Installation of the Parsco Heavy Duty Grounding Kit for a 1.8 Civic 8th Generation - Civinfo
post #1 of 13 (permalink) Old 24th August 2012, 15:14 Thread Starter
delta0's Avatar
Car: RX-8 R3, Blue
Installation of the Parsco Heavy Duty Grounding Kit for a 1.8 Civic 8th Generation.
The first thing you need to do is familiarise yourself with the location of the current grounding cables. There are two which are labelled below.
Pictures of both cables can be seen below, starting with the cable located on the right and attached to the battery.
Then the cable located on the left side of the engine.
Letís get started! Remove the negative battery connector and push it down the side of the battery to hold it in place.
Next remove the other side of this cable from the car.
Letís move on to the left hand side of the engine and look at the second cable. Release this cable in the same fashion as before.
Paint does not conduct electricity so you need to remove this from the surfaces on the body for the left and right hand side cables. Below you see the surface after the paint was removed on the right hand side. Repeat for the left hand cable. This bare surface is obviously going to rust over time if left uncovered, so you should consider using dielectric grease or silver conductive paint.
This is where we start installing the Parsco kit! The left hand cable is a separate piece. In the kit there are two bolts. You need to use one of these in the body and reuse the other one from the engine. Attach the cable similar to as shown below. Then you can touch up any area around the bolt in the body to cover any scratches that are exposed.
In the kit the battery connector has two cables connected to it. The longer is to be attached to the engine. Letís look at the first picture again and note the circled area below. It appears to be circling the oil cap, but if you look behind you will see a bolt. The next image will show this bolt.
As you can see the oil cap and bolt are visible. This bolt is where you need to connect the cable. Note the route over the back of the engine.
This route continues around the engine and between the airbox and engine. Then it goes around the airbox and towards the battery.
Connect the short cable from the battery connector and then attach the battery connector to the battery. Make sure the battery connector is secure onto the battery, i.e. the bolt is tight.
Stand back and admire!
Note: When tightening bolts in the bodywork and engine do not over tighten as stripping threads or bolt heads is not fun! I.e. just tight and then a nip.
delta0 is offline
Thank You to delta0 from 4 Users:
post #2 of 13 (permalink) Old 24th August 2012, 23:03
parsco's Avatar
Car: 2007 CTR, NHB
Looks great mate. Glad you're happy with it and thanks for the brilliant How2
parsco is offline
Thanks to parsco from:
post #3 of 13 (permalink) Old 24th August 2012, 23:13
Dutch
Xa4cornelis's Avatar
Car: 2015 Sport 1.6 sporty blue
Thanks! helped a lot mate!
I will apply two more cables to it pictures when I received my package!
Xa4cornelis is offline
Thanks to Xa4cornelis from:
post #4 of 13 (permalink) Old 24th August 2012, 23:35
parsco's Avatar
Car: 2007 CTR, NHB
On the way tomorrow mate
parsco is offline
post #5 of 13 (permalink) Old 29th August 2012, 15:10
Car: Silver2.2 se leather + fog
Noob question but what does this grounding kit do and what's wrong with the original?
Rymz is offline
post #6 of 13 (permalink) Old 29th August 2012, 15:18
parsco's Avatar
Car: 2007 CTR, NHB
LINKY
Post number 5 mate
parsco is offline
post #7 of 13 (permalink) Old 30th August 2012, 17:30
Car: 2008 1.8 GT Type S
Helped a lot, many thanks.
RA108 is offline
Thanks to RA108 from:
post #8 of 13 (permalink) Old 21st April 2013, 17:01
Alabaster FTW
philliboy's Avatar
Car: 2011 CTR, Alabaster
Fitted today, was struggling with location for the long cable, but this how to solved the problem. Thanks again buddy.
philliboy is offline
Thanks to philliboy from:
post #9 of 13 (permalink) Old 22nd May 2013, 19:54
James90N's Avatar
Car: 2008 1.8 I VTEC ES 5 door
Thanks for the how to, got a wiring kit through today ready to fit this weekend.
James90N is offline
Thanks to James90N from:
post #10 of 13 (permalink) Old 24th April 2015, 11:29
Jay141089's Avatar
Car: 58 Alabaster Silver Type-R
Sorry to bring up an old thread.... The original ground points, are they the same on an FN2?
Jay141089 is offline
post #11 of 13 (permalink) Old 19th May 2015, 19:24 Thread Starter
delta0's Avatar
Car: RX-8 R3, Blue
I think the FN2 may have a metal intake manifold so you can use that if it is rather than going around the back of the engine.
delta0 is offline
post #12 of 13 (permalink) Old 29th March 2016, 11:14
RagweedDrunkenly's Avatar
Car: 2009 1.8 5 door, Black
Sorry for reviving an old thread, but do you still have the images for this? I can't see them at all and am looking at installing a grounding kit. This guide would make that a lot easier with the pictures!
RagweedDrunkenly is offline
post #13 of 13 (permalink) Old 20th September 2019, 10:21
Yes, likewise would be great to see the pics?
mad_mickey is offline
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > This is How To ... (Guides Only) (8G)
How to install Parsco's Grounding Kit parsco This is How To ... (Guides Only) (8G) 37 6th July 2017 15:06
Electrics Heavy Duty Grounding Kit parsco Electronics (8G) 131 19th November 2013 11:35
Electrics DIY - HKS Circle Grounding Kit installation TK-Sp3cialiSt Electronics (8G) 5 16th August 2012 08:34
