Fuel 2.2 Diesel fuel issues - Civinfo
 4Likes
  • 1 Post By Jon_G
  • 1 Post By vivalarichy
  • 2 Post By vivalarichy
post #1 of 13 (permalink) Old 27th February 2019, 17:33 Thread Starter
Hi all,
My wife owns a 59 plate Honda Civic Si 2.2 iCDTI which is having some issues.
Two weeks ago she was driving home from work and the car smoked and revved itself. She immediatley turned it off and after that we couldn't get it going again. Car cranks but isn't firing, no fluid loss (I don't understand the smoke (I wasn't there when she broke down)).
The code on the ECU is P1065 - low fuel pressure.
I've replaced the fuel filter, incase that was clogged but there was fuel in the lines either side of the filter. I've checked the high pressure pump in the engine bay and it's delivering fuel. I've got fuel delivered to each injector but the pressure isn't high enough (7MPa rather than 20-30MPa (according to internet)).
My wife's mum's partner's son (a mouthful, I know) reckons that it's a pump inside the fuel tank which may have burnt out but I can't find anything for this on the internet; I can find the parts on ebay, but my local supplier doesn't sell them.
Could someone please confirm if there's actually a pump on the tank? & if there is how do I access it. I had the carpet up last night but couldn't find any access point.
TIA
Rich
vivalarichy is offline
post #2 of 13 (permalink) Old 27th February 2019, 17:38
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Welcome to Rich
Sorry to hear that you are having issues, the fuel rail pressure relief valve is known to fail - check threads on that out.
Good luck and let us know how you get on.
Farqui is offline
post #3 of 13 (permalink) Old 27th February 2019, 17:39
Farqui's Avatar
Farqui is offline
post #4 of 13 (permalink) Old 27th February 2019, 18:00
scaramanga's Avatar
Car: 2015 white orchid 1.6 dtec
revving up by its self and smoke on some cars happens when the turbo fails
but often you cant switch off till its burnt all the oil
out of interest have you looked at oil level
scaramanga is offline
post #5 of 13 (permalink) Old 27th February 2019, 18:27 Thread Starter
Thanks for this information I’ll be sure to check it out!!!
Originally Posted by Farqui View Post
Welcome to [IMG class=inlineimg]https://www.civinfo.com/forum/images/smilies/civinfo.gif[/IMG] Rich
Out of interest, is there a pump on the tank? (Just so I can put my mind at rest)
post #6 of 13 (permalink) Old 27th February 2019, 18:31 Thread Starter
I thought that too. The oil level is spot on, and there’s no sign of oil up the back of the car, which is something which happened when I had a turbo blow on an old car of mine.
A blown turbo wouldn’t prevent the car from starting up. Error on the MFD is PGM-FI and error on the ecu is low fuel pressure.
post #7 of 13 (permalink) Old 27th February 2019, 18:57
Bye bye Honda...
Jon_G's Avatar
Car: Volvo V60 VEA D4 (181)
I think the key thing here is the inability to reach the 20MPa minimum on cranking (against a 30MPa target). As said, most likely the rail over-pressure valve, but possibly one or more injectors with excessive leak-back.
Bit worried about the revving though, which isn't typical of this problem!
Jon_G is offline
post #8 of 13 (permalink) Old 27th February 2019, 19:01 Thread Starter
Hi Jon,
Thanks for the response... only thing which concerns me with replacing the valve is that none of the symptoms were present before it broke down; are these known to fail quickly like this?
post #9 of 13 (permalink) Old 27th February 2019, 22:15
Bye bye Honda...
Jon_G's Avatar
Originally Posted by vivalarichy View Post
Hi Jon,
Not really, but no reason why it couldn't suddenly fail.
Why not check the valve for any output flow before replacing it (as described on page 1 of the thread linked above by @Farqui )?
Farqui likes this.
Jon_G is offline
post #10 of 13 (permalink) Old 28th February 2019, 09:12
Check the valve first, easiest to do, and you might get some further insight into the issue
cavalrystu is offline
post #11 of 13 (permalink) Old 28th February 2019, 09:44 Thread Starter
That's a good idea. I'll check it out on the weekend! Many thanks!
Farqui likes this.
post #12 of 13 (permalink) Old 15th April 2019, 22:07 Thread Starter
Hi guys. Just wanted to say thanks.
It was a seized injector which my local garage diagnosed and fixed.
Jon_G and Farqui like this.
post #13 of 13 (permalink) Old 16th April 2019, 07:04
Bye bye Honda...
Jon_G's Avatar
Thanks for the update, glad it's fixed. Never heard of this happening on an i-CDTi before!
Jon_G is offline
Civic 1.6 Diesel Major service fuel filter guide CIVICICDTI This is How To ... (Guides Only) (9G) 4 24th May 2019 19:39
Fuel Saving Tips from Honda poor1 General Discussion (9G) 10 4th July 2017 21:59
Gen 3 petrol or diesel? Help! eustachio Honda CR-V 61 29th December 2010 00:03
Honda Assist operated by the AA neilfs General Discussion (8G) 34 7th December 2008 08:15
