Head Unit 09 fn2 double din help - Civinfo
post #1 of 9 (permalink) Old 10th May 2012, 22:55 Thread Starter
Hi , im finding it hard to find any help or advice on how to take apart the dash etc to fit a Pioneer Avic and fitting kit, can anyone post some links if possible.. Thanks Guys
Crezzlin is offline
post #2 of 9 (permalink) Old 10th May 2012, 23:08
無限 Unlimited
Laney's Avatar
Car: 59 Mugenised CTR
Try this guide for starters
http://www.civinfo.com/forum/how/154...into-dash.html
there are some other "how to's" in the same section of the forum
Laney is offline
post #3 of 9 (permalink) Old 10th May 2012, 23:21 Thread Starter
Thanks Mate, looks like i will be pulling my hair out tomo
Crezzlin is offline
post #4 of 9 (permalink) Old 10th May 2012, 23:40
無限 Unlimited
Laney's Avatar
lol, it's not too bad once you work out the sequence of what needs to be removed and where the screws and poppers are plastic trim removal tools are essential.
1. Armrest first (plus disconnect the 12v socket connector) (four bolts)
2. Lever triangle cover off behind door (remove one screw)
3. Pull off cover under steering wheel (poppers holding it on)
4. Centre console surrounding gearstick (remove poppers in footwell either side) take care with clips just above the stashbox under the stereo.
5. Remove the diamond-ish shaped pannel infront of the clock display (only clips holding this but will be stiff to remove take your time)
6. Remove three phillips screws underneath.
7. Two bolts holding the factory stereo onto the metal frame underneath (you'll need to look under as it's not immediately obvious)
8. Pull out the stereo carefully (clips remaining holding it in)
All disassembled! Install in reverse, job done!
Laney is offline
post #5 of 9 (permalink) Old 12th May 2012, 04:43 Thread Starter
Haha Thanks, didnt have the car today the GF had it so will do my best tomo.. Thanks for the info Think i will need it..
Crezzlin is offline
post #6 of 9 (permalink) Old 15th May 2012, 20:53 Thread Starter
Would you have any idea what size speakes i will need for front and rear, sorry been looking all over net and cant find a answer. Thanks again
Crezzlin is offline
post #7 of 9 (permalink) Old 15th May 2012, 23:03
無限 Unlimited
Laney's Avatar
6.5" component speakers for the front and 6.5" coaxial's for the rear
Laney is offline
post #8 of 9 (permalink) Old 16th May 2012, 10:48
neeblack's Avatar
Car: 2008 FK2 1.8 EX, Black
You will likely need spacers as normal 6.5" speakers won't clear the window - see wiki
neeblack is offline
post #9 of 9 (permalink) Old 16th May 2012, 14:46
無限 Unlimited
Laney's Avatar
What he said forgot to mention those, they're cheap though spacers get the MDF ones they're the best.
Laney is offline
Technical Double din :( miller4648 Ipods, MP3 Players and ICE (8G) 3 9th March 2012 15:19
Head Unit How and how much can I get from this Double DIN adapter,Double DIN head unit fascia, sanyo Ipods, MP3 Players and ICE (8G) 5 13th December 2009 11:04
