The "What did you do to your car today?" thread (merged) - Page 109 - Civinfo
 2609Likes
post #2161 of 2484 (permalink) Old 29th April 2019, 21:23
Andy17's Avatar
Car: 2007 1.8 Milano Type S GT
Washed my Type S and then fitted a pair of Heko wind deflectors. Also put my new set of mats in, replaced the worn and holed Civic mats for a set of after-market ones, at less than a quarter of the price of a new set of Honda mats.
deni.babe, Bones126 and dkkirk2016 like this.
Andy17 is offline
post #2162 of 2484 (permalink) Old 30th April 2019, 13:12
Stickers Moderator
Marc S's Avatar
Car: 2007 2.2 EX i-ctdi
Why the need for additional breathers?
Marc S is offline
post #2163 of 2484 (permalink) Old 30th April 2019, 17:40
Karlos's Avatar
Car: Renaultsport Clio 182
I was also wondering what the reason was behind this.
Karlos is offline
post #2164 of 2484 (permalink) Old 2nd May 2019, 20:02
lightningslow's Avatar
Car: 2007 1.8 EX iShift 5DR
Booked the civic in to Honda main dealer to finally get a clutch fitted.
Itís toast. Slipping like mad, HDS says contact point of 8.06mm and coefficient of 870 and jerking.
Also manages to find a set of City pack door protectors in my colour, brand new in the box. What a find!
After al this is done booked it in to the body shop for a side paint job as someoneís keyed my car a while back , have the image pack parts Iíve secured painted and installed.
lightningslow is offline
post #2165 of 2484 (permalink) Old 2nd May 2019, 21:02
FergyCiv's Avatar
Got the A/C recharged today. Icy cool air now coming out of the civic. Hopefully there are no leaks and it stays charged. If it leaks then I'll get UV stuck in it to find it
Sent from my CLT-L09 using Tapatalk
FergyCiv is offline
post #2166 of 2484 (permalink) Old 3rd May 2019, 07:51
There should already have been UV due injected with the recharge
deni.babe and The_b3st like this.
Thanks to lightningslow from:
post #2167 of 2484 (permalink) Old 5th May 2019, 14:07
Cleaned the MAF sensor.
Nice little ring of dirt came off the entire thing.
deni.babe and Bones126 like this.
post #2168 of 2484 (permalink) Old 5th May 2019, 14:26
Karlos's Avatar
Refitted the clock/radio display after it came back from being repaired.
So nice to have it all working properly again, and so much easier to fit than it was to remove!
Karlos is offline
post #2169 of 2484 (permalink) Old 5th May 2019, 17:50
Replaced my wifeís rear brake pads as they were grinding. I couldnít see the reason why when I first took the wheel off as there was quite a bit left on the outer pad so thought it might be a rock stuck between the disc and the disc shield. Having taken the caliper off I worked out the problem; uneven wear of the pads. This was only on the offside the near side was nice even wear. Does anyone know what may have caused this uneven wear to the pads?
tkop2010 is offline
post #2170 of 2484 (permalink) Old 5th May 2019, 17:55
Karlos's Avatar
Sticking sliders, I’d guess.
dkkirk2016 likes this.
Karlos is offline
Thanks to Karlos from:
post #2171 of 2484 (permalink) Old 5th May 2019, 18:16
Thanks Karlos. I thought so too and used a smear of copper grease when put them back together. I’ll report back after the next change of pads.
tkop2010 is offline
post #2172 of 2484 (permalink) Old 5th May 2019, 19:21
FergyCiv's Avatar
Copper grease won't do the trick for them. Will eventually wear out and cause your sliders to seize up. You are better with a grease compatible with the rubber boot as well as the sliders such as red rubber grease or a good silicone based grease. I would take that cooper grease out and clean the sliders up. Apply some of the above.
Karlos, tkop2010, Farqui and 3 others like this.
FergyCiv is offline
post #2173 of 2484 (permalink) Old 5th May 2019, 19:29
dkkirk2016's Avatar
Car: 2007 1.8se vtec i 5 door gal
I use ep3 grease ...
Sent from my FIG-LX1 using Tapatalk
dkkirk2016 is online now
post #2174 of 2484 (permalink) Old 5th May 2019, 19:32
Oh, Iíve always used copper grease around the brakes. Iíll see how much time I have tomorrow and if I get a chance in the evening Iíll take them apart again, clean out the copper grease and apply some red rubber grease. Thank you for the advice!
tkop2010 is offline
post #2175 of 2484 (permalink) Old 5th May 2019, 21:37
Copper grease on the back of your pads and edges and lithium grease for the slider pins. The lithium grease is meant to be the best as won't wear out or damage the rubber boot. Any other grease including copper will eventually damage the boot for the sliders.
Sent from my Letv X500 using Tapatalk
tkop2010, Farqui and Bones126 like this.
reganlives is offline
post #2176 of 2484 (permalink) Old 5th May 2019, 22:43
Thats right i been told that copper grease affects rubber so best to use ceratec instead
Sent from my SM-G960F using Tapatalk
Farqui likes this.
eagle123 is offline
post #2177 of 2484 (permalink) Old 6th May 2019, 11:41
Cleaned the car externally for he first time in theee months.
Need to wait until itís a slight bit warmed until I can do a full decon and restore the plastics that have gone funny again. No matter what I do hard water ruins them!
post #2178 of 2484 (permalink) Old 6th May 2019, 11:48
dkkirk2016's Avatar
It does it cracks it ..
post #2179 of 2484 (permalink) Old 6th May 2019, 13:15
Wilmo's Avatar
Took the spoiler off the FN2 and drilled a small hole at each end to let the water out.
lightningslow and Bones126 like this.
Wilmo is offline
post #2180 of 2484 (permalink) Old 7th May 2019, 14:33
Booked in the car at Honda Chelmsford for major works.
Clutch kit, input shaft bearing (15 minutes extra work while the box is off, good preventative maintenance) and a set of shaft seals on the box.
Hoping that's because the clutch is worn that is hasn't worn down to rivets and necessitates a new flywheel as well. Some slippage but not loads and ints infrequent so I'm hopeful it's fine.
They'll have the car for the best part of a week making sure everything is fine and I'll have to make do with a Jazz which i hate with a passion.
On the plus side, cleaning the MAF has certainly improved pickup and economy a tremendous scale. Butt dyno and fuel economy on my standard routes via computer proves it. Idle is now down to a smooth 700rpm from 780.
deni.babe, FergyCiv and Bones126 like this.
Gran Turismo 5 thread (merged) jonathan power Any non Civic chat here please! 454 2nd March 2011 22:06
thread icons (merged) shrimpman Site suggestions, feedback and rules 16 10th June 2007 17:28
Jokes Thread.... (MERGED) Koos Holswilder Any non Civic chat here please! 23 25th February 2007 19:51
Satisfaction Dissatisfaction thread - merged from many others Topcat Bugs, faults and irritations (8G) 84 22nd December 2006 19:23
