Idle speed - Civinfo
post #1 of 14 (permalink) Old 7th March 2019, 13:33 Thread Starter
shaft's Avatar
Car: 2015 1.6 i-DTEC SE PLUS NAVI
Idle speed
Hi Chaps
I have an intermittent issue with my 1.6 DTEC where occasionally my idle speed jumps from 800 rpm up to 1000 rpm. Does anyone have any the reason why this could be happening?
shaft.
shaft is offline
post #2 of 14 (permalink) Old 7th March 2019, 13:58
joooe's Avatar
Car: Honda Civic Sport 1.6 i-DTEC
Mine does that when I press the clutch pedal.
joooe is offline
Thanks to joooe from:
post #3 of 14 (permalink) Old 7th March 2019, 14:34 Thread Starter
shaft's Avatar
Now you mention it joooe, I think it does happen when the clutch is depressed - hopefully nothing to worry about then. It never happened on my 8th gen 2.2 though.
How many miles has yours done joooe?
shaft is offline
post #4 of 14 (permalink) Old 7th March 2019, 16:31
joooe's Avatar
Mine is now around 53k miles on the clock. Remap since 27k miles.
Anyhow, revs do go up to about 900 rpm when I arrive at home, after parking in the garage. Then I put in neutral, remove my foot from the clutch and goes back to normal.
joooe is offline
post #5 of 14 (permalink) Old 8th March 2019, 12:05 Thread Starter
shaft's Avatar
Mine's twice as many miles joooe, drives beautifully though, I love it!
Doesn't always change the revs when I deploy the clutch though, as I say, it's intermittent.
shaft is offline
post #6 of 14 (permalink) Old 8th March 2019, 12:09
Car: 2016 Civic Sport Alab Silver
Totally normal, mine does it all the time. Not sure why though
stomper is offline
post #7 of 14 (permalink) Old 8th March 2019, 12:53 Thread Starter
shaft's Avatar
Mine doesn't do it all the time stomper. Should I be worried?
shaft is offline
post #8 of 14 (permalink) Old 8th March 2019, 13:58
Haltamer's Avatar
You'll find it is linked to the operation of the Climate control:- You'll find the revs rise, and then fall to give an extra boost to the AC, without having to maintain a constantly higher idle speed, balancing economy with cabin conditioning.
A bit like when the fridge compressor cycles on and off
The 1.4 / 1.8 does similar.
Haltamer is offline
Thanks to Haltamer from:
post #9 of 14 (permalink) Old 8th March 2019, 15:45
Mine does it all the time too...
cavalrystu is offline
post #10 of 14 (permalink) Old 10th March 2019, 04:37
Car: 2014 1.6 DTEC 5 Door White
On mine, the car revs up for you to aid when pulling off. Try and pull off without using the accelerator and you'll notice it.
shaintaylor is offline
post #11 of 14 (permalink) Old 11th March 2019, 11:23
Originally Posted by shaft View Post
Mine doesn't do it all the time stomper. Should I be worried? <a href="http://www.civinfo.com/forum/images/smilies/icon_confused.gif" border="0" alt="" title="Confused" ></a>
Haha as in it does it frequently not literally all the time &#x1f923; my bad
stomper is offline
post #12 of 14 (permalink) Old 5th April 2019, 16:31
Car: 2013 Civic DTEC 1.6
Mine did that - the odd increase to 1,000 rpm - and after a service it stopped doing it. They must have adjusted some sensor. I'm guessing the sensor that detects when you are lifting off the clutch to pull away and it was was a bit loose.
That's one benefit of a Honda service they see and fix things like that. They also fitted the bit of plastic that covers the bottom of the steering column which I'd tried and failed to do.
No charge and not even mentioned. Startins Worcester.
mikewebb is offline
post #13 of 14 (permalink) Old 5th April 2019, 16:38
Haltamer's Avatar
I must say, I noticed that the dealer tightened up my Handbrake without prompting or mention, which is welcome.
Haltamer is offline
post #14 of 14 (permalink) Old 15th April 2019, 15:40
Car: Civic Tourer 1.6DTEC
Idle speed will increase if a DPF regen is in progress. Usually accompanied with the cooling fans being on.
Generally a good idea to let the regen finish rather than turning the engine off part way through the cycle
sasquartch is offline
  Civinfo > 9th Generation Euro Honda Civic (2012 - 2016) > Engines and Transmission (9G)
Other Civic 2.2 revs dropping below idle speed when stopping at junction hondacivicnut Engines and Transmission (8G) 58 26th July 2018 17:17
Indications Idle speed low?? akhil2410 Engines and Transmission (8G) 5 7th June 2017 22:10
Engine Idle speed dropping?! JSOCK Bugs, faults and irritations (8G) 16 6th June 2016 19:49
Tech CTR engine idle speed from cold Dimplyred Engines and Transmission (8G) 23 6th January 2008 15:48
Engine Car idle speed civie Bugs, faults and irritations (8G) 4 4th April 2007 17:47
