there and find it mate, as it may well end up in the cup holders.
Jack The Lad. is offline
post #3 of 12 (permalink) Old 29th December 2007, 21:03
ritchie_perriam's Avatar
Car: 1989 BMW 325i sport
you might be able to get it out if you park it on a slope facing up the hill then bash the plastic underguards to try and vibrate it backwards to a hole!
ritchie_perriam is offline
post #4 of 12 (permalink) Old 29th December 2007, 23:42
Ask for a replacement part "710 cap"
If you can't see it anyway, I would advise that you have your car on a lift and try to get to the part from below, if it is still there. If it has fallen down, then you'll be sure that it is no longer there.. But you may have to unscrew some plastic panels below.
Good luck!
Korkut Varol is offline
post #5 of 12 (permalink) Old 4th January 2008, 14:55
cnicolini's Avatar
I once dropped my brake fluid cap and it fell into the engine bay, to top things off it started to rain. It took me almost an hour to find it and it was resting on the suspension arm. Its not just finding it, its getting the bloody thing, I was using wire, sticks and sellotape. You may never find it if it gets lodged somewhere. If its away from any moving parts like the drive belts then I'd just leave it, it may just drop out as you are driving any how! It can be a pain when these things happen.
cnicolini is offline
post #6 of 12 (permalink) Old 4th January 2008, 15:24
Wine and cooking !
l-noel's Avatar
Car: 2008, Grey Mica 1.5 Materia
You're not the only one .... Same happend to me the 23rd of December ! I replace the missing oil cap by an "home made cap" until I was back home. My dealer recieved the replacement oil cap the day after and everything was fine after havin driven more than 1 500 km with this "DIY" oil cap...
No rattles or damage have been noticed up to now
l-noel is offline
post #7 of 12 (permalink) Old 7th January 2008, 12:15 Thread Starter
nelster's Avatar
Talking
I'm sure everyone will be relieved to know I retrieved the cap just after Christmas, at one stage I thought I was being swallowed into the engine area, managed to go up and over the engine with my arms and grab it off the very bottom of the car.
If it happens to you, be patient get a good torch and have a good look.
nelster is offline
post #8 of 12 (permalink) Old 10th January 2008, 10:03
corlija's Avatar
Hi there,
been there.
On a petrol station on a way home from work, toped some oil, and in a moment, cap slips through my fingers and dissapears in the darkness.
Usually when you drop something in the engine bay it comes out under the car. Well.. not on our spaceships. There is some sort of plastic cover that covers most of the cars underside.
After like a half an hour of desperation, i got an idea.
I started knocking on the plastic cover, and managed to knock the cap out through a hole approx 10x10cm.
/D
corlija is offline
post #9 of 12 (permalink) Old 22nd April 2019, 15:53
Thumbs up Thanks :) Stay calm, have patience, a long piece of wire and a torch
I saw a young apprentice mechanic drop the oil cap of my Civic into the engine bay a few years ago; it took him half an hour to recover the cap and he had a ramp. He ended up removing the plastic cover underneath.
So, I was mortified when I dropped my oil cap into the engine bay of the same Civic this morning . I found this thread and it helped me focus The key advice for me was to "have patience" and a good torch [thanks @nelster ]. I put down a big piece of corrugated cardboard to lay on, scanned around with my "emergency" LED torch (not easy as I wear varifocals these days and the the Civic is very low) and eventually spotted the oil-wet cap glistening I used a very long, fairly thick, piece of wire to hook the cap back. There is a hole in the bottom plate which I couldn't see, and was unaware of, but the cap fell onto the ground earlier and more easily that I expected. It took me maybe 15 minutes - quite a relief. Thanks guys
4thHonda is offline
post #10 of 12 (permalink) Old 22nd April 2019, 18:53
Wilmo's Avatar
Learnt my lesson with the stupid plastic clips that holds trim in place - lost a few down the black hole.
Now if I am working under the bonnet I put a dust sheet over the engine so the b'stards get caught on that.
Farqui and FergyCiv like this.
Wilmo is offline
post #11 of 12 (permalink) Old 23rd April 2019, 08:53
Good idea. Did that myself once, trying to change a bad headlight bulb, at night, at the local garage. Never saw the little black plastic stud again
I hate designs that make it hard to work on cars, esp.changing bulbs.
Wilmo likes this.
4thHonda is offline
post #12 of 12 (permalink) Old 23rd April 2019, 13:03
Car: Audi A3 2.0 TDI 2015
I once got a screw-driver stuck in my slave cylinder when doing work, didnt relise and drove the car 15 miles.
Only when I was turning into my drive I couldnt change gear haha, took me over 2 ours to find it cause it was pitch dark and stuck in 3rd hahaha,
Farqui likes this.
Adamsnake is offline
Electrics NEW Honda Civic ES (I-Shift) / major problem pcf Bugs, faults and irritations (8G) 2 4th December 2007 18:14
Technical Potential Major Problem for new ICE Build - how do i get more AMPS? psykik Ipods, MP3 Players and ICE (8G) 3 9th November 2007 18:24
Moment of thought Kpow99 Any non Civic chat here please! 9 29th December 2006 18:00
Oops Telboy General Discussion (8G) 9 5th November 2006 08:54
Oops! I guess I should have done this by now? SteveWatson Introduce yourself 20 29th August 2006 18:36
