2010 CRV prospects - Civinfo
post #1 of 229 (permalink) Old 5th April 2009, 08:05 Thread Starter
Stef's Avatar
Car: 13 CRV / 14 Accord / 04 S2K
2010 CRV prospects
What I would like and not like on the 2010 CRV, since I plan to have one in 2010.
Most probably the IDTEC will be mounted for 2010
I like the 150hp, but do not like the extra noise the IDTEC produces (tested in the Accord)
The Auto gearbox will be available, since the IDTEC will hit Australia in the CRV, this is good, but auto grearbox=lower economy.
I think also they will colour code the lower bumper and wheel arch.
This I would HATE, and would even try to get a 2009 model with the ICTDI.
Probably it will also get the tyre pressure monitor, this is a must have! It comes standard in the US since 2007.
Hope the sunroof will be available like the US version.
Glass roof is nice, but higher wind noise and heated cabin in the sun.
Sunroof is more practical.
Hope it also get the beige fabric interiour (Available in France and US now)
Stef is offline
post #2 of 229 (permalink) Old 5th April 2009, 08:43
AoS
AoS's Avatar
Car: 2013 2.0 CR-V, Passion Red
Eco display Eco display
It's funny because I'm exactly in the same situation as you are.
I own a 2005 i-CTDI, tried the new Accord i-DTEC and hated the noise ... so, if I still go for the diesel, I'm considering buying one of the last i-CTDI CR-V's (2009 model then). As you said, auto gearbox on the i-DTEC is probably nice but it does increase the bill even more and the fuel consumption is quite disappointing (at least on the Accord).
Has anybody tried an i-DTEC Accord with 5000 or 10000 miles to check if the noise goes down a little bit?
I wonder how the i-DTEC CR-V will compare to the i-CTDI CR-V in terms of economy. The Accord didn't improve its fuel economy when switching to i-DTEC ... but, at the same time, it was a completely new model (wider, ...).
Regarding the colour coded bumper, I think the same ... at least on the Executive model and I will try to avoid it as well.
For the equipment, I doubt that we will get the sunroof in Europe ... I would like it as well but I think it's probably more expensive for Honda to produce cars with metal/sunroof & glass roof and Honda seems to believe that European prefer the glass roof
One thing that will be available on the 2010 and I would be missing if I get a 2009 model is the USB port to the audio system. I swapped the cheap OEM radio on my 2005 by a JVC one with USB port. Stick a 4GB USB key full of mp3 in there and you have hours of music and a radio displaying mp3 tags. No such thing is available on the 2009 unless you take the GPS option ... which I don't want to (just bought a Tomtom Go 930T).
Some other new features I believe that the 2010 model would get:
- LKAS ... to join CMBS & ACC
- led taillights
- 4 parking sensors instead of 2 in the front
Greetings from a belgian living in Switzerland
AoS is offline
post #3 of 229 (permalink) Old 5th April 2009, 09:03
Munro's Avatar
I guess the drive for a higher fuel economy in the new engine means they are using higher injection pressures and compression ratios - hence the noise.
The present civic diesel engine is the only diesel I have considered buying because of its relative refinement.
Munro is offline
post #4 of 229 (permalink) Old 5th April 2009, 10:21
AoS
AoS's Avatar
They went from a 1600 bar common rail system using solenoid injectors to an 1800 bar one using piezo-injectors able to provide more precise, multi-stage injections.
Compression ratio is 16.7:1 for the i-CTDI and 16.3:1 for the i-DTEC ... so this one is a litte bit lower.
AoS is offline
post #5 of 229 (permalink) Old 5th April 2009, 10:34 Thread Starter
Stef's Avatar
Looking at the engine bay,
You can see why the new engine is more noisy
They just saved on insulating cap...
I gues get a 09 by the end of the year for a good price, then may be chip it to 160HP could be a better deal...
Stef is offline
post #6 of 229 (permalink) Old 5th April 2009, 10:43
Car: Jag XF 3.0
I think the reason for the extra noise on the Euro V diesels is because you can't use so many pre-ignition squirts (that are there just to reduce the knock). The iDTEC also suffers from induction noise, because the engine is now fitted backwards (the inlet manifold is at the rear, by the bulkhead, and the turbo and that great big can of beans is at the front).
I have been told that since I tested the Accord i-DTEC there have been software improvements to reduce the rattle.
And the front of the engine with the bean can (DPF) removed:
Pottsy is offline
post #7 of 229 (permalink) Old 5th April 2009, 10:54 Thread Starter
Stef's Avatar
I test drove the Accord but it was a new car. Engine noise was allmost like in my Civic. By far not as good as our 05 CRV.
Stef is offline
post #8 of 229 (permalink) Old 5th April 2009, 10:59 Thread Starter
Stef's Avatar
Thanks for this info Pottsy, this explains a lot!
That is probably why they could not add more insulation cap material, it would heat up... I think.
Stef is offline
post #9 of 229 (permalink) Old 5th April 2009, 12:41
Nice Guy!
Brodick's Avatar
Car: Volvo V40, D4, Se Lux
well, well I think that full colour coding will work Landrover have done this with some of the freelander models and the facelifted disco has more colour coding (nothing wrong with it)
I will certainly be test driving a 2010 CR-V I-dtec with autobox ( if it happens)
Brodick is offline
post #10 of 229 (permalink) Old 5th April 2009, 17:12
AoS
AoS's Avatar
The previous 2 generations of CR-V also had full colour coding after their "facelift". It is working but it's more subject to have your paintwork damaged.
That's why I live to have the most exposed parts unpainted.
AoS is offline
post #11 of 229 (permalink) Old 5th April 2009, 17:22
AoS
AoS's Avatar
Yes, it must be something with the Euro V because I was told it's the same on the Peugeot/Citroen 2.0 HDI engine ... the new Euro5 140hp makes more noise than the old Euro4 136hp one
It's strange because if you look at the exhaust emission figures of the i-CTDI, it should be able to meet the Euro5 regulations with a DPF but I may be missing something.
Same thing for the 2.0 i-VTEC engine on the CR-V. It does meet the Euro4 but if you look at the figures, it's under the Euro5 ones
When did you testdrive it? I drove the Accord i-DTEC in January of this year so it wasn't one of the first model. On top of that, I had an appointment with the dealer for this test and, when I arrived, the car had already its engine running ... to warm it up. So I didn't hear the noise when it was cold
AoS is offline
post #12 of 229 (permalink) Old 5th April 2009, 18:05
Nice Guy!
Brodick's Avatar
Only the top spec have received full colour coding
lower spec models such as SE and SE sport models have not. (certainly in the UK.)
Brodick is offline
post #13 of 229 (permalink) Old 5th April 2009, 18:15
Car: Jag XF 3.0
When did you testdrive it? I drove the Accord i-DTEC in January of this year ...
http://www.civinfo.com/forum/honda-a...7-vs-09-a.html
Pottsy is offline
post #14 of 229 (permalink) Old 5th April 2009, 18:26
AoS
AoS's Avatar
Yes but I like the EX one .... glass roof, parking sensors, privacy glass, better audio, HID
I don't care about leather and would prefer 17" wheels but unfortunately you cannot get an Elegance + Light&Sun pack in Switzerland
AoS is offline
post #15 of 229 (permalink) Old 6th April 2009, 11:58 Thread Starter
Stef's Avatar
Pottsy, how would you compare your new CRV and the Accord
Engine:
Road noise:
Gear shift:
Suspension:
Stef is offline
post #16 of 229 (permalink) Old 6th April 2009, 12:43
Car: Jag XF 3.0
Out of ten (off the top of my head):
Civic09 CRV07 Accord Sp/GT09 Accord
Engine noise78105
Engine smoothness98103
Performance9788
Suspension precision7699
Suspension suppleness3998
Gearchange quality8888
Road noise49810
Space81076
HiFi41089
Economy8597
Looks89710
TOTAL75899383
A bit unfair on the CRV as it only has 400 miles on it. The engine needs running in, but it does that occasional "pinking" noise on light throttle that newer engines tend to do (much like the 09 2.2 Civic I borrowed did).
Pottsy is offline
post #17 of 229 (permalink) Old 6th April 2009, 16:28 Thread Starter
Stef's Avatar
Nice overview Pottsy, thanks a lot!
Engine power is of course relative, since the weight of the cars is different.
Engine power"feel" should be better to describe I think.
Stef is offline
post #18 of 229 (permalink) Old 6th April 2009, 16:39
Car: Jag XF 3.0
Changed it to performance!
Pottsy is offline
post #19 of 229 (permalink) Old 6th April 2009, 17:03
Car: Jag XF 3.0
And added a couple of extra lines...
Pottsy is offline
post #20 of 229 (permalink) Old 6th April 2009, 18:58 Thread Starter
Stef's Avatar
Nice, I think this overview is spot on!
Stef is offline
  Civinfo > Other Hondas > Honda CR-V
New 2010 Civic ChillTypeR 2009 Civic (8G) 247 6th July 2010 17:19
Honda CR-Z:hybrid sports car at the end of 2010 fabian Honda CR-Z 40 31st July 2009 15:36
Insight 2010 leaked brochure ante00 Hybrid 2 24th January 2009 22:53
2010 World Cup qualifiers Sekhmet Any non Civic chat here please! 3 9th September 2008 06:11
