Is my clutch *****? - Civinfo
 5Likes
  • 2 Post By Das
  • 1 Post By Farqui
  • 1 Post By Das
  • 1 Post By Cheddars
post #1 of 8 (permalink) Old 25th June 2019, 13:34 Thread Starter
Cheddars's Avatar
Car: 2009 1.8
Is my clutch *****?
Ever since I bought this car the clutch biting point has been about 1/3rd off the floor - very low, but I got used to it.
Until today...
At a set of lights with my foot on the clutch and in gear there was a huge crunch, now the biting point is right on the floor and basically undriveable.
Do you guys know what this could be? Has the release bearing just let go?
The car is a 2009 1.8 with 75,000 miles
Cheddars is online now
post #2 of 8 (permalink) Old 25th June 2019, 14:03
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
Id check your not loosing fluid at the Slave cylinder first. If the car is still moving forward ok possibly just the slave thats gone. You can see it if you look down behind the radiator in and around the battery and EGR valve area, you will see a Bleed Nipple and thats on top of the slave. Also the fluid reservoir for it is the small one in front of the brake fluid reservoir, if its gone this will be low on fluid.
Farqui and Cheddars like this.
Das is offline
Thanks to Das from:
post #3 of 8 (permalink) Old 25th June 2019, 14:10
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
What colour us your clutch fluid?
When was it last changed?
Cheddars likes this.
Farqui is offline
Thanks to Farqui from:
post #4 of 8 (permalink) Old 25th June 2019, 14:12 Thread Starter
Cheddars's Avatar
Car: 2009 1.8
Cheers guys,
Forgot to mention, clutch fluid was replaced 3 weeks ago - it made a small difference in clutch feel at the time.
Had a quick look, fluid is still clean and filled to max level, cant see any leaks
post #5 of 8 (permalink) Old 25th June 2019, 14:15
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
Id try bleeding it again, maybe the bleed nipple wasn't tight enough and has let air in.
Farqui likes this.
Das is offline
post #6 of 8 (permalink) Old 25th June 2019, 15:34
cb550's Avatar
Car: 2009 EXGT auto, Audi TT 190
Not one of my previous civics, but a fiat I bought way back had exactly the same thing until it too, eventually gave up the bite point/pedal at the floor. A new master cylinder fixed it.
If the slave is'nt moving full stroke and the system's bled correctly the above's a likely fix.
cb550 is offline
post #7 of 8 (permalink) Old 26th June 2019, 10:48 Thread Starter
Cheddars's Avatar
Car: 2009 1.8
Cheers guys,
Had the mrs pumping the clutch last night - master and slave cylinders appear to move fine, but could be wrong. Cant see any leaks anywhere, it's next to undriveable now.
It's booked in at a garage on saturday for axle bushes, so will get them to have a look, just hope I can limp it around this week.
post #8 of 8 (permalink) Old 1st July 2019, 19:45 Thread Starter
Cheddars's Avatar
Car: 2009 1.8
Garage are replacing the clutch for me, apparently everything else is fine, they said it was the release bearing at fault. Hoping to pick it up tomorrow and fingers crossed working currectly?
Das likes this.
