Carrying on from THIS started by SUPERTEACH, I want to conduct a survey of owner's experiences with the Honda Auto Stop/Start feature on various Honda cars.
I appreciate this is in the 10G section, but there is no 'General Discussion' topic in the 'All Civics' section. (Admins?)
Right then.
I, and others have problems with the Auto Start/Stop (SS) feature. I have a 2017 1.5 0G Premier Manual. The SS doesn't work as published.
The symptoms are, with the engine/car warmed or cooled so that you don't get the 'failure' due to Temp or A/C icon, the SS consistently fails to stop the engine with the 'Battery' icon being indicated as the reason.
It appears that if after getting the SS 'Battery' error, (credit to DeermarK in the above thread, Post #27 for this) if you switch the engine completely off for a period of 30 seconds, the SS then works as published until you leave the car standing for more that about 30 odd minutes or so, whereby it then fails to work properly again. The engine OFF/WAIT 30 secs/Restart fixes the problem for me 100% of the times (so far) that I have tried it.
Note: It is important to know engine and transmission combination, as the systems most likely are designed and set up different if Manual or Automatic/CVT Transmission etc.
Please only post and state your Honda model and generation if:
a. Your SS works properly as published.
b. or your SS does not work as published but the above 'fix' fixes it
c. or your SS does not work as published but the above 'fix' doesn't fix it
d. or your SS doesn't work properly at initial startup, but you have found an alternative repeatable fix.
Please don't post if:
a. You suspect that if you change so and so, fully charge the battery etc. etc. might fix it. There have been may posts in the linked thread already that suggest stuff that doesn't fix it. DeermarK has had his Voltage Sensor, Battery and ECU changed and a smart battery charger fitted by Honda. None of which fixed it.
b. You are pleased that it doesn't work because it would P you off.
c. You have comments about wear and tear on the starter/engine etc.
as these are irrelevant to my survey.
Thanks in advance for your inputs
Right then.
