AUX in Xcarlink, Dension or Dice which is best? - Civinfo
post #1 of 7 (permalink) Old 29th August 2012, 18:20 Thread Starter
padster's Avatar
Car: 58 1.8 Type-S GT
Well I've have the FM transmitter for nearly a week and its time to move on to better.
Which is the best Ipod interface?
Also where is the best place to fit it?
Finally if I'm taking the centre console out I might aswell fixt the 12v socket. It works fine but is loose any idea what parts I need?
Thanks for your input.
padster is offline
post #2 of 7 (permalink) Old 30th August 2012, 00:05 Thread Starter
padster's Avatar
I guess it's one of those questions you can't answer - you've either had one or the other.
Well I've just ordered the xcarlink. Hopefully I'll manage the install without any problems!
Any tips for the install?
padster is offline
post #3 of 7 (permalink) Old 30th August 2012, 00:15
Syx
#MrGrumpy
Syx's Avatar
Car: 2008 2.2 CTS GT
I had a loose cig lighter socket, needed a #12. Slid the old one off as it was cracked, new one on and it's nice and solid again.
Honda Car Parts / Choose by Model / Genuine Honda Parts | Honda Cars | Honda Motorcycles | Honda Power Products | Lings Honda
Also had the xcarlink, (non-iPhone version) and worked a treat until I upgraded to a Double DIN.
Install is fairly straightforward. Someone posted a PDF on here earlier this evening from Honda which showed very clearly how to do it but there are How-Tos, and tbh it's hard to go wrong as long as you are patient with removing the trim!
Syx is offline
Thanks to Syx from:
post #4 of 7 (permalink) Old 30th August 2012, 06:27
Maxwell1's Avatar
Car: 2007 CTR, Black, 19's
Can you tell me if the xcarlink is the same for all the fn2 civic models? I've got a type r but my friend has a 2.2 and wants to know of it will fit his when I remove mine.
Maxwell1 is offline
post #5 of 7 (permalink) Old 30th August 2012, 09:33 Thread Starter
padster's Avatar
Thanks for the reply Syx. Will be doing the lighter socket at the same time.
padster is offline
post #6 of 7 (permalink) Old 30th August 2012, 09:41
Syx
#MrGrumpy
Syx's Avatar
I believe they're all the same across the range as they just connect to the CD changer port. Note that you'll need a "Y" cable if you're installing it into a sat nav model.
Syx is offline
post #7 of 7 (permalink) Old 30th August 2012, 14:04
siakol's Avatar
Car: 2007 2.2 SE ictdi
have you considered a parrot mki9200?
siakol is offline
AUX in xCarLink or Dice Box stevenjp90 Ipods, MP3 Players and ICE (8G) 10 28th August 2012 17:51
Upgrades Dension 100/ XCarLink cable length xsprigganx Ipods, MP3 Players and ICE (8G) 2 4th January 2011 16:26
Head Unit Spotify and DICE/DENSION mrmeme Ipods, MP3 Players and ICE (8G) 2 29th December 2010 16:08
Other Dice or Dension aceboy Ipods, MP3 Players and ICE (8G) 10 23rd April 2009 21:16
