would anyone know or be able to give a guess as to what would happen if a new oil pump chain was installed , and the oil pump balance shafts were not locked into posttion correctly. (IE running 90 degrees to correct position)
would it matter? - I am facing a big problem with a new timing chain install....engine not running correctly (big vibrations/ not revving past 3500 rpms.......and thats all i can think of....supposedly everything has been checked (timing position / crank sensor)
thanks for any thoughts
Chris
Chris
