Fk3 2.2 - low power at low rpm - Civinfo
 37Likes
post #1 of 87 (permalink) Old 30th May 2018, 20:55 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
Just bought an FK3 2.2 ...
Problem is, anything below 2500~3000 RPM = virtually no power. When the RPM comes over 2500ish theres a huge surge of power (the power you'd expect) i've just upgraded from a 1.2 clio and the the power feels almost the same below 2500 RPM...
My first thoughts are EGR Valve but the tools I have available won't let me get it off without a fight involving a lot of swearing so i'll be popping over to my uncles tomorrow and try it with his tools.
Does this sound like an EGR Valve issue? - From what I have read EGR would cause hesitation but my problem is like 10% power delivery then 100% after 2500 RPM... EGR? If not, any suggestions?
Getting a P1704 & PGM-FI occasionally but not constant (I do not believe this to be related to the power issue, but hell, it might be)
Knottz is offline
post #2 of 87 (permalink) Old 30th May 2018, 21:43
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Welcome to
The 2.2 does have a bit of a boost at 2.5k rpm but is more noticeable of remapped. Do you know if yours has been mapped?
Fueling might be an issue if the filter hasn't been changed for a few years, or a non Honda filter is fitted.
Knottz likes this.
Farqui is offline
post #3 of 87 (permalink) Old 30th May 2018, 21:51 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
Originally Posted by Farqui View Post
Welcome to
This might help distinguish the fact the power delivered below 2500rpm is not normal. (Anything above 4th gear past 60mph = zero acceleration infact i lose speed and have to drop a gear 5th to 4th etc)
I have no idea if its been mapped. I take it you don't think the PGM-FI / P1704 has anything to do with it then?
Knottz is offline
post #4 of 87 (permalink) Old 30th May 2018, 21:54
Bye bye Honda...
Jon_G's Avatar
Car: Volvo V60 VEA D4 (181)
My first thought is also EGR valve (not closing fully).
Knottz likes this.
Jon_G is offline
post #5 of 87 (permalink) Old 30th May 2018, 21:55
Farqui's Avatar
I had a PGM-FI error after changing the rear lights, to LED's. So need to read up on your codes before suggesting any fixes. I'll try and dig something out for your tomorrow but others may have chimed in by then.
Farqui is offline
post #6 of 87 (permalink) Old 30th May 2018, 21:59 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
Well hopefully I'll be successful in getting it off and cleaned tomorrow, will update about that.
Knottz is offline
post #7 of 87 (permalink) Old 30th May 2018, 22:00 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
From what I've read the PGM-FI is Fuel Injection related but the code p1704 which comes on exactly the same moment is the clutch position sensor which isn't related to fuel at all. Hmm. I'll wait to see what you come up with then thanks pal.
Knottz is offline
post #8 of 87 (permalink) Old 30th May 2018, 22:02
Farqui's Avatar
How many miles has your 2.2 covered?
Farqui is offline
post #9 of 87 (permalink) Old 30th May 2018, 22:04 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
Originally Posted by farqui View Post
how many miles has your 2.2 covered?
a lot. 200,000.
Farqui likes this.
Knottz is offline
post #10 of 87 (permalink) Old 30th May 2018, 22:06
Farqui's Avatar
Originally Posted by Knottz View Post
a lot. 200,000.
Wow, impressive.
I'm interested to hear how sooty your inlet manifold is. See how much goo you can pull out.
Farqui is offline
post #11 of 87 (permalink) Old 30th May 2018, 22:12 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
Wow, impressive.
Interestingly I bought it from a "trader" and it's only had one owner before me. When I had a play with the HFT the previous owners saved three numbers in the phonebook, one of them is "home" I must admit i've been slightly tempted to ring it and ask for details about the car but I feel like it's a rather cheeky move on my part and wouldn't like to cross a line.
The car is in a little bit of bad shape. (I can enjoy something to tamper with and improve on) The passenger side door was stuck shut, the boot was stuck shut (both now working fine - had a long day at scrappies lol) The body is generally okay, needs a new passenger side door handle trim and the engine is in pretty good nick. Service history up until 2015 also so thats not real bad I guess. I got the car dirt cheap.
Hopefully tomorrow proves fruitful and I can get the EGR off and take a look at the intake while i'm at it. I'm just a bit curious where I go from here if the EGR isn't the culprit.
Farqui likes this.
Knottz is offline
post #12 of 87 (permalink) Old 30th May 2018, 23:41
more torque than the mrs
deni.babe's Avatar
egr would be my first to check but I have known the fuel filter to cause issues when was it last changed? the car probably just needs a good service...
Farqui, FergyCiv and Knottz like this.
deni.babe is offline
post #13 of 87 (permalink) Old 31st May 2018, 11:18 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
Yeah when i've got a bit more spare cash i'll do a full service for good measure.
This is my first diesel so this may seem a stupid question but i've noticed when I start the car from cold it idles like 800RPM but any other car ive owned usually idle higher 1200+ ish and slowly lower the idle as the engine warms, do diesels not do this? or maybe this one doesnt?
Knottz is offline
post #14 of 87 (permalink) Old 31st May 2018, 11:27
Clutch pedal guru
hondacivicnut's Avatar
Could be the inlet manifold clogged up, or turbo vanes sticking slightly (including EGR and swirl valve sticking).
Or as said above, it's been remapped.
deni.babe, Farqui and Knottz like this.
hondacivicnut is offline
post #15 of 87 (permalink) Old 31st May 2018, 14:48
Car: 2014 1.6 DTEC 5 Door White
My 2.2 and my 1.6 rarely go on the choke unless it's very cold, my 1.6 starts on the choke at about 8'c, my 2.2 went on the choke at around 5'c but very quickly came off of it
Knottz likes this.
shaintaylor is offline
post #16 of 87 (permalink) Old 31st May 2018, 21:07
Bye bye Honda...
Jon_G's Avatar
In my experience the 2.2 i-CTDi idles bang on 850 RPM hot or cold.
Knottz likes this.
Jon_G is offline
post #17 of 87 (permalink) Old 2nd June 2018, 12:10 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
Well I cleaned the EGR and it wasn't that bad really neither was as far as I could see into the intake and well theres no improvement. One thing I've noticed is a hesitation/misfire right before boost comes on?
https://pasteboard.co/Ho1fshJ.jpg
https://pasteboard.co/Ho1g9XL.jpg
I tried to embed these pictures but the forums not having it, they are in [IMG] Tags but doesn't work.
Knottz is offline
post #18 of 87 (permalink) Old 2nd June 2018, 13:28
Clutch pedal guru
Mine sits at 1100rpm on really cold icy mornings then settles to 850rpm after a minute or so.
deni.babe likes this.
post #19 of 87 (permalink) Old 2nd June 2018, 19:50
Bye bye Honda...
Jon_G's Avatar
Did you actually check that the EGR valve closed completely without delay or sticking by applying a vacuum?
Jon_G is offline
post #20 of 87 (permalink) Old 2nd June 2018, 20:06 Thread Starter
Knottz's Avatar
Car: '07 FN2 CTR
I have nothing lying about that would allow me to do that... i.e a vacuum pump.
What would be normal boost ranges on this engine?
Here's my symptoms as i've now had more time with the car:
  • Poor acceleration below 2500 RPM // 5th/6th gears seem to work from 2100~ RPM (but 6th gear specifically lacks any grunt)
  • Hesitation/Stutter when a sudden increase in throttle, i.e from 10% throttle to 50%+ the car will lose speed momentarily before gaining speed.
Knottz is offline
Remap Low rpm problems/ o2 sensor? BoyGTA Engines and Transmission (8G) 1 13th March 2016 17:38
Low fuel: reduced power? BlackCivic2010 General Discussion (9G) 10 7th March 2016 23:04
Performance Low down power TheTJW Engines and Transmission (8G) 6 6th June 2015 23:36
Other Low heater fan and low revs = engine stall? Donchichi Engines and Transmission (8G) 19 24th March 2013 00:52
Engine Noise at low RPM laluks Bugs, faults and irritations (8G) 8 26th June 2008 06:14
