Honda Sensing - Disabling steering wheel feedback - Civinfo
 7Likes
  • 1 Post By azc
  • 1 Post By M8TJT
  • 1 Post By ikbenben
  • 1 Post By atom3624
  • 1 Post By Steve_m
post #1 of 19 (permalink) Old 3rd May 2019, 12:57 Thread Starter
Question Honda Sensing - Disabling steering wheel feedback
Is there a way to disable the steering wheel 'feedback' when presumably Honda Sensing is is detecting something and 'waking you up'?
This sometimes happens when on a country road with a varying camber, I get a 'steering wheel symbol' in the HUD and the steering wheel itself shakes from side to side.
stoo is offline
post #2 of 19 (permalink) Old 3rd May 2019, 13:36
azc
azc's Avatar
Car: 2018 1.5 S-Design (CVT)
That is caused by the LKAS system. It can be turned on and off by pressing or holding in the LKAS switch on the panel below the steering wheel.
It works great on motorway and main road but not so well on narrow roads or if road marking are bad.
Sent from my SM-G935F using Tapatalk
azc is offline
post #3 of 19 (permalink) Old 3rd May 2019, 13:57
azc
azc's Avatar
There is also an option under vehecle settings to change it to warning only if u dont want to disable it completly
iMZee likes this.
azc is offline
post #4 of 19 (permalink) Old 3rd May 2019, 14:33
azc
azc's Avatar
How to find the setting on headunit
azc is offline
post #5 of 19 (permalink) Old 3rd May 2019, 14:47
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
Just a slight correction for completeness.
The switch that AZC is indicating in his post #3 pic is not the LKAS switch, it is the Road Departure Mitigation (RDM) switch. (Handbook pp 576)
The Land Keeping Assist System (LKAS) switch (Handbook pp 586) is the R/H bottom switch of the group of cruise control etc. switches on the R/H steering wheel spoke.
Driver Assist setup options are on Handbook pp174.
Having said that, it is of course possible that either the RDM or the LKAS systems are giving you the 'steering wheel symbol' and 'wheel shake' symptoms that you have. But it's deffo one of them.
@azc . Nice set of picks in post #4 mate.
azc likes this.
M8TJT is offline
Thanks to M8TJT from:
azc
post #6 of 19 (permalink) Old 3rd May 2019, 15:00
azc
azc's Avatar
Oh yeah i missed that one. I must check these out to see which one stops the vibration. Id say one does the steering control to keep car in lane and other is the warning system.
azc is offline
post #7 of 19 (permalink) Old 3rd May 2019, 16:38
M8TJT's Avatar
Not quite certain of the difference in operation myself, but the manual suggests that the RD applies the brakes and the LKAS doesn't.
From OP's description of what's happening (on country lanes) i suspect it's the RD. If he switches off LKAS (it's off by default), it must be RD that's giving his symptoms, so 'your' knee level switch will 'do the trick'. And perhaps he has it set to Warning Only to give the icon and wheel shake symptoms.
M8TJT is offline
post #8 of 19 (permalink) Old 3rd May 2019, 23:55
azc
azc's Avatar
Ok so had a play around with this on my way home tonight.
Both systems (LKAS and Lane Mitigation) enable the steering wheel wobble and warning.
If one system is disabled the other will enable the wobble warning.
The only way to stop the wobble and warning is to disable both systems, LKAS on the steering wheel control and also disable Land Mitigation via panel button near drivers knee. Or to change the setting to warning only.
azc is offline
post #9 of 19 (permalink) Old 4th May 2019, 00:01
M8TJT's Avatar
Does setting to 'warning only' remove the wheel shake or just inhibit the braking?
M8TJT is offline
post #10 of 19 (permalink) Old 4th May 2019, 10:10
ikbenben's Avatar
Car: 2017 1.5T Sport +
I disabled both on mine already from the begin I had the car. Sometimes I use the LKAS when I'm scrolling trough my music folders and my eyes aren't 100% on the road.
ikbenben is offline
post #11 of 19 (permalink) Old 4th May 2019, 16:12
M8TJT's Avatar
Strange thing to admit?
M8TJT is offline
post #12 of 19 (permalink) Old 4th May 2019, 16:52
ikbenben's Avatar
This happens almost never so the conclusion is that I almost never use it
Otherwise...switch on LKAS and ACC and let the car drive for you
M8TJT likes this.
ikbenben is offline
post #13 of 19 (permalink) Old 4th May 2019, 19:48
M8TJT's Avatar
But the LKAS keeps nagging you to hold the wheel and put in some sort of steering input after a while
M8TJT is offline
post #14 of 19 (permalink) Old 4th May 2019, 23:55
ikbenben's Avatar
It's not like I'm driving blindly, I do watch the road but only not so focused as to when I'm not searching the music folders.
We're not driving a Tesla
M8TJT likes this.
ikbenben is offline
post #15 of 19 (permalink) Old 6th May 2019, 14:35
atom3624's Avatar
Car: 10G Civic Prestige
Don't forget the Highway Code mentions that in the presence of other vehicles (so admitted that it is not compulsory at all times) you should show your intentions to make a manoeuvre - which changing lanes is.
It annoys me when I'm filtering between lanes, or simply changing into a more convenient one as cars ahead are parked, with nobody to indicate to, so I don't, so it 'wobbles'.
I'm only hoping that Honda drivers aren't opting for the indicator delete option that most BMW, Audi, Merc and Ford Kuga drivers do!!
Al.
M8TJT likes this.
atom3624 is offline
post #16 of 19 (permalink) Old 8th May 2019, 11:22 Thread Starter
Thanks for all of the input. Disabling the LKAS (confirmed by showing as disabled in the HUD) using the button near my knee seems to have stopped this for me.
I note that with the cruise control display mode it always shows LKAS irrespective of me disabling it. Why is this?
stoo is offline
post #17 of 19 (permalink) Old 8th May 2019, 12:19
ikbenben's Avatar
Because the button near your knees is Road Departure Mitigation (RDM) and not LKAS. If you switch on the main ACC it also activates LKAS but it's not switched on unless you press the LKAS button at your steering wheel (same as with the ACC).
stoo likes this.
ikbenben is offline
post #18 of 19 (permalink) Old 8th May 2019, 12:53
Steve_m's Avatar
Car: 2019 CR-V Hybrid SR 2.0i-MMD
The Green LKAS indicator shows that LKAS is ready to use, it is only active once the LKAS steering wheel button is pressed and either outlined or solid white lines appear in the display, the same for ACC, until a speed is set.
If there is a problem with either LKAS or ACC these indicator will be orange and you will more than likely have a main meter warning showing.
Both ACC and LKAS are made ready for use by pressing the MAIN button
stoo likes this.
Steve_m is offline
post #19 of 19 (permalink) Old 25th June 2019, 14:30
seejay's Avatar
type r right?
trying to decide over a fk2 or 8 what happened to point and shot driving all these driving aids are putting me off!
seejay is online now
  Civinfo > 10th Generation Euro Honda Civic (2017 - ) > General Discussion (10G)
Dealers Bring Your Honda Home deal Loxy Buying, Dealers and Servicing 19 5th July 2012 00:15
Type R Road Test Pottsy User Reviews 81 16th January 2012 13:02
Gran Turismo 5 thread (merged) jonathan power Any non Civic chat here please! 454 2nd March 2011 22:06
