[HOW TO] replace front Brake-discs and brake pads - Civinfo
 2Likes
post #1 of 46 (permalink) Old 14th October 2009, 08:51 Thread Starter
Sfinx's Avatar
Car: 2007 2.2 Sport Sapphire blue
This is my first how-to so be gentle
How to replace the front discs and brake pads.
Used:
- ATD drilled and vented sport discs
- EBC Greenstuff Brake Pads
Remove both front wheels.
Remove the two screws from the disk.
Remove the flange bolt while holding the calliper pin with a wrench. Be careful not to damage the pin boot.
Remove the brake hose mounting bolt
Remove piston. Press in the piston with the brake calliper piston compressor so the calliper will fit over the brake pads and hang him out of the way with some rope.
Remove the brake calliper bracket mounting bolts (sorry no picture)
Remove break-discs by hitting them careful with a hammer. Clean the front hub and apply copper grease to the front hub.
Install the new disc and insert the two screws
Install the brake calliper bracket and tighten the bolts with max 108 Nm.
Take the new brake pads and apply a thin coat of copper grease to the top en bottom edges and the thin coat of copper grease on the flat side of the outer pad.
Clean the piston shim and apply a thin coat of copper grease. Place the shim in the calliper body.
Install the caliper by sliding it gently over the brake pads. Insert calliper bolts and tighten them with max 35 Nm.
Re-install the brake hose mounting bolt and tighten them with max 35 Nm.
Re-Install the wheels. Put your Civic back on the floor, start your engine and pump the break a few times.
Go for a short drive to "feel" the braking.
and your done
Remember not to brake hard for around 125miles / 200KM to let the discs set.
etusch and Trev27 like this.
Last edited by Pottsy; 16th October 2009 at 18:56. Reason: Spelling at the request of the OP
Sfinx is offline
post #2 of 46 (permalink) Old 15th October 2009, 18:34
dw7
dw7's Avatar
Car: Vivid Type-S 2.2
as simple as you've made it look...I don't think I could ever do my own brakes. I'd be too scared of getting it wrong
dw7 is offline
post #3 of 46 (permalink) Old 16th October 2009, 18:57
Car: Jag XF 3.0
Nice one!
Pottsy is offline
post #4 of 46 (permalink) Old 16th October 2009, 19:06
Its really quite easy dw7, but the rear brakes require a 'wind back' tool. You can push back the front piston quite easily
BTW...its a good opportunity to paint the calipers, while they're padless and split apart.
robbo51 is offline
Thanks to robbo51 from:
post #5 of 46 (permalink) Old 16th October 2009, 19:38
Cockup Specialist
Relic's Avatar
Thanks for this
But...
Is it not bad to force brake fluid back past the master cylinder?
Thought it damaged the seals.
I always thought you were supposed to use a pipe calmp on the flexible hose....open the bleed valve... then push the piston in. (That way the fluid comes out the bleed valve and not back through the master cylinder). Lock the bleed valve off when the piston is in... remove clamp...carry on.
Bleed brakes after to check there is no air pulled in to the system and that level is OK.
Relic is offline
post #6 of 46 (permalink) Old 17th October 2009, 08:40 Thread Starter
Sfinx's Avatar
I know. But there was no time to let the calipers dry
But they will be painted in future
Sfinx is offline
Thank You to Sfinx from 2 Users:
post #7 of 46 (permalink) Old 17th October 2009, 08:59
Munro's Avatar
Nice work
How do you rate the new pads and disks compared with the original Honda ones ?
Munro is offline
post #8 of 46 (permalink) Old 17th October 2009, 09:08
They are better (I retained the original discs) but the biggest difference is the vastly reduced brake dust
robbo51 is offline
post #9 of 46 (permalink) Old 17th October 2009, 09:32 Thread Starter
Sfinx's Avatar
Hard to say yet. Just fitted them 4 day's ago. But it feels like smoother braking.
They look better
Sfinx is offline
post #10 of 46 (permalink) Old 17th October 2009, 10:09
dw7
dw7's Avatar
Re-paint them? Ie touch them up?
Coz as we both know, mine are already blue.
dw7 is offline
post #11 of 46 (permalink) Old 8th June 2010, 05:43
They look better
I noticed this too. I just installed the new brake discs and I feel the difference.
mikeross is offline
post #12 of 46 (permalink) Old 15th July 2010, 22:19
danlat1415's Avatar
Car: 2.2d 5dr Black Civic ES 2007
I'll be doing this - this weekend hopefully.
do you need to bleed the brake fluid when pushing the piston back on?
what would you recommend using to push the piston in? can you use your hands, or is it tough, so pliers or something?
danlat1415 is offline
Thanks to danlat1415 from:
post #13 of 46 (permalink) Old 10th August 2010, 05:03
kojmeister's Avatar
Car: 2007 CTR, Silver
Ive done the same method (re brake fluid issue) as with SfinX and just pushed the pistons back on a mate's STI 4 pot Brembo while changing brake pads.. Learned that this is the wrong method.. Ive been told that you should open the brake fluid reservoir in the engine bay, wrap like absorbent material around it (as when you push the pistons, fluid gets pushed back into here) and then adjust the pistons, so that pressure doesnt build up. Once youre completed, check the level (in case some fluid did spill out, and then top up with new fluid)
But then again, I may be wrong.
But sounds like the right thing to do in my opinion.
kojmeister is offline
Thanks to kojmeister from:
post #14 of 46 (permalink) Old 8th November 2010, 12:38
P1259 ODB-II
Krysten CTR's Avatar
This is a great how-to. Easy to follow and good pics.
As for pushin the fluid back into the reservoir. According to my local Honda's workshop guide this is what the mechanics are told to do by Honda. Good enough for them, then it's good enough for me.
Cheers for this. Saved me a bundle of cabbage which would have been owned by the dealer otherwise.
Krysten CTR is offline
post #15 of 46 (permalink) Old 23rd January 2011, 15:06
Civic type-s's Avatar
Car: 2009 CTR, Red
I have replaced mine
With help from this post and the one for rear brakes i replaced all mine with EBC Turbo grooved discs and green stuff pads. The only problem i had was one of the studs sheared off my rear hub due to a seized wheel nut so had to buy a new stud and nut from Honda.
The reason i decided to change all mine was A) my front discs were basically at the end of their life, B) the brake dust from oem pads and discs is ridiculous, C) OEM pads and discs wear out to quickly, and D) my car was standing for about three days and when i tried to move it the rear pads had stuck on the discs, i rocked the car with the clutch and they became unstuck but unfortunately on of the rear pads braking material had separated from the backing plate and stuck to the disc making the car undrivable
Civic type-s is offline
Thanks to Civic type-s from:
post #16 of 46 (permalink) Old 23rd January 2011, 15:10
Car: 2009 CTR, Red
Forgot to mention
Remeber to buy or make a bleeding kit and bleed the brakes into that using the nipple, do not push calliper piston in and force the fluid back into the master cylinder.
post #17 of 46 (permalink) Old 4th May 2011, 15:41
Fantastic guide, changed my rear discs / pads last week. This guide made it much easier.
As a side note it may be worth mentioning if your discs are seized on with rust (mine were not). There are two bolt holes on the disc which take a 8mm 1.25mm thread bolt to screw in push the disc off the mount (small turns equally to both sides, if you do this).
You can get these bolts from d-fix, handy to have as a precaution rather than hitting the disc for hours as I've previously done on other cars.
shanem63 is offline
Thanks to shanem63 from:
post #18 of 46 (permalink) Old 12th May 2011, 12:53
Car: 2006 Black i-CTDi Sport
I've just fitted all new Discs and Pads to an '06 Civic. I'd like to add the following observations.
On the Civic I went for OEM Honda discs and pads - 260 incl VAT from Honda for 4 discs and 4 sets of pads.
The quality is excellent. I was particularly impressed with the OEM Pads, they come complete with 8 new brass/alloy Pad guides, new Caliper bolts, and new stainless steel shims for the front calipers. You don't get these with pattern pads.
On the above guide copious amounts of Coppa Slip have been appled to the rear of the pads. Do NOT do this with OEM pads. The OEM pads have a thick layer of adhesive on them, peel off the protective backing paper before you refit the caliper, and the Pads are then stuck firmly to the Caliper and the Piston, ensuring there is no pad rattle.
OEM Pads and Disc's are far better than cheap pattern parts, not to expensive, and they will last twice as long as cheap pattern parts.
The stopping power is excellent, Honda would not provide a car with *****e brakes would they?
AliShaff is offline
post #19 of 46 (permalink) Old 12th May 2011, 15:14
Cockup Specialist
Relic's Avatar
Yes. They call them eco friendly as a justification.
But yes all they extras in the pack would be nice in other aftermarket sets.
Relic is offline
post #20 of 46 (permalink) Old 12th May 2011, 23:23
無限 Unlimited
Laney's Avatar
Car: 59 Mugenised CTR
Good guide overall, clear pictures and instructions but agree with Relic on the point below re: pushing the piston back, think there could have been an extra bit of description there.
Added point is that the rear caliper pistons are often seized (due to handbrake being left on) and even a retracting tool can buckle... open bleed nipple and bring the hammer with a little bit of pin point force to free the piston, then try the retracting tool again.
Originally Posted by Relic View Post
Thanks for this
But...
Laney is offline
Thanks to Laney from:
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > This is How To ... (Guides Only) (8G)
Brakes Replace Brake Pads on 96' Honda Civic autowise Wheels, Tyres, Suspension and Brakes (8G) 1 24th June 2010 08:34
Long list Flat battery, Check System, VSA, ABS, Steering, Alarm, Brake Pads/Discs Fedupwithmycivic Bugs, faults and irritations (8G) 7 27th February 2010 12:50
Brakes How long have you brake pads and discs lasted since new? smurf79 Wheels, Tyres, Suspension and Brakes (8G) 23 13th October 2009 17:43
