2012 EXGT HID Headlight adapters for Europe - Civinfo
post #1 of 11 (permalink) Old 17th July 2012, 15:21 Thread Starter
doomed's Avatar
Car: Gen 9 1.8 EXGT Crystal BLACK
Does anyone know how to convert HID headlight on a 9th Gen EXGT for driving in Europe? I have seen the Eurolite instruction leaflet & it only refers to non-HID lights
doomed is offline
post #2 of 11 (permalink) Old 17th July 2012, 15:25
Grayfox's Avatar
Car: '11 Impreza R Special
Eco display Eco display
What?
Are you wanting to add HIDs to a non EX GT model?
Are you wanting a device that converts the H7 fitting to a D2R HID fitting?
HIDs come in a kit, the kit has ballasts which take the 12V and pump it to a higher voltage which then goes to the HID bulbs which make the light.
You can just plug a HID bulb into a 12V system, it will not work.
Or more info is needed on what you want than just "CAN".
To get a HID kit, you will firstly need to buy a H7R not a H7, but a H7R kit.
This kit will upgrade you to HIDs to be used with the reflective housings.
Mr JP sells them for the 8th gen so he should be able to help you with the 9th gen.
That is if the H7R will fit it.
Last edited by Grayfox; 17th July 2012 at 15:30. Reason: Updated post to reflect OPs post.
Grayfox is offline
Thanks to Grayfox from:
post #3 of 11 (permalink) Old 17th July 2012, 15:48
無限 Unlimited
Laney's Avatar
Car: 59 Mugenised CTR
Originally Posted by Grayfox View Post
What?
I think Doomed means changing the direction of the dipped beam. It's down and to the left on RHD cars. Down and to the right on LHD cars.
@ Doomed - I can't find a website for eurolite but I'd just fit them as per non-HID instructions
Laney is offline
post #4 of 11 (permalink) Old 17th July 2012, 16:06 Thread Starter
doomed's Avatar
Thanks Laney
But my previous civic was a 59 CTR GT and the Eurolite positioning on those HID lights were different to the std Civic.
doomed is offline
post #5 of 11 (permalink) Old 17th July 2012, 16:43
無限 Unlimited
Laney's Avatar
there might be markings on the headlight case itself as to where the centre of the beam passes through? otherwise trial and error fitting? - sorry I'm of no further help
Laney is offline
Thanks to Laney from:
post #6 of 11 (permalink) Old 17th July 2012, 18:59
nickp8's Avatar
Check your owners manual or see if you have the adjustment on the headlight as per the 8th gen. http://www.civinfo.com/forum/how/306...eadlights.html
nickp8 is offline
Thanks to nickp8 from:
post #7 of 11 (permalink) Old 18th July 2012, 00:54
iAndyF's Avatar
Car: 2012 i-DTEC EX GT
The “Models with high voltage discharge tube bulbs” note on the right hand side of page 160 in the handbook states: “The headlights are suitable for both right and left hand traffic. You do not need to alter the headlight beam distribution.”
Under “Models fitted with halogen bulbs” it suggests that “You may need to alter the headlight beam distribution.” It then refers you to page 295.
Personally I would ask the dealer for advice / clarification on this before taking the car to Europe.
iAndyF is offline
Thanks to iAndyF from:
post #8 of 11 (permalink) Old 18th July 2012, 07:52
Bog
Bog's Avatar
Car: 2016 CR-V 1.6 160 4WD
That's interesting... not sure how that works, but would a 'Continental' police officer understand that or would he/she be expecting to see the adaptors?
Bog is offline
post #9 of 11 (permalink) Old 18th July 2012, 09:46
...............Daedalus
mpn_daedalus's Avatar
Car: CW Type R No. 460
As long as your lights aren't glaring them, would they care?
Sent from my Sony Xperia S using Tapatalk 2
mpn_daedalus is offline
post #10 of 11 (permalink) Old 19th July 2012, 01:42
Alwaysblack's Avatar
Car: 2012 2.2 EX GT Crystal Black
I'd put some on before leaving, unless you speak fluent French and convince them that they are automatique!
Alwaysblack is offline
post #11 of 11 (permalink) Old 19th July 2012, 16:37
iAndyF's Avatar
I don’t know how it would work either, so can only assume that it’s something to do with the beam pattern produced by HID lighting. That’s why I would ask the dealer for confirmation of what it states in the handbook before driving on the continent.
iAndyF is offline
JAE 2012 / Mods 2012 / "Sale of the Century" ... J. Derek Riddell England Midlands 72 4th September 2012 20:40
Accord 2012 vs Civic 2012 jonis General Discussion (9G) 5 25th September 2011 20:41
HID Headlight Keeps Going Out? liamcalland Lights (8G) 6 25th September 2010 07:05
