200,000 plus club - High mileage Civics - Civinfo
 46Likes
post #1 of 51 (permalink) Old 5th February 2018, 11:31 Thread Starter
Car: 57 2.2 EX 5 door. Royal Blue
My 2.2 CDTI Civic has just ticked over 215,000 miles and I can honestly say it's been the most reliable car I've ever had!
I've owned it since around 100,000 miles and use it every day. I work closer to home now, so gone are the days of 20,000 miles per year, but it just keeps going!
It's still on the original turbo, injectors, dampers, suspension bushes, air con pump, wheel bearings....by 220,000 miles my previous 2002 Golf 150PD had needed all of those replacing.
In my ownership, other than the expected consumables and service items, it's needed:
  • A replacement clutch (but still on original DMF)
  • A boot leak fixing (it was the common crack at the back of the roof gutters)
  • A flash of the ECU to clear a stuttering fault
  • Front drop links and ARB bushes
  • An ABS sensor
  • The DIY fix for the folding mirrors
That's it!
I get the occasional "P2004 Intake Manifold Runner Control Stuck Open" error every 3-6 months, but just clear it with a bluetooth OBD2 reader.
In terms of servicing, it's always been to Honda to get the book stamped (for 20/month for servicing with a courtesy car and free fuel why not) but for other niggles and annoyances and things like ARB bushes, pads & discs, I fix those myself and this forum is a great resource.
In the summer on a long motorway run I can see 54-58 MPG. In the winter on short runs it's more like 42-45 MPG. (Compare that to my Dad's 2017 1.0-litre Petrol Civic, he see's MPG in the 30's on a mixed run!) The 2.2 diesel torque is great for towing.
Anyone with higher miles care to let me know what I might expect as we approach 250,000 miles?
tkop2010, Jon_G, Farqui and 1 others like this.
chrisw_82 is offline
post #2 of 51 (permalink) Old 5th February 2018, 12:05
Civic_1's Avatar
Car: 2014 1.6 iDTEC EX, Silver
I'm roughly 2 years off 200k - currently on 145k. Following done so far since 64k:
1. Rear discs twice. Rear pads three times.
2. Front discs once. Front pads three times.
2. All 4 x shocks
3. Anti-roll bar links and one top mount carrier.
4. Aircon / clock centre screen - resolder due to missing / jumbled characters.
5. Clutch and flywheel still awaiting fitting.
6. May need a new exhaust manifold - waiting for CO detector to confirm
Civic_1 is offline
post #3 of 51 (permalink) Old 5th February 2018, 12:23
Bye bye Honda...
Jon_G's Avatar
Car: Volvo V60 VEA D4 (181)
Originally Posted by Civic_1 View Post
...May need a new exhaust manifold - waiting for CO detector to confirm
Unlike petrol engines, there's hardly any CO in diesel exhaust. So take a negative result with a pinch of salt! It's pretty obvious when there is a crack, the rising black smoke can be seen coming up the rear of the engine on start-up.
My Accord will soon reach 200k miles. Still on the original clutch/DMF, turbo, fuel pump and injectors, but the manifold is cracked and I had to replace the timing chains a few years back. Injectors are noisy under load, particularly with cold fuel.
Jon_G is offline
post #4 of 51 (permalink) Old 5th February 2018, 19:00
Clutch pedal guru
hondacivicnut's Avatar
Mine clicked over to a mere 161k miles yesterday but it still drives very well. I think a lot is due to the owner where mileage is concerned, someone mechanically sympathetic will normally have a car that lasts longer.
Jon_G and Farqui like this.
hondacivicnut is offline
post #5 of 51 (permalink) Old 5th February 2018, 19:56
Clutch pedal guru
Speaking of mileage, it just proves that these STANDARD iCTDi units are immensely reliable. I can remember when HUB was selling his egr blanking plates telling us that if we didn't blank up the egr, our engines will be coked up in no time
post #6 of 51 (permalink) Old 5th February 2018, 20:26
Civic_1's Avatar
LoL - I see the "How to" thread on here and thought mine must be clogged and dirty by now. Think I was on about 120k at the time, stripped it all down for nothing, very clean so it's what people are putting in their cars and how they drive them
Civic_1 is offline
post #7 of 51 (permalink) Old 5th February 2018, 20:34
HUB
HUB's Avatar
Good evening. I am still selling them. Car is on 204k with mapped out and blanked off egr for 100k. I dont regret my decision
Farqui likes this.
HUB is offline
post #8 of 51 (permalink) Old 6th February 2018, 05:18
Clutch pedal guru
Mine remapped WITH wotking EGR. Don't regret my decision
Jon_G likes this.
post #9 of 51 (permalink) Old 6th February 2018, 07:07
Bye bye Honda...
Jon_G's Avatar
I've never blanked my EGR or interfered with its function in any way, and the inlet has remained clean enough.
EGR is an important environmental control feature to minimise NOx production, something which causes asthma in children, so I definitely don't regret my decision.
Vehicle MOT test requirements for diesels are tightening up this year. It's likely that full monitoring of both particulates and NOx will be introduced into the test over the next few years.
Jon_G is offline
post #10 of 51 (permalink) Old 6th February 2018, 07:52
HUB
HUB's Avatar
Over 200k proved by photo
HUB is offline
post #11 of 51 (permalink) Old 6th February 2018, 08:29
Bye bye Honda...
Jon_G's Avatar
Nobody was questioning that figure.
Miles or kilometres?
Jon_G is offline
post #12 of 51 (permalink) Old 6th February 2018, 08:45
HUB
HUB's Avatar
Miles
HUB is offline
post #13 of 51 (permalink) Old 6th February 2018, 08:52
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
With a UK location, not likely to be anything else.
M8TJT is offline
post #14 of 51 (permalink) Old 6th February 2018, 09:00
Bye bye Honda...
Jon_G's Avatar
Did you not realise that foreigner visitors working in the UK often bring their vehicles over here with them?
Farqui and M8TJT like this.
Jon_G is offline
post #15 of 51 (permalink) Old 6th February 2018, 09:07
I've stickied it as it's a good advert.
I don't think I'd like to be bombing around in kph with the speed cameras around.
Jon_G and chrisw_82 like this.
Kremmen is offline
Thanks to Kremmen from:
post #16 of 51 (permalink) Old 6th February 2018, 11:36
HUB
HUB's Avatar
Photo or did not happen??Can we??
HUB is offline
post #17 of 51 (permalink) Old 6th February 2018, 12:00
Bye bye Honda...
Jon_G's Avatar
I'm happy to believe all the rather modest claims made so far in this thread! If we don't trust the claims, then how can we trust the pictures?
More Civinfo high mileage club info here:- http://www.civinfo.com/forum/general...es-merged.html
Farqui likes this.
Jon_G is offline
post #18 of 51 (permalink) Old 6th February 2018, 12:10
HUB
HUB's Avatar
The title is 200k plus club.
HUB is offline
post #19 of 51 (permalink) Old 6th February 2018, 15:24
dimitris82's Avatar
Car: CIVIC TYPE S
I have now 225.000 kilometers and drives like the first time!
Farqui likes this.
dimitris82 is offline
post #20 of 51 (permalink) Old 6th February 2018, 18:52
Clutch pedal guru
I hope they do bring them into the MOT test properly mate. Diesel drivers have been getting away removing emission control devices for too long. Petrol engines get emission tested so diesels should.
Jon_G, Farqui and Wilmo like this.
Very High Mileage R Jason85 Type-R 12 20th June 2016 19:30
Faults High Mileage 1.4 Mr Punch Engines and Transmission (8G) 10 20th December 2011 20:35
100,000 Mile Club... marcwicks General Discussion (8G) 11 30th June 2010 19:50
Other High mileage pete the postie Engines and Transmission (8G) 8 13th March 2010 13:52
High Mileage.... henbury General Discussion (8G) 19 10th February 2008 21:11
