'84 Mk3 Sedan (Water in the trunk) - Civinfo
post #1 of 8 (permalink) Old 6th February 2016, 21:59 Thread Starter
Alvega's Avatar
Hello to all
I own a Civic Mk3 Sedan with the 1.3 engine.
I bought it a few months ago and now with the rain I have the trunk pretty wet.
I looked around and I didn't discover where it cames from.
Any ideas?
As you guys know rust arrives easily so I would like to know if someone had the same problem or if knows how to solve it.
Thanks.
Alvega is offline
post #2 of 8 (permalink) Old 7th February 2016, 13:05 Thread Starter
Alvega's Avatar
Another pic!
Alvega is offline
post #3 of 8 (permalink) Old 11th February 2016, 21:16 Thread Starter
Alvega's Avatar
Anyone has an idea how to solve my trunk problem?
Thanks.
Alvega is offline
post #4 of 8 (permalink) Old 11th February 2016, 21:20
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Pop off the inner boot trim/carpet and try to chase the leak to the source.
Good luck.
Farqui is offline
post #5 of 8 (permalink) Old 12th February 2016, 20:28 Thread Starter
Alvega's Avatar
I did that but it I had no conclusion.
Anyway, I didnt explain how the water apeears in the trunk.
It's something like this (Paint skills ) :
Alvega is offline
post #6 of 8 (permalink) Old 12th April 2016, 20:19
gaseb's Avatar
Car: 2007 FN2 Black
Ŕemove both roof moldings and check for any sealing crack.
gaseb is offline
post #7 of 8 (permalink) Old 13th October 2016, 12:33
DoriD's Avatar
If you haven't sorted this already, check rear lights from inside. Most hondas leak water in that way especially sedans, integras, ek and eg civics etc. You might not be able to see traces of a leak so use water hose and spray generously, water bucket can help too. They usually have some kind of gasket behind lights, if you cant source one you can build one yourself, it is easy enough. Some people have used hard cardboard if I remember correctly, something similar to shoe box cardboard but it was 1mm thick, not sure what its called.
I have used inside tire from a bicycle, had it cut lengthwise then built a gasket on a piece of cardboard previously marked in shape. That way I was able to build a new gasket from 4 pieces of tire, glued together. It was a a really neath job and worked a treat.
If lights aren't your problem next place to check would be boot lid seal up on top near rear window, corners. Maybe you need a new seal or boot lid adjustment. Another possibility, but very unlikely, would be your rear window seal has deteriorated. Again it would be corners that let water in which then runs down and pools in bottom corners till it goes behind window and runs down side walls/suspension turrets. New seal is the only solution but I doubt that is your problem here.
good luck
DoriD is offline
post #8 of 8 (permalink) Old 13th October 2016, 13:48
Skomaz's Avatar
Car: 2006 2.2 ctdi Sport
^^^ THis! I'd bet a tenner it's rear light seals leaking! Usually they have a PU foam seal aorung them that perishes with time. Take them off, clean them up and there-fit with sealant.
Skomaz is offline
Crv mk3 wiper redskel Honda CR-V 4 15th March 2015 23:23
Leaks Water in trunk nemo1982 Bugs, faults and irritations (8G) 9 17th March 2012 11:20
Mini Smurf Mk3 smurf79 Any non Civic chat here please! 4 29th January 2011 22:40
England South Hawk Meet Mk3 - 21 June 2009 dave87 Past Events 44 26th May 2009 15:58
