Rotrex race kit - Civinfo
 1Likes
post #1 of 45 (permalink) Old 16th June 2014, 12:39 Thread Starter
Rotrex race kit
Thought id share with you my results from my tts rotrex race kit. Got offered 15% off and as i was saving for one anyway i jumped at the chance.
Well happy with the results 418 bhp at the wheels apparently the acceleration is savage, 1st and 2nd just spins the ad08r's up but once you get into third its controllable. Its running 14 psi of boost on a stock engine with a stage 4 comp clutch. http://
The red is the power run before the charger just running flashpro and gruppe m mapped by cpl it was making 236 bhp at the fly
http://
http://
http://
http://
http://
http://
http://
http://
umtomtom is offline
post #2 of 45 (permalink) Old 16th June 2014, 14:32
Warwick1984's Avatar
Car: Type-R GT Milano Red
bet its a proper animal to driver now!
Warwick1984 is offline
post #3 of 45 (permalink) Old 16th June 2014, 14:52 Thread Starter
i haven't stopped smiling since i picked it up, the look on people's faces when you fly past them is priceless. it's on a whole different level now, but as others have said who own charged fd2's it feels like it could handle more power.
would of been dissapointed with a jackson or supersport kit for the money it cost.
umtomtom is offline
post #4 of 45 (permalink) Old 16th June 2014, 15:11
Aye Aye....
DPG87's Avatar
Car: 2009 CTR, Milano
very impressive power mate, hope you enjoy it!
my only reservation is that is a lot of power and boost on a stock bottom end so be careful! (I dont mean to be a killjoy but I wouldnt want to see you blow the bottom end!
DPG87 is offline
post #5 of 45 (permalink) Old 16th June 2014, 16:54
Civinfo's Bulb Supplier
Mr JP's Avatar
Wow great results mate, awsome power at less than 1 bar boost. Hope you have some dry weather to use and abuse it
Mr JP is offline
post #6 of 45 (permalink) Old 16th June 2014, 20:04
Lunar Tick's Avatar
Car: 2008 FD2, Vivid Blue
Very nice - very quick!
Lunar Tick is offline
post #7 of 45 (permalink) Old 17th June 2014, 01:43
#darkside
Andrew Moore's Avatar
Car: 2015 LCI M135i
Nicely done, got similar power here, 417.xx at the wheels on TTS rollers, only at 9psi though on a kraftwerks c30-94. Hellish fast and brings a smile to my face all the time, I can only imagine your grin being just the same
Andrew Moore is offline
post #8 of 45 (permalink) Old 17th June 2014, 19:02 Thread Starter
how is that possible? and why dont you run a bit more boost? had a quick look through your thread and looks a nice build but cant quite figure your engine spec
umtomtom is offline
post #9 of 45 (permalink) Old 10th July 2014, 17:53 Thread Starter
Got a boost gauge to fit today and not quite sure were to plumb the vacuum line in. Been so long since ive had a car with boost.
Was going to plumb it in to the hose coming off the blow off valve as it runs into the side of the inlet manifold and then what seems to be the power steering pump? Didnt know if plumbing in to this would affect how the valve works or not.
umtomtom is offline
post #10 of 45 (permalink) Old 12th July 2014, 00:50 Thread Starter
sorted the gauge finally, what a nightmare slotting a wire through the firewall is. not sure the prosport gauge is too acurate because its been hitting 17 psi in 1st and second when it spins the wheels i guess. still have an in line filter to fit to the vacuum pipe so that might calm things down
[URL="http://[URL=http://s85.photobucket.com/user/TimTom121/media/C9E8018C-7BD5-4704-AA0A-9B15350124EC.jpg.html][/URL]"]http://[URL=http://s85.photobucket.com/user/TimTom121/media/C9E8018C-
umtomtom is offline
post #11 of 45 (permalink) Old 12th July 2014, 09:26
#darkside
Car: 2015 LCI M135i
That's an odd one as I'd of thought any excess boost would be wasted unless it's pre recirc/blow off? (Assuming it makes a difference). Nice looking gauge though
post #12 of 45 (permalink) Old 11th August 2014, 00:33 Thread Starter
had 3 little sessions on cadwell at modified live on saturday. usually a fan of open pitlane but at cadwell sessions seem to work well because of the tight layout of the circuit ? any way had probably the best session ever , the car was untouchable an absolute hooligan on track. ive done caddy before in dc5 but in the fd it was way more a buzz with the boost. the fd2 is so forgiving and neutral in handling it makes easy work on a very technical circuit. wanted to take it easy out there so set my boost warning at12 psi which meant i was shifting around 7000 rpm and when needed i would rev to 8500 hitting 14 psi. im needing better cooling for water and oil and bigger brakes will be on the shopping list soon. i didnt have no fade as i changed fluid last week but i wasnt too heavy with the late braking either. runing on ad08r's at 27 front and 24 rear once warmed up gave loads of confidence. learnt so much from the day from the driving and talking to the drivers afterwards it was an absolute belter of a day. got a chance to speak to the race mad jprocter with his highly strung fd time attack car. dude if i had the cash id be doing the same thing with mine its the best drug ever. might see you at silverstone.
any way link to my last sesh of the day , wasate getting to the grid and started last overtook 15 cars including a drag race down the main straight with a bmw m5 and won. so anyone wondering how a rotrex fd2 goes on track taking it easy here is your answer. enjoy.
umtomtom is offline
Thank You to umtomtom from 3 Users:
post #13 of 45 (permalink) Old 11th August 2014, 08:39
Lunar Tick's Avatar
Enjoyed that - thanks for posting mate Good speed down the long straight btw !
post #14 of 45 (permalink) Old 11th August 2014, 09:44
Clutch pedal guru
hondacivicnut's Avatar
Looks very quick that. Lol at the 205 nearly losing it through Hall Bends.
hondacivicnut is offline
post #15 of 45 (permalink) Old 11th August 2014, 09:46
coste1l's Avatar
Wickedly quick that
coste1l is offline
post #16 of 45 (permalink) Old 11th August 2014, 10:50
davef09's Avatar
Car: 2009(59) CTR,Milano
what a beast! ! looks very nice aswell bud.
davef09 is offline
post #17 of 45 (permalink) Old 11th August 2014, 13:31 Thread Starter
Thanks guys, my best lap time was a 1:50 , if i had forged engine , bigger brakes and slicks etc i could push a lot harder and use it to its full potential. But even as it is its amazing on track. Had a lot people coming over to check what's under the bonnet.
My mate in the black eg was on the grass on the entry to barn nearly causing a pile up , his cars quick with a k swap full cage etc.
any way i thought i was quick till i saw the in car from this. Roger clarks gobstopper 2 beating the lap record of rob haslams superbike time. 1st car ive seen get airborne on the mountain, this car is insane and built to a level iv'e never seen before.
umtomtom is offline
Thank You to umtomtom from 2 Users:
post #18 of 45 (permalink) Old 11th August 2014, 14:04
davef09's Avatar
holy moly!!! thats sick its like a gocart. what power dose that put out?
davef09 is offline
post #19 of 45 (permalink) Old 11th August 2014, 14:10
lazytrev's Avatar
Car: 2008 NHB CTR
Excellent videos, Cadwell looks great need to drive it sometime
lazytrev is offline
post #20 of 45 (permalink) Old 11th August 2014, 14:31 Thread Starter
http://http://
think its about 1000hp. a very special car that.
cadwell is an awesome track my local and my favourite. in a stock type-r it can be frustrating on a couple of corners as in 2nd and 3rd gear choice with the small vtec window you get, but if you have hondata and vtec set at 5000 rpm 3rd gear should be good enough for them. the mountain, barn and mansfield were a pain in my stock dc5 but fantastic in my fd2.
umtomtom is offline
  Civinfo > Civic Type R > FD2
My TTS C30-94 Rotrex kit project! allagios Modification Projects 902 25th July 2018 12:05
Rotrex SC for my FN2 shabsta Type-R 43 19th June 2014 21:00
Rotrex Leepie Modification Projects 81 29th January 2014 20:17
Rotrex C30-94 or Rotrex C38-81 jonno66 General Discussion (8G) 6 31st March 2013 11:27
