2.2 type s clutch issues - Civinfo
 3Likes
  • 1 Post By Alex Giovanni
post #1 of 12 (permalink) Old 24th July 2019, 16:57 Thread Starter
2.2 clutch issue continues: Stage 2 remap 300lbs of torque.
First and reverse won't engage when engine is on. But fly into gear when off. Clutch has always been heavy but this is ridiculous now.
It currently has a twin plate on a SMF fitted by TDI-North. This was replaced like for like (along with the bearing) 18 months ago because it fully went.
Issues with the master cylinder 2 months ago so had a new one.
The only thing I've never changed in it is the slave so I'm doing that next but I dont expect this to solve my problems. Finding one is a nightmare
Any advice would be great. If not could someone recommend anywhere to diagnose my issue in Somerset/Bristol.
Alex Giovanni is offline
post #2 of 12 (permalink) Old 24th July 2019, 21:04
Clutch pedal guru
hondacivicnut's Avatar
Does it have the damper bypass hose fitted?
New slave can be bought from a motor factor.
hondacivicnut is offline
post #3 of 12 (permalink) Old 24th July 2019, 23:14 Thread Starter
I've never actually checked tbh so I'll look tomorrow
You thinking it could be a faulty hose if there?
If not there should I Bypass it?
post #4 of 12 (permalink) Old 25th July 2019, 07:20
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
No, the clutch damper can fail, are awkward to bleed properly and bypassing it makes the clutch lighter and feel like an old school clutch. Oh and its cheap
Yes, it's a win, win
Farqui is offline
post #5 of 12 (permalink) Old 25th July 2019, 07:49
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
Originally Posted by Farqui View Post
No, the clutch damper can fail,{snip}
I guess that you actually mean "Yes, bypass the damper" Farqui?
M8TJT is offline
post #6 of 12 (permalink) Old 25th July 2019, 09:41
Farqui's Avatar
Now I'm at my PC I see Alex had several questions, so I've tweaked my reply Trev
Farqui is offline
post #7 of 12 (permalink) Old 25th July 2019, 11:11 Thread Starter
Well it hasn't been bypassed so I've just order the cable from TDI hopefully this sorts it
Farqui likes this.
post #8 of 12 (permalink) Old 25th July 2019, 12:01 Thread Starter
I'll also change the slave as I've taken it out already 😂
Farqui likes this.
post #9 of 12 (permalink) Old 29th July 2019, 14:43 Thread Starter
So this fixed the issue with my clutch thanks for the advice
Although warning to anyone who attempts this. Getting the rusted pipes off the clutch damper took me 2 solid days.
Farqui likes this.
post #10 of 12 (permalink) Old 29th July 2019, 17:30
Farqui's Avatar
Excellent news, well done
Did you replace the slave too?
Last edited by Farqui; 29th July 2019 at 17:31. Reason: I give it 5mins before flashy chimes in ;)
Farqui is offline
post #11 of 12 (permalink) Old 29th July 2019, 19:39 Thread Starter
I did not yet however that is a potential future option should the issue persist
post #12 of 12 (permalink) Old 30th July 2019, 14:20
Clutch pedal guru
Brill, glad it's sorted 👍
