Door handle coming loose - Civinfo
 9Likes
Old 19th April 2014, 19:58 Thread Starter
UJU
I've just been washing my Civic when I noticed part of the drivers door handle was coming away from the door slightly.
I'm generally pretty perceptive so I think I would noticed if it had always been like this. I am the only driver of the car so I can't blame someone else for being heavy handed when opening the door (not that this part takes any of the load anyway)
A friend recently had the lock barrel stolen from his BMW, presumably a failed attempt to break in. I'm just a little concerned someone has tried the same with my car, although there are no other signs of damage.
Just wondered if anyone else had come across this or had a possible explanation to put my mind at rest?
UJU is offline
Old 19th April 2014, 20:09
Type-R6's Avatar
I had the same problem mate. Nothing to do with attempted theft.
There a 3 tiny screws that screw into the handle cover and all 3 looked snapped on urs exactly the same as mine.
Get on eBay for a replacement cheap and easy enough to change.
Unless you buy new then there rediculous.
Graham
Type-R6 is offline
Old 19th April 2014, 20:13
Dogfish's Avatar
Car: 2007 2.2 type S GT-T
I too had exactly the same and it was a broken screw. Just removed the door card and replaced broken screw. 20 mins job done. Hope yours is the same and as simple
Dogfish is offline
Old 19th April 2014, 20:17 Thread Starter
UJU
Thanks for your help guys, I'm glad it's just a poor design and not attempted theft. Looks like I'll be dismantling the door tomorrow, if the weather is nice!
Sent from my GT-I9505 using Tapatalk
UJU is offline
Old 19th April 2014, 20:25
burgerking1972's Avatar
Car: TYPE R GT,58 PLATE.
I just reglued mine,sits flush and still feels solid.
burgerking1972 is offline
Old 19th April 2014, 20:26
tres103's Avatar
Car: 2008 CTR, Bronze
all I done was pull it off completely and bond it back on same bond we use to stick windows on buses in with could use something like tiger seal?
tres103 is offline
Old 20th April 2014, 13:15
Matt3905's Avatar
Car: 2007 1.8ES 5Door Millano Red
Hi same as mine just glued it as it was the screw housing that had broken off .
Matt3905 is offline
Old 21st April 2014, 22:05
delta0's Avatar
Car: RX-8 R3, Blue
Popped a couple of balls of epoxy putty in mine. Been holding for over a year now, possibly two.
delta0 is offline
Old 14th May 2014, 17:03
gm1980's Avatar
I am having the same problem. Noticed today. Is coming almost a centimeter appart. The screw holes seem to be broken.
gm1980 is offline
Old 21st May 2014, 09:53
Trabant Dave's Avatar
Car: 2010 Volvo C30 R-Design
I had this issue with mine at least two, maybe three years ago; I glued it using 'Sticks like Sh*t' and by golly it does! No problems since......
Trabant Dave is offline
Old 21st May 2014, 11:54
nab
i've the same problem.. how can i get acess to the door handle screws?
nab is offline
Old 22nd May 2014, 16:03
Forbidden8701's Avatar
Car: FN2 CTR GT
Have to remove door card and the handle mechanism. Easier just to glue it in place.
Sent from my GT-I9300 using Tapatalk
Forbidden8701 is offline
Thanks to Forbidden8701 from:
nab
Old 17th August 2017, 18:57
dimitri9494's Avatar
Hi there today i noticed the same problem. So to replace the screws we need to completely remove the door card from the inside? I trough this were a kind of screws that we put on place and mount the handle cover like fitting it...
Sent from my ALE-L21 using Tapatalk
dimitri9494 is offline
Old 17th August 2017, 21:11
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Replacing the screws is unlikely to help as the plastic they screw into tends to become brittle and break.
Easier/cheaper to glue it back. It sounds naff but it works.
Otherwise trot off for a replacement but 2nd hand may also be brittle.
dimitri9494 likes this.
Farqui is online now
Old 18th August 2017, 09:26
Ex-Pat Geordie!
nturnb's Avatar
Car: 2015 Civic S Navi I-dtec
Same happened and my 8G... Luckily was when I was considering trading in....
nturnb is offline
Old 18th August 2017, 15:22
Yeh seems the best advice is just to glue it in. Easier job and fairly long-lasting.
JazzHands is offline
Old 18th August 2017, 15:44
Neil11's Avatar
Car: 2006 2.2 5door milano red
Hi
Glad i came across this post as i just found mine had come away at the front and suspected attempted theft just the same as others I noticed , anyway I have glued mine with a dab of epoxy where the screw housing is and its solid again!
Thanks it saved an afternoon stripping the door down
Farqui likes this.
Neil11 is offline
Old 19th August 2017, 08:57
Car: 2007 1.8
Another one checking in. Came off loose a month ago. Glued it back on.
We're having a broken handle party here!
Farqui likes this.
jumper852 is offline
Old 19th August 2017, 09:07
cheekee's Avatar
Car: Red 2010 1.8 I-Vtec SE-T
My passenger side did this and the plastic posts the screws screwed into were snapped. Had to glue it back on. Been fine ever since. I used epoxy putty.
cheekee is offline
Old 19th August 2017, 20:28
Today I took the door cover off (2 screws and the right way to do it 5 min). Then I took the door handle off and I figured out the screws holes went damaged...
Bought a epoxy for plastic glue and put the holes in place. Tomorrow I hope it is strong and I will put it back again
Exterior Door handle ljubisa86 Bugs, faults and irritations (8G) 9 2nd June 2017 07:13
Road Noise Something loose in driver's side door? tom619 Bugs, faults and irritations (8G) 14 21st September 2011 22:01
Exterior Loose outer door panel? Jonny 43 Bugs, faults and irritations (8G) 4 25th May 2011 22:36
Recalls passenger door handle is really loose and now wont open deni.babe Bugs, faults and irritations (8G) 0 22nd February 2010 16:14
Exterior loose door handle, poor fuel cap!!! soupyrn Bugs, faults and irritations (8G) 1 21st July 2009 14:44
