Replace rear Disks and Pads. - Page 3 - Civinfo
 6Likes
post #41 of 48 (permalink) Old 17th April 2016, 15:45
Impo's Avatar
Car: 2007 57 2.2 ex alabaster
image.jpgThanks for the how to
Did my rears today
Had to drill out the disk screws and tap them out again. No problem 5.5 MM drill and 6mm tap. Ended up borrowing a wind back tool, can't believe you could do them without one.
Painted callipers as well
Fronts next weekend
Sprotty and Sprotty like this.
Impo is offline
Thanks to Impo from:
post #42 of 48 (permalink) Old 13th July 2016, 23:05
joz
Car: 2007 1.8EX Black
I'm doing this at the weekend. Think im ready following this guide but with one question. Do both pistons rotate in the same direction?
The tool I bought has both left and right handed threads.
Cheers for the info.
joz is offline
post #43 of 48 (permalink) Old 14th July 2016, 07:15
tibsy's Avatar
Car: 2008 2.2 es cosmic grey
Both r/handed if i remember correctly!
tibsy is offline
post #44 of 48 (permalink) Old 12th April 2018, 17:52
DalianY69's Avatar
Car: 56 2.2 CDTI EX, Cosmic grey
I've ran into a bit of an issue while doing this, pretty much everything is seized. When removing bolts holding the caliper to the carrier they have sheared off so I've got the caliper off but there is still some of the bolt threaded into the carrier. any advice on what to do?
Del
update:
I've priced up a new carrier bracket and they are dirt cheap so i'm just going to replace the entire bracket. only issue is the bolts are excessively seized, might need a few tips and tricks for that still!
DalianY69 is offline
post #45 of 48 (permalink) Old 12th September 2018, 05:42
Wd 40?
Sent from my SM-G960F using Tapatalk
eagle123 is offline
Thanks to eagle123 from:
post #46 of 48 (permalink) Old 12th September 2018, 07:27
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
A proper penetrating oil such as plus-gas.
Jon_G likes this.
M8TJT is offline
Thanks to M8TJT from:
post #47 of 48 (permalink) Old 13th September 2019, 11:55
DalianY69's Avatar
A penetrating oil, blowtorch and a soft mallet did the trick 😂
M8TJT likes this.
post #48 of 48 (permalink) Old 15th September 2019, 20:46
Ex-Pat Geordie!
nturnb's Avatar
Car: 2015 Civic S Navi I-dtec
I use one of these for the fronts and it works a treat.
https://www.amazon.co.uk/DASBET-Inst...%2C171&sr=8-20
And one of these little fellas for the rears. Rotate both sides clockwise to rotate pistons in.
https://www.amazon.co.uk/Spreader-Re...%2C171&sr=8-26
Another thing I always do when changing pads is to remove the sliders, clean them with brake cleaner and then grease them. Sample of some grease below.
https://www.amazon.co.uk/Silverhook-...s%2C158&sr=8-1
nturnb is offline
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > This is How To ... (Guides Only) (8G)
Fitting My Rear EBC Grooved Disks and Yellow Stuff Pads Relic This is How To ... (Guides Only) (8G) 101 13th May 2014 14:56
Brakes Which pads and disks for rear?? Chambo Wheels, Tyres, Suspension and Brakes (8G) 16 4th May 2013 22:09
Brakes Rear disks and pads need replacing urbanmammoth Wheels, Tyres, Suspension and Brakes (8G) 2 12th June 2012 13:39
Brake pads and disks... _7cups Type-R 1 2nd September 2010 21:38
Brakes Rear pads and disks need replaced at 12000 jubilee88 Wheels, Tyres, Suspension and Brakes (8G) 15 6th March 2010 09:29
