How to remove the radio? - Civinfo
 1Likes
post #1 of 43 (permalink) Old 19th March 2013, 04:30 Thread Starter
Car: 2012 1.8 5 door,White Orchid
IMPORTANT: Ensure the vehicle is safely parked in a well lit location. Disconnect the car battery. Make a note of the radio security code as this may be required after the power is restored. Proceed carefully and AT YOUR OWN RISK. DO NOT attempt if you have limited time or your are not confident in DIY procedures. Note that there may be wiring harnesses / plugs for the SRS AIRBAG system in the vicinity (Keep well away from these - DO NOT TOUCH!!!) If in any doubt, consult an experienced auto electrician or your Honda dealer.
Tools required: Plastic car trim tool kit (optional but highly recommended to avoid damaging trim), Philips head screw driver, flat blade screwdriver, painters masking tape (low tack), a small tray to hold screws.
1) Just above the headlight adjuster and VSA switch panel there is an irregularly shaped trim piece (held in by clips). Look for a small slot and using a flat blade screwdriver (wrap some electrical tape around tip first) carefully lever the trim out.
2) Remove the dash under tray (held in by clips). Do not pull too hard downwards. Unplug the wiring connectors (VSA / headlight adjust / front parking sensor switch off - where applicable).
3) Pop out the steering wheel top cover/shroud (clipped in). Once removed you can pop out the two clips which hold the "vinyl cover" to the shroud. The vinyl cover is permanently attached to the cluster hood.
4) Remove the screw holding one edge of cluster hood. (Note: it's the normal screw, not the one with the washer).
5) Remove the screw holding the long centre console trim piece. Pull the whole trim piece upwards in one motion. It is held together tightly by clips. Take your time.
6) Remove the other screw holding the cluster hood in place.
7) Pop the cluster hood off carefully (held in by clips). Note the position of the rotary instrument dial brightness stalk. You do not want to accidentally break this.
You will need to disconnect the wiring plug for the Econ mode and engine start button (if equipped).
8) Wrap some masking tape around / over the gear lever top for protection. Stick some tape on the section just in front of the Airconditioning control panel and some over the gear lever base bezel.
9) The Airconditioning panel pulls away (towards you) in one piece. It is clipped in. Unplug wiring harness(es) for auto stop/seat heaters/dual zone airconditioning if applicable.
10) Behind where the Airconditioning panel was, you will see the metal radio brackets. Undo the 2 screws which hold the radio in place.
11) Pull out the radio unit towards you. It is held in by clips. You can start from the right hand side and then work your way towards the left. Disconnect the wiring plug for the hazard lights first. Then disconnect the wiring plugs for the audio system.
12) Reassembly is the exact reverse of the above steps.
Important reminder: When re-installing the cluster hood, ensure that the rotary instrument dial brightness stalk is poking out of its hole otherwise you will snap it in half!!
13) After it is all done and back together again, start the car up and ensure all lights, systems, indicators etc appear to be working on the dash. Go for a test drive to confirm.
Good Luck!
Vti07 is offline
Thank You to Vti07 from 7 Users:
post #2 of 43 (permalink) Old 19th March 2013, 09:07
gloom's Avatar
Car: 2012 Civic 1.8, White Pearl
Can I just recommend to always use plastic tools made for this very reason. Will leave no scratches and a bit gentler when bending stuff.
gloom is offline
post #3 of 43 (permalink) Old 19th March 2013, 09:38 Thread Starter
Yes, a plastic trim tool is very handy. I bought a 10 piece kit from a UK Ebay seller and use it all the time.
Vti07 is offline
post #4 of 43 (permalink) Old 19th March 2013, 10:05
gloom's Avatar
This is great information and should be stickied imo.
Good job!
gloom is offline
post #5 of 43 (permalink) Old 19th March 2013, 10:10 Thread Starter
Thanks Gloom. Happy to help.
Vti07 is offline
post #6 of 43 (permalink) Old 19th March 2013, 10:20
Alwaysblack's Avatar
Car: 2012 2.2 EX GT Crystal Black
I'm very impressed but not something I would ever have the confidence, let alone the need, to attempt.
You surely must have a fine ear for music to want to do this. I have always found the systems provided perfectly adequate.
Pardon! What did you say?
Alwaysblack is offline
post #7 of 43 (permalink) Old 19th March 2013, 10:41
gloom's Avatar
I am very fond of music and besides my home and job, the car is where I spend a lot of the time. Unfortunately I'm not allowed to listen at work (tram driver).
I have produced and released some songs and love music so it's a big deal to me
Stock system is one of the better ones (one with tweeters) so I totally understand you.
I need more detail and "depth" though.
gloom is offline
post #8 of 43 (permalink) Old 19th March 2013, 10:47 Thread Starter
As I missed the nice OEM 10 speaker sound system in my previous Accord, I decided to install a 12" active subwoofer in the boot. The base 4 speaker system (no tweeter) clearly lacks low end punch. I needed to get access to the speaker signal cables somehow (preferred not to pull apart the doors though). It sounds much better than before and I do not mind the reduced boot space.
Vti07 is offline
post #9 of 43 (permalink) Old 19th March 2013, 10:53
Syx
#MrGrumpy
Syx's Avatar
Car: 2008 2.2 CTS GT
Great How-To. And we thought getting to the radio in the 8G was bad!!
Syx is offline
post #10 of 43 (permalink) Old 19th March 2013, 11:54
H.A.T's Avatar
Car: Cw type R. No 518
Re: How to remove the radio?
Exactly what I was thinking syx. Still a very good how to. Well done
H.A.T is offline
post #11 of 43 (permalink) Old 19th March 2013, 12:17
gloom's Avatar
I have a 12" slim sub from my previous car but need all boot space available.
Not really sure I can use it tbh but the speakers are rated down to 35hz, coupled with rears should be ok.
gloom is offline
post #12 of 43 (permalink) Old 19th March 2013, 12:22
Aaaaa...V-tech
Kaney*Mugen's Avatar
Car: 2011 CTR Mugen
Just use a chisel and hammer wedge in between the little gaps and yank it , works 60% of the time everytime
Kaney*Mugen is offline
post #13 of 43 (permalink) Old 19th March 2013, 15:00
sakis9282's Avatar
Car: 2013 1.4 sport white orchid
Gloom you will put 2-din stereo?
sakis9282 is offline
post #14 of 43 (permalink) Old 19th March 2013, 15:07
gloom's Avatar
No oem radio with audison bit ten processor and mds amp.
gloom is offline
post #15 of 43 (permalink) Old 19th July 2013, 05:27
Hi, can you tell me what harness lead I would need for a pioneer double din head unit to connect to a civic 9 g hatch
Vij29672 is offline
post #16 of 43 (permalink) Old 20th July 2013, 07:07
GENUINE CIVIC KIT
Pioneer Patch Lead
or
Connects 2 Car Audio Systems, Car Stereo, Car Radio DAB Stereos, Car interface adapters and accessories > ProductInformation
Product Information
kendallj is offline
Thanks to kendallj from:
post #17 of 43 (permalink) Old 13th October 2013, 17:07
Car: 2013 1.8 5D polished metal
Smile Removing radio
Hi Vti07 (or any one else who can help me),
Just wanted to ask you question about the process of removing radio.
Do I have to remove the all plastics as shown on pictures (for example the dashboard above the steering wheel) to remove radio, or I can skip some steps? I'm a little afraid to remove the entire car
I apologize for repeating the question but I would love to some more information!
Best regards.
yakov82 is offline
post #18 of 43 (permalink) Old 14th October 2013, 01:50 Thread Starter
Best regards.
The steps are basically from a Honda guide for installing an accessory OEM bluetooth kit however i have omitted the unnecessary steps. If the trim pieces are not removed (with the hidden screws), you won't be able to remove the AC/ climate control panel. Behind the panel are the two bolts that hold the factory stereo in place.
Vti07 is offline
post #19 of 43 (permalink) Old 15th October 2013, 05:23
Originally Posted by Vti07 View Post
You've convinced me I little bit afraid to damage any details when removing dash above steering wheel. I'm wrong? And BTW, where I can find a Honda guide for installing an accessory OEM kit, if it exist at all?
And one more time, thank you.
yakov82 is offline
post #20 of 43 (permalink) Old 15th October 2013, 07:41
Car: 2013 1.6 iDTEC Lifestyle
You don't have to remove the dash above the steering wheel.
I did remove the radio without removing this part.
nigel132 is offline
Thanks to nigel132 from:
  Civinfo > 9th Generation Euro Honda Civic (2012 - 2016) > This is How To ... (Guides Only) (9G)
Head Unit 07 plate type r, radio can only pick up radio 1! martyn.stuttard Ipods, MP3 Players and ICE (8G) 4 5th September 2012 14:09
Electrics Radio, Aircon display blank radio not working Hotchy Bugs, faults and irritations (8G) 4 14th April 2012 12:34
Electrics Remove radio and satnav help atmw1 Electronics (8G) 1 26th February 2011 21:11
Radio 1Din Radio beneath OEM radio unit endepende Ipods, MP3 Players and ICE (8G) 6 12th October 2010 00:21
Electrics OEM radio replaced by AVI alpine radio GORDIET Electronics (8G) 3 10th January 2010 18:05
