The "What did you do to your car today?" thread (merged) - Page 114 - Civinfo
 2590Likes
post #2261 of 2474 (permalink) Old 17th May 2019, 19:38
dkkirk2016's Avatar
Car: 2007 1.8se vtec i 5 door gal
Originally Posted by Fergiem123 View Post
Fitted wheel spacers all round
Wow what spacer are them ?
Sent from my FIG-LX1 using Tapatalk
dkkirk2016 is offline
post #2262 of 2474 (permalink) Old 17th May 2019, 19:42
Fergiem123's Avatar
15mm front and 20mm rear.
Wheels are 5mm extra offset so all in car is 20mm and 25mm wider
Bones126 and dkkirk2016 like this.
Fergiem123 is offline
Thanks to Fergiem123 from:
post #2263 of 2474 (permalink) Old 17th May 2019, 19:46
Maurice63's Avatar
Car: 8G TypeR
They fill the arches better than 15 & 20 that's for sure ' looking good
Maurice63 is offline
post #2264 of 2474 (permalink) Old 17th May 2019, 19:51
Fergiem123's Avatar
Plenty of room for my Brembos now
post #2265 of 2474 (permalink) Old 18th May 2019, 15:55
piasek's Avatar
Washed the old girl. Iím always amazed how good Bilt Hamber wheel cleaner is
piasek is offline
post #2266 of 2474 (permalink) Old 18th May 2019, 22:39
Fergiem123's Avatar
I always hated doing the reactivate cleaning of my wheels.
I keep them good with a decent coat of poor boys now which helps just wash off the grime and brake dust
post #2267 of 2474 (permalink) Old 18th May 2019, 22:40
dkkirk2016's Avatar
Ow crap lol so I don't need to keep spraying bilt hamber on the every time I clean the car then! Just wash the whole thing and done??
post #2268 of 2474 (permalink) Old 18th May 2019, 22:48
Fergiem123's Avatar
Itís a personal choice to be fair.
Wheel cleaners are good but donít prevent the build up of crap.
Barriers like hard wax are more work but help in the long run
The poor boys I use is easy on easy off and much better during interim (jet wash) cleaning
post #2269 of 2474 (permalink) Old 18th May 2019, 23:49
piasek's Avatar
This is correct, unless your car is a workhorse and have alloys curbed like mine
piasek is offline
Thanks to piasek from:
post #2270 of 2474 (permalink) Old 19th May 2019, 09:16
veehexx's Avatar
Car: 2015 CTR FK2
i've used the poorboys wheel sealer (pink stuff in a tub) and didnt really find it much use after one or two washes. ended up going through the same cleaning process.
now i've admitted defeat and just go through a 6/12month Iron-X with ValetPro bilberry wheel cleaner along with an agitator brush for the worst bits and wheel woolies for the rest.
what 'ave i done to mine?
the usual 'quick' wash; snow foam,2bucket hand wash and microfibre drying.
also FINALLY found a knocking from suspension area thats been bugging me for months. nut tightened but new parts on order as the grease seal is split anyway.
lightningslow likes this.
veehexx is offline
Thanks to veehexx from:
post #2271 of 2474 (permalink) Old 19th May 2019, 15:45
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
I use BH Korrosol on my Wheels about once a month or so, in between I just use BH Surfex HD to do a "normal" clean. I had a guy stop and ask If i had just had my wheels refurbed after using the Korrosol on them, it really does get the ingrained dirt out of them. TBH its the best non acidic wheel cleaner Ive ever used.
Das is offline
Thanks to Das from:
post #2272 of 2474 (permalink) Old 19th May 2019, 16:12
Benjy's Avatar
Car: 2008 Alabaster CTR
Fixed my passenger side door handle back on as my little girl decided it would look better on the floor........
deni.babe, flashy, M8TJT and 2 others like this.
Benjy is offline
post #2273 of 2474 (permalink) Old 20th May 2019, 18:32
Replaced the fuel filter boy was i due for punishment.
Removed the battery tray air box the air box holder and remoced the electrical connectors they were fiddly to remove but eventually managed to released them
However i couldnt removed the bolts i managed to remove the black carrier bolt holding the filter but got stuck on removing another bolt hidden under the carrier.
Gave up popped everything back in then a few days called my mate over to assist.
The whole job took 2 hours.
Most of the time took in inserting the 2nd carrierbolt which was in a inconvenent place.
Eventually got that out removed the filter which was a genuine honda filter replaced with genuine honda
When i emptied the old filter the deisel fuel was yellow
Wonder if its bacteria .. result car is quieter and smoother it was worth it unfortunately i dropped a little extension bar and it in where the plastic cover is ....
Sent from my SM-G960F using Tapatalk
deni.babe likes this.
eagle123 is offline
post #2274 of 2474 (permalink) Old 20th May 2019, 20:47
Skomaz's Avatar
Car: 2006 2.2 ctdi Sport
I did three cars yesterday (Siwft, MX5 and Octavia Estate) - rinse, snow foam, rinse, snowfoam, wash mitt, dry - three times! And I nearly ended up doing a fourth when a friend called round with her manked up CRV (she declined my offer).
No wonder I ache today...
Skomaz is offline
post #2275 of 2474 (permalink) Old 21st May 2019, 07:49
Stickers Moderator
Marc S's Avatar
Car: 2007 2.2 EX i-ctdi
Good old Civic passed the MoT with no advisories for the fifth year running. Not sure how much of that is down to good maintenance and how much is just the car...but I'll take it!
Marc S is offline
post #2276 of 2474 (permalink) Old 21st May 2019, 10:42
Maurice63's Avatar
Car: 8G TypeR
Way to go mate for another year !
post #2277 of 2474 (permalink) Old 21st May 2019, 13:54
lightningslow's Avatar
Car: 2007 1.8 EX iShift 5DR
Cars in with Honda CHlemsford, flywheel fine, clutch kit being done as we speak with new shaft seals. £800 all in with tracking.
Hurts a little but being as no one else is remotely competitive on the iShift clutch changes, its money well spent.
lightningslow is offline
post #2278 of 2474 (permalink) Old 21st May 2019, 17:19
more torque than the mrs
deni.babe's Avatar
at least you have their guarantee it will be done right...
deni.babe is offline
post #2279 of 2474 (permalink) Old 21st May 2019, 17:23
Yeah pretty much.
Also picked up a new set of top mount bearings as theyíve gone again. £80 for the pair which isnít bad. Squeak is doing my bloody head in!
After that, new brake pads going in. TRW pads as Iíve found out are made out of similar stuff to eBC green stuff as theyíre ceramic based and also have already been bedded in. £60 for both sets of rear and fronts and Iím good with that. Less dust and better braking is a - ok.
Now if I can just find my bleeding hose and bottle ....
post #2280 of 2474 (permalink) Old 21st May 2019, 20:17
veehexx's Avatar
Car: 2015 CTR FK2
so weird but productive night.... fitted new tie bar since the original bars boots were damaged.
also fixed a problem i've had since the car left factory - steering wheel alignment. thanks to the dealer not lining the steering column correctly when i had clutch done last November - was one spline out from when it went it - it doubled the difference from being straight. EURIKA! left factory being 1 spline out. easy fix; move steering column 2 splines back, and wheel is now perfect. Its been to dealer at least twice to fix the specific issue, and 2 alignment places for general work but no-one has been able to fix it.
going to be weird not having something wrong with the car to work on every weekend now.
FergyCiv likes this.
veehexx is offline
Gran Turismo 5 thread (merged) jonathan power Any non Civic chat here please! 454 2nd March 2011 22:06
thread icons (merged) shrimpman Site suggestions, feedback and rules 16 10th June 2007 17:28
Jokes Thread.... (MERGED) Koos Holswilder Any non Civic chat here please! 23 25th February 2007 19:51
Satisfaction Dissatisfaction thread - merged from many others Topcat Bugs, faults and irritations (8G) 84 22nd December 2006 19:23
