Turn signal wire - Civinfo
post #1 of 8 (permalink) Old 5th September 2014, 14:22 Thread Starter
Turn signal wire
Hey guys,
I don't want to remove the whole of the front car again to access the very tight turn signal bulb, where can I tap into the wire so I can install a switchback LED?
EDIT: Just for confirmation, I want to know if there is a wire that is live when the turn signal is used.
Tea-Aholic is offline
post #2 of 8 (permalink) Old 5th September 2014, 14:47
Grayfox's Avatar
Car: '11 Impreza R Special
Eco display Eco display
Besides the wire that goes to the blinker, NO.
Grayfox is offline
post #3 of 8 (permalink) Old 5th September 2014, 15:27 Thread Starter
Thanks Grayfox. I don't know how I'm going to wire it, it's very very tight on the 9G.
What I was asking was where does this wire lead? So it starts at the socket for the globe, then where does it go? If it's in a better place, I can wire it there instead of trying to reach into the turn signal socket.
post #4 of 8 (permalink) Old 5th September 2014, 23:11
Grayfox's Avatar
It goes to one of the internal fuse boxes.
Grayfox is offline
post #5 of 8 (permalink) Old 6th September 2014, 07:43 Thread Starter
Hmm, okay so in that case you suggest I intercept the wire at the socket? I'm a bit weary about cutting a factory wire, should I tap into the socket itself?
Does it matter whether I connect the positive turn signal wire to the negative or positive part of the socket? I was thinking as long as the LED strip gets a signal from the turn signal it should override the DRL function.
EDIT: the turn signal function will not work when I connected it to the negative terminal of the battery, just the positive so I answered my own question.
I have another question (sorry Grayfox or anyone who can help) if I want the turn signal to work all the time, I would need to have the LED strip negative wire always connected right? I have only wired them to the parkers. So to make this work, I presume:
Black: ground to the battery (where is the ground for the factory DRL?)
Red: Parker light (Or can I wire this to the DRL wire so that it is full brightness when during the day and dimmer at night?)
Yellow: positive wire to turn signal.
EDIT 2: Sorry I was thinking about it and I don't think I want the LED strip to be visible all the time. There is already factory DRL so no point having it 2. But I still want it to function as a turn signal always and come on when with the parkers. So my final connection should be:
Black: Ground at battery terminal
Red: Parker light
Yellow: Positive wire to turn signal.
I presume having the black wire always connected to ground will not run the battery down without the positive connected? Anyone here think what I'm doing is correct?
post #6 of 8 (permalink) Old 6th September 2014, 08:57
Grayfox's Avatar
No need to cut the stock harness.
Use a BA15S extension cable
2X 1156 BA15S LED Bulb Extension Wire Cable NO Error Free Decoder Adapter Socket | eBay
The black cable can ground on the chassis, any part will do.
Grayfox is offline
post #7 of 8 (permalink) Old 6th September 2014, 09:13 Thread Starter
Thanks Grayfox. Problem is the Civic uses BAU15S and even those ones don't fit the original socket holder. Honda has an extra notch that makes these eBay ones useless. And there isn't enough space. I think I will need to splice the wire.
Oh so technically any of the negative wire for the lights of the car can be grounded at the chassis? That's interesting, sorry for being dumb!
EDIT: Just tried, most of the chassis doesn't work, I presume chassis means any metal part? I ended up wiring one side to the ground terminal that is used for jump starts as per the user manual. The other side will be on the battery.
post #8 of 8 (permalink) Old 6th September 2014, 13:10
Grayfox's Avatar
BAU15S have offset pins so you just have to grind one of the pins away, but it may not be fully secure.
Chassis is any bear metal part.
Here is a pic of a FN2 with chassis grounding connecting to the negative on the battery.
Grayfox is offline
  Civinfo > 9th Generation Euro Honda Civic (2012 - 2016) > Styling (9G)
My install F930bt no am/fm signal Lacey Ipods, MP3 Players and ICE (8G) 16 8th April 2014 05:10
Remote Wire wont turn on amp. HCCTDI Ipods, MP3 Players and ICE (8G) 1 23rd June 2013 16:40
Turn by turn guidance on the I-MID Reverend Electronics and ICE (9G) 7 8th October 2012 22:22
Tach Signal tdan7260 Type-R 8 19th September 2012 09:16
No turn by turn option tamzin Electronics and ICE (9G) 9 9th August 2012 10:48
