Hello and slightly worried dohhhhhhh - Civinfo
post #1 of 16 (permalink) Old 20th August 2012, 13:08 Thread Starter
always loved civic, finally get one in three days, was excited until read about clutch problems arrrrrr now im starting to think ive made a mistake
2007 2.2 cdti ex full service every stamp one owner 95,000 should i be worried
stewartcjones is offline
post #2 of 16 (permalink) Old 20th August 2012, 13:12
Syx
#MrGrumpy
Syx's Avatar
Car: 2008 2.2 CTS GT
Hi and welcome!
The 2.2 clutch is a bit of an unknown; some people have had them fail very early on and others are fine at similar mileages to you.
The only recommendation I have is budget for the replacement and then you'll have nothing to worry about when it does go.
Syx is offline
post #3 of 16 (permalink) Old 20th August 2012, 14:01
Batmobiles Rule ✌
Staffs Deltic's Avatar
Car: FK8
Hi & welcome to the forum.
Don't worry about it. Everyone vents frustrations on forums, chances are you won't have any problems.
Staffs Deltic is offline
post #4 of 16 (permalink) Old 20th August 2012, 14:12
Hotchy's Avatar
Car: 2007 57 2.2 Type S
Chances with the 2.2 is you will have trouble with clutch lol
Hotchy is offline
post #5 of 16 (permalink) Old 20th August 2012, 14:17
okehciv's Avatar
Welcome Stewart, who is to say its not been replaced already. Am sure you test drove the car and it was ok.
okehciv is offline
post #6 of 16 (permalink) Old 20th August 2012, 14:18
Batmobiles Rule ✌
Car: FK8
A clutch can go in any car, yes the 2.2 has had issues reported by people on this forum; but bear in mind how many people have 2.2s, the majority do not frequent this forum and I would guess that quite a large percentage of them have had no issues.
To the O.P., it is a case of something to be aware of not worry about. All makes & models have faults and forums like these are there to help. Try not to let it worry you.
post #7 of 16 (permalink) Old 20th August 2012, 14:57
stevencavanagh's Avatar
Car: 58 2.2, Black ; 09 CTR, Red
Budget for it, just in case.
I'm on number 5 (72K)
Sent from my BlackBerry 9900 using Tapatalk
stevencavanagh is offline
post #8 of 16 (permalink) Old 20th August 2012, 15:16
Urban Parkour Monkey
Flipt's Avatar
Car: 2009 CTR GT, Milano Red
I had the 2.2 in a 56 plate Accord and the clutch only started slipping at 127K. That was the original clutch.
Take the car out for another spin before commiting. Stick it in 4th drop to about 1K revs and then floor it! you should then see if there is any slipping
Flipt is offline
post #9 of 16 (permalink) Old 20th August 2012, 15:24
Lucky then!
post #10 of 16 (permalink) Old 20th August 2012, 18:34
John-R's Avatar
Hi and welcome
John-R is offline
post #11 of 16 (permalink) Old 20th August 2012, 18:58
wanner69's Avatar
Car: Jaguar F Type V6S
Hi and welcome to the forum
wanner69 is offline
post #12 of 16 (permalink) Old 21st August 2012, 00:02 Thread Starter
thanks everyone. for advice just took out a 12 month extra warranty so that should cover some of the costs if it goes
post #13 of 16 (permalink) Old 21st August 2012, 00:26
Aqib's Avatar
Aqib is offline
post #14 of 16 (permalink) Old 21st August 2012, 07:26
ex CW FN2 owner
Adam S's Avatar
Car: Honda Jazz 1.4S
Hi and welcome dont worry to much about the clutch at least you have found the right place to find out all the info you need incase you do have any issue down the line
Adam S is offline
post #15 of 16 (permalink) Old 26th August 2012, 14:15
jeremiah's Avatar
Car: 2007 NHB Civic 5D 2.2 i-CDTi
+1 You'll notice it first in higher gears!
Welcome to the forum mate! Just test the clutch on regular base, but don't have it ruining your ride!
jeremiah is offline
post #16 of 16 (permalink) Old 26th August 2012, 14:21
bleb's Avatar
Car: 2007 2.2 i-CTDI 5door
never had a problem with mine and its not very often i drive economically
and welcome to the forum!
bleb is offline
Faults Need i be worried ??? nuclearstar Engines and Transmission (8G) 4 15th March 2012 13:14
Other slightly different smig64 Gallery (8G) 12 17th February 2012 12:42
Faults should i be worried ?? gazmdm Engines and Transmission (8G) 9 27th February 2010 17:40
I am worried..... Kremmen Any non Civic chat here please! 63 8th May 2009 15:44
So worried... Spartan General Discussion (8G) 20 26th September 2006 23:24
