Faults Civic 1.6 i-DTEC injector failure - Civinfo
 4Likes
post #1 of 24 (permalink) Old 22nd July 2018, 21:18 Thread Starter
Hi. This is my first post. I have a 2014 Honda Civic 1.6 i-DTEC, ive owned it for 18 months. Previously i have owned a 2011 2.2 diesel, since changing to the newer 1.6 i initially thought it was less responsive and powerful. Over the last 6 months i have gradually noticed it has been getting less responsive and the fuel consumption has increased.
last month it was booked in for a service and on the way the DPF warning came on. The garage carried out a DPF regeneration along with the service and MOT, they advised me the car sounded noisy and suggested it was a diesel combustion noise possibly caused by worn injectors.
Two weeks later the DPF light came on again! This time i went to my local Honda dealer, they carried out a forced regeneration and told me the engine is noisy, they have carried out a few tests and suggest the injectors are worn.
The dealer has quoted just over £1400 to supply and fit all 4 injectors and have told me the DPF could be ruined, costing eye watering amounts.
This is something concerning for a 2014 car with 85000 miles.
I have taken the car to a local garage and they have advised me to get the injectors reconditioned and the DPF removed and flushed/cleaned by a specialist company.
The DPF has been removed, sent away and returned back ready to fit.
The injectors and have been sent to "the best diesel specialist in the country" and they have contacted me with some bad news!
The rebuild kit and nozzle that is needed for the serial number/model of injector for these engines is not currently obtainable from the manufacturer. They have had on average 2 sets of these injectors sent in a month for the last year with the same problem and suggested there is or was a design issue with these units.
He suggested to buy new genuine units from Honda as by experience they can be obtained quicker than ordering through him and theres no real price difference.
I asked his opinion on fitting second hand ones as they can be found on eBay for £70-£80 each. I was advised not to do this as it could be a waste of money, they have had people buy second hand ones off ebay, send them to be tested and they are far from perfect. It would also ruin the DPF too.
So, has anyone else had the same issue with 1.6 i-DTEC injectors and what did you do?
star1985 is offline
post #2 of 24 (permalink) Old 24th July 2018, 17:29
Car: 2014 1.6 DTEC 5 Door White
I'm sorry that it's not going to answer your question, but what kind of noise/symptoms did you experience? Mine makes quite a racket sometimes on startup but goes when I rev it and also in the heat the car stutters a bit under light acceleration
shaintaylor is offline
post #3 of 24 (permalink) Old 25th July 2018, 20:00 Thread Starter
Shaintaylor.
From speaking to my local honda dealer there is a common problem with 16MY 1.6 I-DTEC engines. the cam shafts wear and have excessive end float causing a rumble noise on start up and low RPM's.
My vehicle has a diesel combustion knock when puling away and under load, its noisy when starting too and it stutters and surges when trying to pull away from junctions. it has slowly progressed and got worse it sounds like a little end knock.
star1985 is offline
post #4 of 24 (permalink) Old 26th July 2018, 12:20
Ex-Pat Geordie!
nturnb's Avatar
Car: 2015 Civic S Navi I-dtec
What sort of Mileage and Journeys are you doing out of curiosity?
nturnb is offline
post #5 of 24 (permalink) Old 26th July 2018, 18:31 Thread Starter
Its done 84000 miles, i use the car 5 days a week for work, 3 miles on country roads then on to a motorway for 18 miles, same again on the way home, 42 miles a day round trip, always use BP diesel too.
star1985 is offline
post #6 of 24 (permalink) Old 26th July 2018, 19:57
Clutch pedal guru
hondacivicnut's Avatar
Can't offer any help on this but this doesn't sound good. Have you been in contact with Honda UK customer services about it? Bypassing the dealer.
Bog standard diesel is the minimum required, buying anything more expensive is a waste of money.
nturnb likes this.
hondacivicnut is offline
post #7 of 24 (permalink) Old 27th July 2018, 11:36
Would you be able to take some videos to compare against mine? Mine is a 14MY with 120K on it, it has made the cold ticking since I had it but has only started spluttering when accelerating since the start of summer... When yours does splutter and surge, does your engine make a rattling noise until it stops? I'll try and get some videos of mine.
Would also be able to describe this rumble when pulling away and at low revs? As I have a new vibration coming from the engine when accelerating but it will be hard to capture on video....
I'm starting to regret trading the 2.2 for this now...
post #8 of 24 (permalink) Old 28th July 2018, 13:20 Thread Starter
Sorry i cant take video, its currently got the injectors removed.
I was hoping other people had known about this issue and may be able to recommend somewhere other than the dealers for new injectors
star1985 is offline
post #9 of 24 (permalink) Old 29th July 2018, 18:27
Clutch pedal guru
That's why I said contact Honda UK direct. In my experience, they take reliability very seriously. See what they have to say. They may even offer to help you with costs as a goodwill gesture.
Jon_G likes this.
post #10 of 24 (permalink) Old 30th July 2018, 09:21 Thread Starter
i will try contacting Honda UK today. Thanks
star1985 is offline
post #11 of 24 (permalink) Old 30th July 2018, 09:24
Ex-Pat Geordie!
nturnb's Avatar
They don't take their servicing serious. Honda Dealer and Honda UK thought this still had another 3K in it...
nturnb is offline
post #12 of 24 (permalink) Old 30th July 2018, 10:31 Thread Starter
Ive spoke to Honda UK on the phone, because my vehicle does not have a fully stamped service book from a honda main dealer they will not offer to help.
I have just bit the bullet and have ordered a set of new injectors as i need the vehicle back on the road.
star1985 is offline
post #13 of 24 (permalink) Old 1st August 2018, 08:10 Thread Starter
The new Injectors have been fitted and the car sounds and drives a lot better. It's like a different vehicle!!
star1985 is offline
post #14 of 24 (permalink) Old 1st August 2018, 08:34
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
Result then! How much was the complete set?
M8TJT is offline
post #15 of 24 (permalink) Old 1st August 2018, 18:34 Thread Starter
Not as bad as i first thought as the garage that did the repair got trade discount on parts. the total with the labour was £1340.
Typically as luck would have it i have since found a set of 4 on eBay that are "as new" and a lot cheaper
https://www.ebay.co.uk/itm/Genuine-H...MAAOSwk6hbXJD7
star1985 is offline
post #16 of 24 (permalink) Old 1st August 2018, 18:46
M8TJT's Avatar
Wow. Why the hell are the injectors so expensive. I had a couple changed under guarantee on separate occasions on my 2.2 Accord and they told me the job was about £400 each.
Bummer finding those on eBay too late though.
M8TJT is offline
post #17 of 24 (permalink) Old 2nd August 2018, 18:08 Thread Starter
Yes they are expensive. The ones ive found on eBay have been reduced now too, really rubbing the salt in the wound
On a positive note my car feels smoother, sounds quieter, pulls harder and the fuel economy is much better. Im very happy!!
nturnb likes this.
star1985 is offline
post #18 of 24 (permalink) Old 2nd August 2018, 19:40
Ex-Pat Geordie!
nturnb's Avatar
Good result but at a high cost mate.. I always try eBay first if I need anything major. Half of my Mrs Fiat Punto is off eBay Best one was the throttle position sensor, actually mated to the throttle body and doesn't split £356 Fiat £10 FleaBay and 20 minutes to fit
nturnb is offline
post #19 of 24 (permalink) Old 3rd August 2018, 15:49 Thread Starter
Yes im actually annoyed at myself, I spent 20 mins every night for a week looking for some injectors but that are all used. typically after i bought new ones some came up on ebay that have only been used in a engine for a few mins. always the way
Jon_G likes this.
star1985 is offline
post #20 of 24 (permalink) Old 4th August 2018, 05:33
Earth Dreams :)
Higgo8's Avatar
Car: 2017 CTR GT
Don't you have to code the injectors though with the ECU?? Not just a case of replacing them from what I understand..
Higgo8 is offline
9G DTEC vs 10G DTEC Findings Nickolodeon General Discussion (10G) 15 16th July 2018 23:04
Exhaust Civic 06 2.2 CDTi Cracked Manifold and Injector Blowing GadgetBoy Engines and Transmission (8G) 3 11th October 2015 13:46
Fuel 2006 Civic ICDTI- injector leaking alamn2 Engines and Transmission (8G) 11 25th June 2013 15:56
Fuel Mileage of civic 2.2 injector seals being replaced CIVICICDTI Engines and Transmission (8G) 1 19th January 2013 08:34
Engine 2.2 civic injector Decoep3 Bugs, faults and irritations (8G) 6 13th July 2011 13:00
