Prospective Owner - Civinfo
post #1 of 22 (permalink) Old 5th September 2012, 18:09 Thread Starter
Pri
Prospective Owner
Hello all, Livvy pointed me in this direction as I'm looking to upgrade my little C2 to something more practical and the 8th Gen Civic came up as one of my options (Amongst the Leon, Ibiza, Golf and 1 Series).
Always loved the Civics because they reminded me of a spaceship! Now that I'm older and a little wiser, I like the practicality of the Civic and someone at work showed me the size of the boot and interior which was impressive - not to mention the dash which looks like a pilots cockpit!
Looking to get a 5dr 2.2 CDTI in probably the Ci-T trim level or something similar. What I would like to know is if the mpg is anything like the "book" value of 53?
This forum has already answered my questions about whether or not I can put in my aftermarket audio (yes with a bit of trickery!) and servicing costs (£200-£400 depending on dealer and service) and also the possibility of a remap in the future. Does anyone know if all the Civics have the double sun roof or is that model dependant?
I guess my main concern is living with the poor view through the rear view window - how bad is it really? And if there are any common faults or issues with the cars. Any thoughts would be most appreciated on the car in general and the points made
Pri is offline
post #2 of 22 (permalink) Old 5th September 2012, 18:25
Type R GT Milano GP Kit
Jeza's Avatar
Car: 1997 Nissan Skyline R33
Its a panoramic sun roof depending on the model, the rear view window is easy after a week or 2 once you've adjusted to it then it doesn't bother you. As I drive Trucks I use wing mirrors all the time when reversing so I'm used to it. As for bad points I'll leave that to the guys that own the diesel version, they'd be better for telling you.
Jeza is offline
post #3 of 22 (permalink) Old 5th September 2012, 19:03
hi and welcome.
The rear view is bad but not as much as its made out to be as the wing mirrors are big you can add parking sensors to the rear if worried but imo ive been ok with the split across the boot helps block out headlights from behind at night
Gp_kho is offline
post #4 of 22 (permalink) Old 5th September 2012, 19:05
Jeza's Avatar
Originally Posted by Gp_kho View Post
hi and welcome.
Thought you'd be used to it by now?
Jeza is offline
post #5 of 22 (permalink) Old 5th September 2012, 19:21
yeah its not a big issue for me ive never really had a problem with the rear veiw
Gp_kho is offline
post #6 of 22 (permalink) Old 5th September 2012, 19:24
Jeza's Avatar
Same here buddy just get used to it.
Jeza is offline
post #7 of 22 (permalink) Old 5th September 2012, 20:29
fatmarky's Avatar
Car: 2011 cts gt alabaster
Hello and welcome to civinfo.
fatmarky is offline
post #8 of 22 (permalink) Old 5th September 2012, 20:33
wanner69's Avatar
Car: Jaguar F Type V6S
Hi and welcome to the forum
wanner69 is offline
post #9 of 22 (permalink) Old 5th September 2012, 20:43
ivtec just kicked out,YO!
Yassian's Avatar
Car: 2011 FK2 Milano red
Yassian is offline
post #10 of 22 (permalink) Old 5th September 2012, 21:30
Hi and welcome. I drive my 2.2 mixed between enthusiastically and economically dependant on who is in the car with me (wife = economically) and I get 50 mpg almost exactly. The panoramic roof is standard on an ES model not the SE. The rear view is perfectly fine after a few days as mentioned above and the blocked bit of the rear window is perfect for blocking out headlights which is a bonus.
Kenny junior is offline
post #11 of 22 (permalink) Old 5th September 2012, 21:35
World Traveller
Stevo!'s Avatar
Car: (64) 1.6 DCI Megane GT Line
Welcome, I don't own a derv, but you will want to do some research on the clutch before buying, Im surprised it hasn't been brought up already, its normally the first think people talk about.
Stevo! is offline
post #12 of 22 (permalink) Old 6th September 2012, 08:03
guten's Avatar
Car: 07 NHB CTR GT NAV/HFT
hi and welcome
guten is offline
post #13 of 22 (permalink) Old 6th September 2012, 09:36
ying's Avatar
Car: 2008 Civic Type-R GT
Hi and welcome mate
ying is offline
post #14 of 22 (permalink) Old 6th September 2012, 11:01
MrBozo's Avatar
Car: 2007 2.2 EX, NHB
Welcome mate.
MrBozo is offline
post #15 of 22 (permalink) Old 6th September 2012, 17:28 Thread Starter
Pri
Thanks all - I had a quick search on the forums last night and it seems as though the clutch problem is hit and miss - along with the prices for repair. I think a bit more research is needed as I don't particularly want to have to keep £1000 spare just in case!
Pri is offline
post #16 of 22 (permalink) Old 8th September 2012, 14:35
Batmobiles Rule ✌
Staffs Deltic's Avatar
Car: FK8
Hi and welcome to the forum.
Staffs Deltic is offline
post #17 of 22 (permalink) Old 9th September 2012, 14:50
Aqib's Avatar
Hi and welcome
Aqib is offline
post #18 of 22 (permalink) Old 9th September 2012, 16:11
Cockup Specialist
Relic's Avatar
This is the sad reality I am afraid.
The clutch is a real weak point.
The third revision is 325 which appears much better.
Older models failed with normal map let alone remaps.
the 325 seems to be coping OK even with light remapping.
If you want something more underfoot then the only real option is the CG competition clutch at the moment.
Personally I hate the judder when pulling off.
Others say its not so bad.
A New DMF will be essential with the CG clutch or you'll probably kill an old DMF and then have to replace both.
New DMF = New Clutch.
This is under a 1000 at the moment all in.
Honda fitted replacement clutch is about 625 without a dmf.
Type s is 3 door ...all others are 5 door.
GT has cruise/climate control/panoramic roof
2009 models or newer have blutooth and usb I think
5dr EX has most toys
Livvy ....bad girl.... bad bad girl
...this is humour by the way
Relic is offline
post #19 of 22 (permalink) Old 9th September 2012, 18:09
coste1l's Avatar
I would get the 1.8 tbh
Sent from my GT-N7000 using Tapatalk 2
coste1l is offline
post #20 of 22 (permalink) Old 9th September 2012, 18:13
Cockup Specialist
Relic's Avatar
as long as it dont have syncro issues :/
Relic is offline
Prospective Newbie Civic Type R Introduce yourself 17 21st June 2012 15:56
Old NHB EP3 owner, New Milano FN2 owner says 'hi'.. egg1000 Introduce yourself 19 17th February 2010 20:25
Prospective 2.2CDTi SE Owner stevezodiac Introduce yourself 6 14th January 2009 22:49
Prospective owner. RickSkye Introduce yourself 5 21st May 2008 17:19
Prospective mods- Yay or Nay? Unknownsoldier General Discussion (8G) 29 9th December 2007 21:05
