Other 2010 FN2 Clicking/Tapping engine noise on acceleration. - Civinfo
 1Likes
  • 1 Post By Shippo
post #1 of 18 (permalink) Old 18th July 2019, 15:50 Thread Starter
Shippo's Avatar
Car: 2010 CTR (LSD), Red
Question 2010 FN2 Clicking/Tapping engine noise on acceleration.
Hi all,
I have a question on a concerning noise from my engine. on my 2010 FN2
Firstly i apologise in advance if this is posted somewhere else, i have been looking.
So the sound is as the title suggests, sounds a bit like a diesel engine, or some gremlin with a tiny hammer tapping my block. But for me it is only noticeable when accelerating in gear (or maintaining speed by feathering the pedal) not on idle or revving out of gear, which is obviously helping things....
now for me this is odd, because if your driving along with this tapping going on then release the accelerator (still in gear) the tapping goes, so for me at least this takes out the possibility of some loose trim, or a heat shield for example, or severe engine damage or you would surly hear this constantly?
I have a video, only sound - well a video of my air vent. ill be honest its not easy to hear.
i cant post links so copy and paste for youtube video: youtu.be/nq7VYofFSUk
So im just looking for any suggestions on possible faults? or good starting places to look into.
in looking through these posts i did find out that the PCV valve needs replacing, parts on order. but this was more of a 'bearing grinding' noise and constant.
Its booked into a garage tomorrow as my closest Honda dealers are weeks for even being able to look at it......
Im going to ask the garage to check the valve clearances as was last done at 44k and now im at 64k, so definatly worth it as nearly due to the book. but could that cause the sound?
im a bit confused and really worried about driving it.
Any help/advice much appreciated
ps. its bog standard
Shippo is offline
post #2 of 18 (permalink) Old 18th July 2019, 18:53
Commander2874's Avatar
Car: 2007 CTR GT (FN2) Bronze
Sounds like valve clearance needs doing mate
Sent from my SM-G960F using Tapatalk
Commander2874 is offline
post #3 of 18 (permalink) Old 18th July 2019, 20:49 Thread Starter
Shippo's Avatar
Thanks for the reply, gives me something to have the garage tackle first tomorrow. Anything serious to worry about with driving it, obviously staying well out of the vtec. Strange all of a sudden and then being SO noticeable!
Commander2874 likes this.
Shippo is offline
Thanks to Shippo from:
post #4 of 18 (permalink) Old 19th July 2019, 06:34
You're welcome, i was always on here asking questions when i bought mine haha. No won't be an issue mate, keep a eye on the oil levels too. Great cars
post #5 of 18 (permalink) Old 20th July 2019, 10:54 Thread Starter
Shippo's Avatar
Ok. So long story short. I'm having a go at it myself.
With the valve cover off obviously you can see the timing chain. How much (if any) slack is supposed to be on the chain?
Exhaust cam gear it's tight almost no movement. But inlet side is got some play in it.
Shippo is offline
post #6 of 18 (permalink) Old 20th July 2019, 17:52 Thread Starter
Shippo's Avatar
Thumbs down not the result i wanted
So you can ignore the previous post (i think) when turning the engine the chain had no slack.
Right so ive changed the PCV valve (i dont think was related) and now done the valve clearance myself as was going to be end of the month before honda could look at it. Not gonna lie took ages, but i was being meticulous and took my time to be sure i did it right. 0.009 on the intake and 0.011 on the exhaust. But checked them all before i did anything, shocking! i got between 0.015 - 0.030 all round most nearer the higher end!.......slightly off
So now the result........... no difference! not a bit. i wasnt convinced it was the clearances anyway. this is a much louder tap/knock i did another video, i just need to edit and then ill add. but it does seem to run a bit rough on idle now. once it sits for a few seconds it almost feels like its on the verge of cutting out i am not liking how this is going.
So anybody got some suggestions? even better anybody near by who might be able to help diagnose or suggest a decent garage or mechanic who might know more......
please
Shippo is offline
post #7 of 18 (permalink) Old 20th July 2019, 18:18
Mate you're obviously quite concerned so take it to a honda specialist near you. Don't know where you are but tgm sport in Fleet are very good.
post #8 of 18 (permalink) Old 20th July 2019, 19:05 Thread Starter
Shippo's Avatar
ok so not my car, but probably the best video ive found sounding the same as what i have.
Video {click}
how can i confirm if its bottom end?
Shippo is offline
post #9 of 18 (permalink) Old 20th July 2019, 20:51 Thread Starter
Shippo's Avatar
Im in dunstable, bedfordshire. so far not many places near by from a quick scout.
im really concerned, alot of money to buy this car and only had a year.
Shippo is offline
post #10 of 18 (permalink) Old 20th July 2019, 21:55
scaramanga's Avatar
Car: 2015 white orchid 1.6 dtec
unfortunately the car in the youtube clip does sound like a big end
but I have heard some cars sound similar and it was the camshaft pulleys some have a little movement in them sort of spring loaded
scaramanga is offline
post #11 of 18 (permalink) Old 20th July 2019, 22:03
Car: 2011 FN2 Crystal Black Pearl
I think there are a couple of bearings in he alternator, might be easy to check and cross off the list.
Sent from my Moto G (4) using Tapatalk
jakabi is offline
post #12 of 18 (permalink) Old 21st July 2019, 16:12 Thread Starter
Shippo's Avatar
thanks for the replies, have a mate coming over shortly. bit of a CTR madman. but knows his stuff and had the bottom ends goes on his. gonna give me his view and see whats best move from here. also has good contacts for work needing to be done.
will update when i know more. but at the moment its off the road, im not risking it - might still be salvageable.
Shippo is offline
post #13 of 18 (permalink) Old 23rd July 2019, 11:02
Did you get to bottom of this?
jakabi is offline
post #14 of 18 (permalink) Old 2nd August 2019, 13:57 Thread Starter
Shippo's Avatar
Unhappy
Hi All,
Sorry haven't updated. As always these things always come at a time when you really don't need them.
Anyway, update. So mate never turned up. tried a few things as advised by others and no real confirmation on the issue. So i sent to Honda dealer to carry out the valve clearance (to be sure it was correct) and had them investigate the noise im hearing and sadly they confirmed that the noise is defiantly coming from the bottom end, not the top and confirmed my fears of the likely hood of the bottom bearings starting to fail.
So im now looking into the cost of the repair, lets say its not looking cheap.
If anyone else has had this and can give some experience, how they solved it. ie just change the bearings or full engine rebuild?
Also if anyone knows of a decent garage who could do the work would be much appreciated.
Honda did 'name drop' a garage called 'Dream Automotive' not to far from me who might be able to do the work, but at this moment still awaiting a reply.
Im now stuck in this situation where i don't really want to loose the car, wont make any decent money back in the state it is in and its bloody expensive to repair........basically screwed!
Shippo is offline
post #15 of 18 (permalink) Old 2nd August 2019, 14:12
flashy's Avatar
Have you thought of a K24 bottom end? Were you planning to mod it? That's crap news though.
flashy is offline
post #16 of 18 (permalink) Old 2nd August 2019, 14:54
Sorry to hear that. If it were me I'd take it to a trusted specialist as the noise could be a number of things, don't forget there is a big lump of an oil pump in the same area that 'could' be the issue.
jakabi is offline
post #17 of 18 (permalink) Old 2nd August 2019, 17:48
Wilmo's Avatar
Shame, sounds like bad news all round.
You haven't said how many miles it's done or what the service history is like though.
Wilmo is offline
post #18 of 18 (permalink) Old 14th August 2019, 17:49 Thread Starter
Shippo's Avatar
So, bit of an update. been on holiday so not much done. But i finally got a response from 'dream automotive'. they are in the process of moving there business from Bushey, Watford to there new premises in Luton, about 15 mins away. highly rated, booked in for Monday so im expecting to finally get this moving. im just hoping for good news on the price! could do with it with the amount of things gone wrong this month.....if it could go wrong it has. i fed up and the joys of public transport and bumming lifts off people is really wearing thin now.
Wilmo, car is currently on 64k and has full service history and tons of receipts.
I have read about quite a common cause of oil starvation on these is from hard cornering ie track days as an example. as the sump on these allows the oil to move away from the pump temporarily. so was looking at maybe a baffled sump. think its worth the investment? I dont do track days, just days
And whats this K24 Mod? wasnt really looking to mod as i like standard, and these seem generally very pricey for any mods....worth while ones anyway.
Will update when i hear the news from monday........
Shippo is offline
