2006 1.4 Jazz washers - Civinfo
post #1 of 5 (permalink) Old 25th August 2013, 18:21 Thread Starter
bonzo's Avatar
Washers have packed up on wife's car (front and back) can't seem to be able to locate the fuse,,,,, that's if there is a separate one for the washers.
If not can I assume that if the wipers are working then it must be the motor and not a fuse problem?
bonzo is offline
post #2 of 5 (permalink) Old 5th January 2014, 15:59
Car: 2013 CR-V EX Polished Metal
Funny, I just came on to ask the same question.
Did you find out if the front washers are on a separate fuse?
craigdthomas is offline
post #3 of 5 (permalink) Old 5th January 2014, 17:23 Thread Starter
bonzo's Avatar
After taking the o/s wheel off and removing the wheel arch cover protector I found two washer motors, 1 front and 1 rear.
why I never had any of them working was, one of the motors was u/s (replaced) and the other had a bad contact so had to but one new motor.
this is the one I bought.
hope this helps
bonzo is offline
Thanks to bonzo from:
post #4 of 5 (permalink) Old 5th January 2014, 17:53
jameseh's Avatar
Car: Orchid White GG6 Si
Thanks for sharing the info. Will come in handy if ours decides to pack in!
jameseh is offline
post #5 of 5 (permalink) Old 6th January 2014, 13:02
Cheers, thought it might be after a bit of reading.
How easy was it to remove the cover?
  Civinfo > Other Hondas > Honda Jazz
Will Jazz sport bumper fit on Jazz s 1.2 extrovert Honda Jazz 0 1st August 2009 17:21
Bigger, better Jazz ready to call the tune - Honda Jazz Honda News Feed Honda Jazz 3 5th September 2007 12:08
Next Jazz taking shape - Honda Jazz Honda News Feed Honda Jazz 11 1st May 2007 22:48
New, bigger Jazz on the way - Honda Jazz Honda News Feed Honda Jazz 0 9th January 2007 08:10
HID HID Washers Maldax Lights (8G) 2 13th November 2006 22:58
