2003 Civic S 1590 cc---Rear screen washer - Civinfo
post #1 of 1 (permalink) Old 21st April 2010, 13:32 Thread Starter
The rear screen washer in my Civic is not working. The pump is working and operates the front washers. Disconnection of the pipes where the pipe enters the hatch door from the body has proved that water is getting to there and the pump is delivering. The blockage must be between there and the nozzle. I have removed the panel in the hatch door and can feel the pipe where it enters the wiper arrangement but I am reluctant to exert too much force on something I cannot see! I notice that the nozzle seems to be in a separate and perhaps detachable bit from the wiper stalk. Can this be removed and, if so , how? `would this help? If it is necessary to expose the pipe where it enters the wiper motor how do you remove the main panel on the hatch door? If there is an easy way to tackle this please advise. I have made sure the nozzle is clear.
Rockford
rockford is offline
Alloys Choice Will a 2003 17'' set of Honda Civic Type R alloys fit a 2007 civic 2.2 cdti SE? domingo Wheels, Tyres, Suspension and Brakes (8G) 0 25th June 2007 17:17
Windscreen Screen Washer Meino Bugs, faults and irritations (8G) 14 14th May 2007 15:37
Tech 2003 1.4 civic jasey007 Engines and Transmission (8G) 5 3rd December 2006 19:58
Head screen / headlight washer fluid TTDegs Lights (8G) 12 2nd September 2006 13:24
Rear Screen karlak General Discussion (8G) 11 9th June 2006 16:45
