Indications Help with oil light please - Civinfo
post #1 of 18 (permalink) Old 18th April 2014, 07:51 Thread Starter
Soichiro's Avatar
Car: 2017 1.6 Tourer Sport
Can people with 2.2 iDtecs do a little test for me?
Please time in seconds how long it takes for your oil pressure light to go out after starting
1 first thing in the morning
2 after turning the engine off and immediately back on
3 after leaving the engine stopped for 1/2 hour
I will tell you why when we get some numbers in
Soichiro is offline
post #2 of 18 (permalink) Old 18th April 2014, 18:00
jc40's Avatar
Car: 2012 CIVIC 2.2 I-DTEC SE
1 Approx 3 seconds.
2 If i'm quick enough the light doesn't come on at all.
3 Goes out instant engine starts.
jc40 is offline
Thanks to jc40 from:
post #3 of 18 (permalink) Old 18th April 2014, 19:45 Thread Starter
Soichiro's Avatar
Thanks for that.
Any more for any more?
Soichiro is offline
post #4 of 18 (permalink) Old 19th April 2014, 09:22
1 about 3 secs
2 & 3 probably less than a second
phil_ellis is offline
Thanks to phil_ellis from:
post #5 of 18 (permalink) Old 22nd April 2014, 12:28 Thread Starter
Soichiro's Avatar
You have confirmed my suspicions
I thought when I got the car the oil light went out as you describe.
Mine, after 10k miles now takes about 3-4 secs to go out for 1 and more importantly 3.
I think the non return valve must be stuck, so the oil runs back out the filter when the engine stops....
Trip to dealer booked.
Soichiro is offline
post #6 of 18 (permalink) Old 22nd April 2014, 12:31
SHOCKD
JackW's Avatar
Car: BMW 116i 2.0
Mine takes about 4 seconds to go out when the engine is cold..
I started my engine and a lot of smoke came out the exhaust the other day.. Any reasons why?
Garage said i could have just had oil lying as I may have revved my car a little before turning the ignition off
JackW is offline
post #7 of 18 (permalink) Old 22nd April 2014, 12:53 Thread Starter
Soichiro's Avatar
Mines about 3-4 seconds from cold. The more important one is after a short stop.
What colour smoke?
White, water vapour or unburnt diesel - Damp in the exhaust or glow plugs not up to temp?
Black, bit of old soot out the exhaust or overfuelling when starting can do this occasionally
Are you remapped? Clean air filter?
Black, as suggested burning off some oil.
If it only happened once I don't think it's a major problem....
Soichiro is offline
post #8 of 18 (permalink) Old 22nd April 2014, 12:55
SHOCKD
JackW's Avatar
Car: BMW 116i 2.0
What colour smoke?
Its like a whitey blue...
Could be glow plugs not to temp.
But no im not remapped mate just oem
JackW is offline
post #9 of 18 (permalink) Old 22nd April 2014, 13:05 Thread Starter
Soichiro's Avatar
White/grey/blue sounds like a small amount of unburnt diesel.
Slightly worn engine will do this, compression not as high as when new, or a bit of wear on injectors
More likely glow plugs not as efficient as new.
Try operating glow plugs twice by turning key, wait for glow plug light to go out and then switch key off and repeat.
If smoke is less, may give you an indication?
Soichiro is offline
post #10 of 18 (permalink) Old 6th May 2014, 20:49
Car: 2013 1.6 i-dtec
Hi I've just joined. I was searching around to see what people say about the time it takes for the oil pressure light to go out after a cold start. This is because I've always driven petrol engined cars (where the oil pressure light goes out directly on starting whether hot or cold) so I was a bit surprised when I found that the light takes about 2 seconds to go out after starting in the morning. I haven't noticed how long it takes after a 1/2 hour stop (it goes out immediately if the engine is stopped and started again straight away). By the way mine is a 1.6 diesel with only 5000 miles on it. Is this normal?
hondaandy is offline
post #11 of 18 (permalink) Old 8th May 2014, 12:26 Thread Starter
Soichiro's Avatar
Welcome hondaandy!
All of my other cars, petrol or diesels have usually extinguished their oil lights almost immediately on starting.
The only exception has been after an oil change when the filter is empty.
So I am sure this should not be normal. I am sure that 2-4 seconds is not a good idea for a long engine life.....
I do have two theories
1: Oil pressure switch is set to operate and turn light off at higher pressure than normal for some reason.
2: The non return valve in the filter assembly is not working, or Honda have not designed one in. The oil filter is located high on the engine for ease of service and will naturally empty back into the sump. On the Vauxhall we have with a similar oil filter design there is a simple valve to keep oil up in the filter when the engine is not running. I canít see one of these on the Honda
Anyway mine is going to the dealers to check this at the weekend.
I will let you know the outcome.
Soichiro is offline
Thanks to Soichiro from:
post #12 of 18 (permalink) Old 12th May 2014, 12:16 Thread Starter
Soichiro's Avatar
Update
Well car has had an oil and filter change and the time for the light to go out is much reduced, down to about a second.
So either the filters clog up easily, or the oil put in at the factory is really really thin!!
Soichiro is offline
post #13 of 18 (permalink) Old 13th May 2014, 12:38
Hi Soichiro, I contacted my local dealer who said that it 'was normal' - I don't really believe this though. They said they only use shell 5W-30 oil - do you know what oil you've had put in?
post #14 of 18 (permalink) Old 14th May 2014, 12:09 Thread Starter
Soichiro's Avatar
Hondaandy,
My dealer said it was normal to!
But after the service and an oil and filter change the time for the oil light to go out has been reduced to 1 to 2 seconds.
My dealer uses 5W-30 in everything dispite Honda's recommendation of 0W-30.
If you are at all worried and are planning to keep the car for a long time it might be worth having an oil change done?
I my opinion 12.5k miles is a bit long - a half time change at 5-6k can only be a good idea....apart from the high cost of engine oil these days!!
Soichiro is offline
post #15 of 18 (permalink) Old 14th April 2018, 18:37
DieselGeek's Avatar
I'm reviving an old thread here. Its 10k since my last oil change so a service is due, however I'm having this issue now. When the cars warm the light will go out instantly, but when its a cold start in the morning it takes about 2 seconds now and things sound a little rattly. Mildly concerning. I'm hoping its just oil change needed but its never done this before. Does anyone think it may be the oil pump on its way out?
DieselGeek is offline
post #16 of 18 (permalink) Old 14th April 2018, 19:58
FergyCiv's Avatar
You checked the oil level recently?
FergyCiv is offline
post #17 of 18 (permalink) Old 15th April 2018, 08:10 Thread Starter
Soichiro's Avatar
When mine started doing this it was much better after new oil and filter
I think much of it is caused by the fact that the oil filter is high up on the engine and the oil drains right back down to the sump overnight
There is a non return valve of sorts I believe but if the filter is starting to clog and reach the end of its life it will increase the amount of time it takes to refill the filter housing first start in the morning
Most of the rattle on my 2.2 as it got older and went through 100k was to do with the timing chain and not the oil pump
Soichiro is offline
post #18 of 18 (permalink) Old 24th April 2018, 20:25
DieselGeek's Avatar
Ok It should be fine then. The oil and oil filter hasnt been changed in just under 10k miles now so its probably high time I did it. I changed the timing chains already at 155k miles so Im hoping to get 200k without any issues. Thanks for the advice guys its appreciated.
  Civinfo > 9th Generation Euro Honda Civic (2012 - 2016) > Engines and Transmission (9G)
Faults Glow plug warning light flashing and engine management light on. Gmac00 Engines and Transmission (8G) 71 6th March 2017 21:13
Electrics Flashing Glow Plug light and Check Engine light. jsurfer1971 Bugs, faults and irritations (8G) 21 8th September 2013 14:32
Bulbs head light & side light bulb info icivic06 Lights (8G) 1 22nd January 2009 18:12
Brake Width of high level brake light - doesn't fill the light shape? benjamino Lights (8G) 3 12th January 2009 16:53
