Engine oil for 1.8 petrol - Civinfo
post #1 of 9 (permalink) Old 16th August 2018, 07:28 Thread Starter
Highpeakhonda's Avatar
Car: 2012 1.8 IVTEC EX Milano red
Hi all I'm going to change my engine oil in the next month or so as I've owned the car nearly 6 months. I purchased the car from a Mazda dealer. They gave it a service but I'm not sure that they used the correct oil. Anyway I've seen some mannol 0w20 on eBay for 22 pounds for 4 liters. Just wanted to ask if anyone else has used this brand of oil. It seems quite cheap for 0w20 oil.
Highpeakhonda is offline
post #2 of 9 (permalink) Old 16th August 2018, 15:13
Raeman's Avatar
Car: 2012 Civic 1.8 se Silver
5W/30 in mine, thatís what Honda have put in at services and what I top up with.
Raeman is offline
post #3 of 9 (permalink) Old 16th August 2018, 18:09
Car: 2006 1.8 ES petrol v-tech
Yep 5/30 fully synthetic is the correct oil.
painter is offline
post #4 of 9 (permalink) Old 16th August 2018, 19:01
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
IIRC Honda say you can use 0/20, 0/30, 0/40 and 5/30. 0/30 is what they are filled with at the factory. Castrol, Mobil 1 and Opie Oils all recommend 0/30 too.
Das is offline
post #5 of 9 (permalink) Old 16th August 2018, 21:18 Thread Starter
So I can use 5w30 fully synthetic.
post #6 of 9 (permalink) Old 16th August 2018, 21:25
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
Yes.
Das is offline
post #7 of 9 (permalink) Old 23rd August 2018, 12:18 Thread Starter
Decided to buy the oil and filter from Cox honda Mobil 0w20 oil. For the sake of 20 pounds or so id rather use genuine parts and quality oil.
Last edited by Highpeakhonda; 23rd August 2018 at 16:42. Reason: Wrong word in the text.
post #8 of 9 (permalink) Old 23rd August 2018, 12:31
Earth Dreams :)
Higgo8's Avatar
Car: 2017 CTR GT
You know it makes sense.. plus it will have the same additives etc as when Honda did the validation work with the engine..
Higgo8 is offline
post #9 of 9 (permalink) Old 24th August 2018, 10:25 Thread Starter
It does make sense given the price difference is so small between genuine parts and pattern parts. Especially as I plan to keep this one for a good few years. Got the discount added from Cox too.
Honda Civic mk8 2006 56 plate 1.8 petrol semi auto which engine oil? THE_AKTA General Discussion (8G) 0 2nd August 2016 17:30
Engine Oil Pumps/ Top engine oil change WhiskyDelta General Discussion (8G) 15 25th October 2014 18:34
Oil consumption, oil reading, oil use, oil warning light... stefhuk Type-R 5 29th August 2013 16:23
Oil Engine oil smells of petrol ash_rage Engines and Transmission (8G) 2 9th September 2010 18:32
Oil using "Turbo Diesel" oil in a petrol engine Raldanash Engines and Transmission (8G) 2 28th May 2008 20:00
