2-Step Acceleration Pedal - Civinfo
 1Likes
  • 1 Post By Steve_m
post #1 of 6 (permalink) Old 27th November 2018, 08:06 Thread Starter
Hi, new 9th Gen Civic owner here...
I found out my newly purchased 65 plate Civic SR 1.8 cvt has a two step accelerator pedal completely by chance.
I wasn’t told this by the salesperson or in further reading of manual or online searches.
When pedal seems like it’s fully pressed, there is an extra bit of travel (almost like a switch) then the car revs go high and it gets very sporty. 😉
Is this just a known thing on Hondas? I’ve never owned a car before that has one. Is it just a cvt automatic thing?
Lozgriff is offline
post #2 of 6 (permalink) Old 27th November 2018, 08:27
Car: MY13 1.8 EX Auto
Eco display Eco display
That's i-VTEC and has been on Honda's for decades now.
Kremmen is offline
post #3 of 6 (permalink) Old 27th November 2018, 08:58
Haltamer's Avatar
You've probably got the car in eco mode?
On the petrol models, this changes throttle response, meaning you get less go for the same press- when you go to WOT (Wide open throttle), the throttle response damping is overridden to give you maximum performance; In fact, some German marques even disable certain ancillaries at WOT to increase engine power output to the wheels.
Try pressing the Eco Button on the right (You'll see "ECO OFF" on the I-Mid, and a green leaf light in the fuel gauge will switch off.) - This will give you a far more linear throttle response.
Edit:
Given the fact you have a CVT, and RPM's are jumping up, you're also tripping a kickdown. With regard to RPM on these engines, think in three steps -
0 - 3500RPM the engine runs with a single intake valve per cylinder.
3500 - ~5600RPM you've got both intake valves, giving you good performance.
~5600RPM - The end ( ) you're running in performance VTEC, which alters valve lift and timing
Haltamer is offline
post #4 of 6 (permalink) Old 27th November 2018, 19:29
Steve_m's Avatar
Car: 2019 Civic 5D 1.5 Sport+
Its just the AT kick down detent. Without going past it there is no gear ratio change, go past and the gear ratio will significantly change giving additional acceleration by a down change as you would in a manual.
Haltamer likes this.
Steve_m is offline
post #5 of 6 (permalink) Old 27th November 2018, 21:49 Thread Starter
Makes sense! Thanks for the info
Lozgriff is offline
post #6 of 6 (permalink) Old 27th November 2018, 22:10
cb550's Avatar
Car: 2009 EXGT auto, Audi TT 190
If it's a UK car 1.8 auto it'll be a 5 speed torque converter auto gearbox. The continuous variable transmission (cvt) came along with the 10g Civic.
As already explained, the 5 speed transmission drops down one or more gears when the throttle pedal's 'floored' (kickdown)
cb550 is offline
clutch damper by pass step by step awob1973 General Discussion (8G) 3 31st March 2018 21:29
Servicing Oil and filter step by step? yates Engines and Transmission (8G) 3 28th June 2013 19:09
Other Spraying your wheel rotors - Step by Step bryte1 Wheels, Tyres, Suspension and Brakes (8G) 18 11th May 2011 20:14
Whats your procedure step by step to your weekly wash? borse2010 Cleaning 41 9th April 2011 19:06
AG Super resign polish or Mequires Step 1 & Step 2 gm1980 Cleaning 3 8th August 2010 10:19
